Question about Refrigerators
Kenmore 54383300 water filter
I have a Kenmore side-by-side ultrafresh refrigerator model # 5255210, serial# SM0649567. I cannot find the water filter. Where is the water filter located on this refrigerator ?
Owning 1 of these refrigerators will require you to replace the water filter from time to time, in order to keep the water fresh and the refrigerator running efficiently. Kenmore refrigerators are made by Amana, Frigidaire, GE, LG, and Whirlpool, so it is important to find out which manufacturer made your Kenmore refrigerator, in order to make sure you order the right part. Kenmore refrigerators use filters that are located in the bottom, front panel of the refrigerator. Details can be found on WiKi how to change a water filter on a Kenmore Refrigerator.
May 24, 2016 | Kenmore Refrigerators
Can't close the door on the water filter cabinet on my Kenmore Elite refrigerator
check to be sure you have the correct length filter in place, you may have one to long for the unit.
May 30, 2015 | Kenmore Refrigerators
Does the ice maker filter have to be in for the fridge to work right it is a Kenmore Coldspot
? I don't believe there is a "Ice maker" filter just for the Ice. There is a water filter for both the icemaker and cold water (usually). Check your Owner's manual. Usually there is an option for water filter or no water filter. The no water filter option requires a "bypass" device to substitute for the filter, but of course the water is not filtered, unless you have an external water filter in the supply line to the refigirator. Hope this helps. Of course if you have no water supply, the Ice Maker will not make ice.
Mar 03, 2015 | Kenmore Refrigerators
The water dispenser is not working on my kenmore model #795.5132
This probably means you need to change your water filter. That would be your first step. It could be the water valve but I'd change filter first.
Write down this part# for filter: 5231JA2002A and you can purchase here.
Appliance Parts
Feb 08, 2015 | Kenmore Refrigerators
How install a water filter in Kenmore refrigerator
Water filters usually are installed in line in the water supply line to the refrigerator (behind it).
Dec 22, 2013 | Kenmore Refrigerators
I need a replacement filter for my kenmore coffee maker item#69768
If anyone is looking for the Kenmore Coffee Water Filter model 69768 - Sears / Kmart re-branded the filter under the Cuisinart name making them near impossible to find under the Kenmore name. HERE is the link to order them under the Cuisinart name at SEARS (its the EXACT same filter and they come 2 to a pack)
http://www.sears.com/shc/s/p_10153_12605_00869768000P
Nov 13, 2010 | Kenmore DCC-KE12 Coffee Maker
Can't locate the water filter. water has a bad taste
The base grille water filter is located below the freezer
compartment door. Depending on your model, you may have a filter that is installed behind the base grille or a filter that is installed through the base grille.
May 23, 2009 | Kenmore Refrigerators
Where the heck is the water filter?
some fridges don't have water filters, some have them behind the bottom grill or inside or on the back
Mar 24, 2009 | Kenmore Refrigerators
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
