Question about Mantis 4-Cycle Tiller
Won't start has spark , no fuel
Fuel pump cycling long time bike won't fire,has good spark.
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
What to do When Your Motorcycle Won Start
1098 won start
Ducati 907 906 Paso Workshop Service Repair Manual 1988 1993 Searchable...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Mar 14, 2013 | Ducati Motorcycles
My Lincoln navigator won't start will turn over but won't start
you either have no spark , check spark plugs, or fuel pump isnt working , dont know the year of your lincoln but it could possibly be a fuse for your fuel pump ..
Feb 17, 2013 | Cars & Trucks
I have a 94 chrysler concorde. The problem is it won't start, I have replaced the fuel pump and the fuel pump relay fuse. And it still won't start. What should I do now?
check see if you getting spark if not.have vechicle code scan could have faulty ECM .faulty camshaft sensor and crankshaft sensor.make sure engine has been tuned up.replace fuel filter change spark plugs and wires. before engine can run need fuel and spark.either one not working car will not crank.
Jan 12, 2013 | Cars & Trucks
Hi everyone I have a 125 4 stroke ducar engine it won't start I don't know why can anybody help me the petrol goes thru and it had a spark I have no clue why it won't start
there are three things that engine needs to start fuel,spark and compression you stated that fuel and spark but what about compression if no compression could rings or valves!
Jun 02, 2012 | 2003 ATK 125 4-stroke
1997 mazda 626 won't start.
Are the plugs wet with fuel?
Check for spark. No spark? it may be the ignition module.
Plugs dry and spark present? No fuel?Spray a little starting fluid and see if it will run on that.
Then check pump fuses and for fuel pump noise.
Jun 01, 2017 | 1997 Mazda 626
Turns over won't start getting gas up top to fuel injectors, but won't start
GIVE IT A SHOT OF STARTING FLUID IN INTAKE IF IT RUNS FOR A MINUTE THE CONTROLER FOR INJECTIORS HAS PROBLEMS IF NOT CHECK FOR SPARK AT SPARK PLUGS THIS WILL TELL YOU REALLY WHAT SYSTEM YOUR HAVEING PROBLEMS WITH. USALLY IF THERES FUEL AT INJECTORS ITS A SPARK PROBLEM GOOD LUCK
Aug 20, 2011 | Dodge Neon Cars & Trucks
Won't start sometime
you need to determine if its a no spark or no fuel problem.check to see if you have spark at the plug.if so then you will need to see if its getting fuel.check this when it won`t start as when its working its pointless.to check for fuel you can spray intake cleaner into the intake when it won`t start,if it does then stalls when it has burnt what you sprayed then its a fuel problem.the pressure will have to be checked with a gage to get a proper reading.the pressure should be about 35 lbs.pumps are a common problem with this year.if no spark then you will have to find what component is causing the no spark.
May 09, 2011 | 2001 Buick Regal
1995 e34 520i won`t start
i would check the fuse for the fuel pump and the relay.
May 26, 2008 | 1994 BMW 5 Series
Mantis 4-Cycle Tiller Logo
60 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
