HOW DO I PROGRAM My pioneer cu-vsx105 for tv and dvd
PIONEER REMOTE CONTROL CU-SD092
HAVE A REMOTE FOR MY PIONEER SD-P5185 PROJECTION TELEVISION. THE TV IS ABOUT 10 YEARS OLD OR SO. REMOTE CONTROL IS MODEL CU-SD092. DOES ANYONE KNOW THE STEPS TO SEARCH CODES TO PROGRAM THIS TO WORK TV. IT WORKED BEFORE BUT TOOK THE BATTERIES OUT AND NOW I HAVE RESET IT AND DON'T REMEMBER HOW TO REPROGRAM
Feb 02, 2014 | Pioneer Televison & Video
I have a pioneer usx-405 reciever for a PDf407. It used to work just fine but recently whenever I power it on in keeps flashing "muting". I looked it up online and a forum said I need a remote...
You mean Vsx 405, right? Model numbers are senseless enough without typos.
Are you saying you DON'T have a remote? How did you ever set it up? There are several CU-VSX105 remotes available on eBay, one at $9.99 and expiring in a few minutes (17:12 PDT). If you get this in time you could snipe it at the last 10 seconds.
http://cgi.ebay.com/Pioneer-CU-VSX105-Remote-Control-Receiver-/170642335146?pt=LH_DefaultDomain_0&hash=item27bb1365aa
Many a Pioneer receiver will come up MUTING if it powered down Muting. It's not clear if you have been experiencing unwanted shut-downs. Unwanted Muting or any other command could well originate with an unintended remote control source. Mask the receiver so it can't see other I/R sources.
May 21, 2011 | Pioneer VSX-405 Receiver
No hdmi funktion to my new LED TV.
Most likely the output from the Pioneer is not compatible with the TV.
Try resetting the output by holding Stop (on the pioneers front) and press the Open/close button. This will reset the output signal. Also, if the harddrive in the Pioneer is defect, the HDMI signal will not output.
Jan 12, 2010 | Pioneer DVR-550HS HDD Recorder
I was given a pioneer tv sd-p5575 and i dont have
MY PROBLEM IS ANTIVIRUS IX DIRTY AND NEW ANTIVIRUS
Dec 06, 2009 | Pioneer Televison & Video
Region unlock code.
hopefully this will help
Converting the player to Multi-Region:
Requires the use of a Palm Pilot w/Palm OS 3.0 or later and the OmniRemote Pro from http://www.pacificneotek.com/
(Other PDAs using Palm OS and compatible with the OmniRemote Pro from http://www.pacificneotek.com/ can also be used).
1. Program the Palm Pilot/OmniRemote. For instructions on programming the Palm Pilot/OmniRemote click How to Program the Palm Pilot.
2. Power on the DVD player without any DVD in the tray.
3. Keep the programmed Palm Pilot close to the IR port of the DVD player.
4. Start the OmniRemote program.
5. Place OmniRemote in TV mode and tap the "0" button on the OmniRemote.
6. The DVD player will power off.
7. Power the DVD player on again. Check the Region-free status by playing a DVD.
Dec 18, 2008 | Pioneer Televison & Video
Need to program remote for pioneer receiver
Usually universal remotes are programmed by holding down the device button (i.e. if you would like to teach the remote how to control a TV, press and hold the TV button). If the device key lights up when pressed, it should stay on or blink when in programming mode.
After that, input the code that corresponds to your device:
http://www.remotecodelist.com/remotes/pioneer/pioneer_misc.html
The remote will either accept this code directly, or you'll need to confirm it. Try pressing the device key again.
Oct 19, 2008 | Televison & Video
Pioneer dvd recorder dvr-530H
The EPG is the electronic program guide trying to download TV listings.
http://en.wikipedia.org/wiki/Electronic_program_guide
This is normal for this player. To disable this, you would need to turn off the TV guide function.
Sep 28, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Pioneer DVD-RW DVR-111d instruction manual
The manual likely is at the Pioneer website. But why do you need it? These drives stick in your computer pretty easily, and only function if you have a good DVD burning program installed. Did it come with an installation CD? Your burning program may be on that. If you run into trouble, just call Pioneer--they owe it to you.
Mar 23, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Unlock codes for Pioneer DVD player
Pioneer DV-667A
Dec 13, 2007 | Televison & Video
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
