Question about Viper Vehicle Parts & Accessories
97 Honda Prelude with Viper Alarm won't start
Turns key dash lights come on, then immediately go out, no relay clicking sounds
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
SOURCE: 1993 honda prelude si dash lights
my 93 prelude was doing the exact same thing and for me it was my alternator was working properly.
go to a parts store and have them test it.
Posted on Aug 07, 2008
SOURCE: transmission solenoids Prelude
Which tranny solenoid are u reffering to? What is the actual problem u r having?
Posted on Oct 01, 2008
ltfrc
  • 227 Answers
SOURCE: viper remote starter
Sounds like the tach connection has been loosened or slipped out of position. Here is a link for installation manuals, Will help in location and inspection of tach wire.
http://www.directeddealers.com/manuals/ig/viper/N5501V_12-06post.pdf
Posted on Jan 17, 2009
jpk528
  • 95 Answers
SOURCE: when i arm the car how can i hear the sound viper on
whats the make and model fo the alarm? and go to viper.com/support for more information
Posted on Feb 16, 2009
  • 33 Answers
SOURCE: Viper alarm, lights dont flash
Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
http://64.85.6.121/diagrams/printpage.asp?ModelID=17258&MakeID=16
Posted on Mar 02, 2009
1994 Honda Prelude si starting problems
Your starter motor is either not getting power or in need of replacement. Otherwise, there is nothing wrong with your car.
Also check your battery connections for no corrosion there as well as by the starter motor. Low voltage circuits in a car are extremely vulnerable to poor contact issues.
Mar 29, 2017 | Honda Prelude Cars & Trucks
Sorry bud you need a starter, relay contacts in the starter are very dirty or just plain worn out.
Sep 08, 2012 | Honda Prelude Cars & Trucks
Lost my remote viper remote starter. Car alarm goes off when open and car won't start. What do i do to disarm the alarm since the car won't start?
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
Aug 25, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
2001 aurora won't start at all. Hook batery up horn horn sounds and doesn't stop head lights stay on but nothing happens when the key is inthe ingition. No clicking or anything at all. alarm on...
The security system does not disable the starter, it only disables fuel to the engine. In the fuse block under the hood, locate the STARTER relay. Place your hand on this relay and see if it clicks while someone else turns the key to start...if the relay is ok then the starter itself is faulty. Good luck, i hope this helps.
Jul 11, 2011 | 2001 Oldsmobile Aurora
Alarm light in dash blinks constantly, remote start doesn't work, and occasionally truck doesnt start. Have an Esi Viper remote
did your install it yourself or did someone do it for you if either way man you may need to get someone to look at your wiring make sure everything is tired in right to your vehicle your power sources your ground everything your relay may be gone on the remote start in that case you can have that problem check your relay leading to your remote start
Nov 11, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
1990 Honda Prelude won't start after I stop or konks out during
Sounds like it could be a Main Relay (with controls the fuel pump & others). Look it up - on the '92 models its under the dash near the steering column.
Apr 06, 2009 | 1988 Honda Prelude
Alarm goes off for no reason 20-30 minutes after i lock doors
remove the battery from your remote and see if works
Mar 12, 2009 | 2001 Dodge Viper
Viper 771 Remote start/Alarm
the viper alarm is malfunctioning , it is supposed to bypass the key ignition and or chip in the key to allow it to start , you will need to look for a reset button( under the dash and just two wires going to the button)( stuffed under the dash ) ( not the switch) , this should let you start it but if the alarm components that control that bypass is to far gone then this will not help and the alarm will need repair , replaced or removed
Jan 25, 2009 | Viper Security and Remote Start System...
1993 honda prelude si dash lights go off and engine dies. try to start but engine dies. if dash light comes on after fiddling with key, car can be kick started.
Jul 27, 2008 | 1986 Honda Prelude
Vehicle Parts & Accessories Logo
18 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
