Question about Vtech Tote n Go Laptop Plus
Tote n Go laptop, mouse click not recognized
In the Tote n Go laptop, when I try to select an activity by pushing the number and selecting the same through mouse, the mouse doesn't respond to the click. However, the left, right, forward, backward motions of mouse are recognized, only the mouse click is not recognized by the laptop. Any advice on how to resolve this problem
    Problem Solver:
  • 18 Answers
It is very likely one of the wires came loose inside the mouse itself. There are 4 black foot pads on the bottom of the mouse. With the batteries removed, pry off the four feet and remove those four screws. You will see two tiny brown wires that correspond to the mouse button.
Examine these two smaller brown wires and ensure they are not loose or have become disconnected from the small computer chip inside. The two smaller brown wires are on the interior of the chip and should be soldered to the board, opposite a larger brown wire and a larger white wire. The two larger wires, brown and white go back into the main cable that connects inside the laptop.
If these four wires appear to be intact, the next step would be to remove the two larger screws in the central blue piece with two larger holes on either side. This will release the mouse from the base. Examine the two solder points where the two brown wires are connected for any breaks. If these look good, there are two more screws that hold this chip in place. remove them and examine the button of the mouse.
Many others have found the actual push button under the mouse fails. This blog entry explains how he fixed the mouse button: fangletronics.blogspot.com
If you need further help, send a request to: kjhenseler [at] gmail [dot] com
Posted on Nov 14, 2009
  • Kenneth Henseler
    Kenneth Henseler Nov 16, 2009
  • Marty Leibowitz Jul 06, 2014
    Neither the buttons or the mouse on our Tote & Go responded. I opened the mouse and saw that there should be 4 springs holding the movable part of the mouse in proper position. 2 of the springs were off and loose. It was a 5 minute job of re-attaching the 2 springs. After that, all the buttons and the mouse worked again. I figure that without all the springs, the mouse was not centered properly and not making the right connections. Marty
My daughters V-tech tote and go is malfunctioning. It powers on, however, the activity selection buttons are none responsive, so is the mouse. When powered on, it just keeps running through the intro
Sorry, I don't know much about them, but try pulling the batteries and unplugging it too, if it has a power cord. Then hold down the power button for 20 seconds or so to drain the charge in the capacitors. I hope it works for you. By the way, your question is written better than any question I have seen here.
Oct 27, 2014 | Computers & Internet
How to fix mouse problem
The sensors are prone to picking up a lot of dirt and lint during use. Remove the covers, clean the ball and all the sensors and try again.
Sep 03, 2014 | Vtech Tote and Go Plus
When I plug in an external mouse, it won't click.
If an external mouse does not work correctly, you may need to install device drivers for it. Windows does not support all 'mice' just by plugging them in. Download and install the drivers for the mouse from the manufacturers web site. Do NOT do a factory recovery for a device driver problem.
Jun 29, 2014 | Lenovo IdeaPad Yoga 13
Cursor hopping backwards
One of the innovative features about laptops is the built-in trackpad in lieu of a standard computer mouse. This device eliminates the need to have a mouse dangling from your PC as you tote it from palce to place. Unfortunately, this feature can also wreak havoc on word processing, as the text cursor will jump around the document if the trackpad is accidentally grazed during typing. Fortunately, this is a problem that is simple to correct for both PCs and Macs.
Click on the "Start" icon. Select "Control Panel," then select "Hardware and Sound." Select "Mouse," then select "Device Settings." Select "Settings." Under this tab select the option for "Tapping." This will let you turn off the feature that moves the cursor when you tap the touchpad. Stopping Cursor Jumping for Macintosh Select "System Preferences." Select "Trackpad." Uncheck the box next to "Clicking." This will disable the tapping feature.
Mar 01, 2013 | Computers & Internet
Mouse driver for m00117 laptop running win 7 does recognize mini mouse need driver
click start control panel under harware and sound view devices and printers you should see your mouse right click select open download mouse software
once your usb mouse is connected windows 7 should automatically search for and update the drivers
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question/exclamation mark? ! or a red Xthis means a driver will need to be updated right click select update driver
Oct 18, 2011 | Sakar Optical Retractable USB Mouse...
How do I save music from an usb port to my computer
Plug in your usb wait for windows to recognize the drive then access you usb drive. once its open go to your music files and select the files you want to copy press the right mouse button then select copy. then click on your usb drive's window then press right click again on your mouse and select paste.
Nov 10, 2009 | IBM ThinkPad R52 Notebook
Mouse don't work after restored
Reboot. The puter should see it and install it
Oct 07, 2009 | Computers & Internet
My computer not recognized the USB Flash memory, but it recognized other device like the mouse, webcam scanner, digital camera ... Thanks for your help
if usb flash memory is working on other computer/laptop then do the following step.
Insert the usb flash memory.
Goto desktop, right-click my Computer, click Properties, click on Harware tab, click Device Manager button.
There should be yellow exclamation(!) sign showing Unknown Device
Right-click and select UnInstall.
Reboot your laptop
It should work.
May 30, 2009 | Dell Inspiron 6400 Notebook
Trying to use a brand new Verbatim usb 500GB portable hard drive
For WindowsXP:
Goto Start> Control Panel>
Select Hardware Tab > Divice Manager
Select the + on Disk drives, and see if you see your USB Verbatim drive listed (if so good, close all thoes windows and goto the next steps) If not stop here.
From the Contorl Panel> Administratinve Tools> Computer mangement>
Under Stoage select Disk Management on the left panel
Look in the Right panel and single click your USB drive in the "Volume" colume.
Know look at the lower panel and make sure the drive states that it is "Online", look at the "Health" Status. And;
Make sure it has been "Partitioned" in the Layout colume. If not right mouse click the drive letter and select "Mark Potiton as Active".
Right mouse click on the USB drive in the Volume colume> select "Change Drive Letter and Paths"
If there is on drive letter assing to it select the Add button, if one is there, select the Change button and assign one to it or change it to a drive letter that is beyound the number of drives you have.
In other works if you have drives C:, D: and E: before you add the USB drive, make it the H: drive.
Exit out.
Now check your drive files.
Jan 21, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
I can't find out how to activate the "FN" keys. keyboard
1. Right Click on "My Computer" on the desktop.
2. Select Properties
3. Select Hardware
4. Select Hare ware Profiles
Find mouse in the list, double click...
Click Disable
Click OK
You are done!
Dec 21, 2008 | Dell Latitude D600 Notebook
Vtech Tote n Go Laptop Plus Logo
792 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
GI Consulting
relojmesa
Are you a Vtech Toy Expert? Answer questions, earn points and help others
