Question about ASUS F6A-X2 PC Notebook
Insert disk key - ASUS F6A-X2 PC Notebook
Imac will not load disk
Hi Wayne,
Put in an original install disk that came with that Mac and hold option key while booting and select the disk with arrow keys and press enter
Regards,
Sean
Apr 18, 2013 | Apple iMac Computers & Internet
RESET TO FACTORY SETTINGS
What type of Laptop ? and operating system on it ?
Restoring your laptop to factory settings can take up to an hour to perform, depending upon the type of laptop and operating system on your machine. Prior to performing a system recovery, you should remove any external peripherals, such as ExpressCards, PC Cards, and USB-connected printers and hard drives. Turn on the laptop. Press the "F8" key until the "Advanced Boot Options" screen appears. Select "Repair Your Computer" using the arrow keys. Press the "Enter" key. Choose your "Language," then "Next." Login with an administrator-level username and password. Click "OK. Select "Dell Factory Image Restore," then "Next." Tick the check box next to "Yes, reformat hard drive and restore system software to factory condition." Click "Next." Click on "Finish" after the computer has concluded the factory restoration. b> Restore on an HP b> Insert the HP recovery disk. Restart the computer, and press the "F11" key. Press the "F" key to "reinstall factory settings." If your computer's operating system is damaged, you may only see "perform a full system recovery" as an option. In this case, press "R." Insert any disks if prompted by the restoration program. Otherwise, permit the computer to restart as needed. b> Restore Via Disks (Generic) b> Insert the "Recovery Disk" or "System Recovery Disk." If you have more than one disk, make sure you insert "Disk 1" or "Part 1." Press any key to boot from CD if prompted to do so. Choose a "Full System Restore," "Restore Factory Settings," or another option worded similarly. Confirm that you want to perform the restoration. Press "Next," "Yes," or "OK," as needed. Press "Finish" or "Restart" when prompted by the computer. Hope this helps.
Dec 23, 2012 | Computers & Internet
Will not start
A brand name and model with operating system would be nice so someone could be precise. ?
Dec 10, 2012 | Computers & Internet
Aspire one keep saying no bootable device insert boot disk and press any key and I don't have a disk slot
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 19, 2012 | Computers & Internet
HP Pavilion dv4-1548dx no bootable device-- insert boot disk and press any key help no disk
en mi laptop hp pavili
como hago si mi laptop hp paviliondv4 sale no bootable divice -- insert boot disk and press any key
Apr 23, 2012 | Computers & Internet
Product key e machines model EL 1200
You do not need any product key to install Operating System in Emachines as it uses OEM versions of OS. If you have Recovery Disk you can use it.
The recovery disk consist of 2 DVD, the first is the System Disk (this is first disk to insert), once finished loading, it will ask to insert the second CD (Application and Drivers disk), if in case both are not working, then follow the below mentioned steps:
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also place order for a set of Recovery disk by calling Acer Technical support at 1 800 816 2237
Thanks and regards,
Jitha
Aug 09, 2011 | Computers & Internet
I have a Yamaha portatone PSR-6700. When I insert a disk, the disk indicator does not light up. When I depress the disk orchestra button, it says "No Disk Found!" I can insert the disk and the...
Verify that the disk is sampled when you insert it, that is you can hear it access the disk. Also make sure you disks have NOT been corrupted by trying them in a computer or near magnetic fields. Some Cell Phones have a strong enough magnet in the speaker of them to degauss the disks.
Jul 31, 2011 | Yamaha Psre223 61 Full Size Keys Bass...
I'm trying to recover from Backup Disks made when i first got the computer, I've inserted Factory Default disks 1 + 2. Now its asking for the next Disk. Question 1: What is the next Disk to insert?...
Thanks and regards,
Jitha
Jan 19, 2011 | Acer Computers & Internet
I have a toshiba laptop 1996 and it keeps saying insert system disk in drive pree any key when ready
it needs inf from os disk (xp )
so insert your windows disk and press any key.if you do not have a windows disk borrow a friends it doesnt matter whose disk you use as long as you have a valid cd key.
Jan 23, 2009 | Computers & Internet
ASUS F6A-X2 PC Notebook Logo
11 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
