I have a Smith Corona Galaxie Twelve typewriter. The roll where the paper lays will not type through, it keeps sliding back to the far right end of the page. any ideas?
  • 328 Answers
Sounds like the escapement is stuck or broken. Can you move the carriage release levers? Do they have some spring tension on them? Open the bottom of the unit and look down at the bottm of machine and while moving the carriage, look for movement in the middle bottom section. Particularly if you depress the spacebar, watch for the escapement to rock back and forth. Maybe gummy. Try a little lube spray.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Jun 22, 2009
The carriage on Smith Corona Galaxie Manual typewriter sticks. Any ideas?
The SC typewriters need lubrication annually. If you have not lubricated it lately, it's time!
May 16, 2015 | Smith Corona Office Equipment & Supplies
Why does paper not advance to next line when carriage returns?
There might be a setting for how many lines it moves when the carriage gets to the end. It is mechanical so you'll see it!
Sep 01, 2014 | Office Equipment & Supplies
How do I fix my Smith Corona SC110 Typewriter?
make sure the right hand platen knob is tight hold the platen and turn the knob top toward the back of the typewriter until it is tight
Aug 17, 2014 | Smith Corona Wordsmith 100 Typewriter
Smith Corona with a key disconnected
Hi: you should be able to do it yourself. Flip the typewriter up on its end. As you can see all the typebars are connected in the same way.
You need to find the sub link that popped of the I typebar. It might be bent. Move the two keys that are adjacent to the letter I and you should be able to find the sub link that came off. Straighten it out and use a flat tip screw driver to open the clip on the end of the sub link and connect it back on the end of the typebar.
Good Luck
Andrew
Oct 13, 2013 | Smith Corona Vintage 70s Galaxie Twelve...
My Smith Corona Galaxie 12 malfunctions by automatically adding spaces between letters while I type. How do I fix this?
Did you ever get a resolution to the added space problem? I just purchased an old Smith-Corona Super Sterling and it is doing the exact same thing.
Jan 11, 2013 | Smith Corona Office Equipment & Supplies
My Smith-Corona DX 4000 typewriter when you turn it on it comes up with lid? - ribbons? & won't type. How do I fix it?
The lid has an extension that pushes on a switch on the L. thru a hols in the lower case they do break noff. TRy rolling up some paper and pushing it into the hole and cheating the switch.
DickyO
Aug 01, 2011 | Smith Corona Office Equipment & Supplies
Hello! i just got a smith corona Galaxie Twelve Typewriter (around 70s made) and I have never used a manuel typewriter before, and the typewriter is in its carrying case. The problem is I do not know how...
You opened the case by pressing in two metal tabs in the plastic block under the carrying handle. Under the bottom of that same plastic block is a smaller metal tab. Press it up into the plastic block, and it will unlatch the front of the typewriter. Lift the front, then slide the machine forward off the tabs that go into the back, and you're free!
Feb 15, 2011 | Office Equipment & Supplies
Smith corona SL480 instruction manual. I just need a manual so I know how to use the features built into the typewriter
How to Use a Smith Corona Typewriter A Smith Corona typewriter can be either a manual or electric model. Whichever model you have, the typewriter works in basically the same way. If you are familiar with a computer keyboard, you can type on a typewriter as the keys are laid out exactly the same. Unlike a computer, typing mistakes are harder to correct and, unless you use carbon paper, you will only have one copy of any document you type.
Aug 03, 2010 | Smith Corona Office Equipment & Supplies
Galaxie twelve power-space bar
There is an adjustment for the power space bar..looks like it is pulling the escapement out too far. Not something for a novice to try..It may also have a bind in it.If so just try to wiggle it to remove the bind.
Hope this helps
Squipps
Jul 21, 2009 | Smith Corona Office Equipment & Supplies
Bought a great smith corona coronet electric 12 typewriter - and need a manual to learn functions - any ideas? cant figure out the return other than advancing paper and sliding across manually - but i...
Try going to www.willrepairservice.com for a manual for your Smith Corona typewriter. Or, you can go to Google and type in "Will Repair Service", go to the first link displayed in the results. Best of luck to you!
Apr 07, 2009 | Smith Corona Office Equipment & Supplies
229 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
