Question about Mach Speed Trio DA-8033A (512MB) MP3 Player
My 512 on-board mp3 wont turn on
See i had it for a long time and it looks like it has cracked but its not fully opened and now it wont turn on and i think i forgot how to.P.S.Would it be a good thing to take it to Best Buy and how much will it cost to get it fixed.
0 characters
1 Points
Wont turn on unless plugged into computer
Hi it very much sounds like the on board batttery is not charged up, (not charging) hence when you plug into the PC it gets it supply from the USB 5Volts and plays as normal
Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
Replaced SD card now Shaker won't play
Hi Cathi!
Few things you need to know about Sansa Shaker and the SD card:
  1. The Sansa Shaker DOES NOT support SDHC memory cards. Only regular SD cards are supported.
  2. Maximum capacity for supported SD cards - 2GB!
  3. Any SD card which doesn't meet the requirement above might cause the problem you encounter. REPLACE the card with a supported one - SD card with up to 2GB in capacity.
  4. No software/data is stored or needed to be on the memory card - apart from your music files.
  5. MP3 file type is fully supported by Sansa Shaker.
Apr 10, 2010 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Jensen SMPV-2GBUB wont turn on or charge
How to get the Jensen mp3 to charge - model smpv-2gbub,
transparent-pixel._v42752373_.gifIgnore instructions that came with it - they don't work.
Here's how to charge - I discovered this with mine:
1.When computer is on and at windows screen, attach cable from computerto mp3player with mp3 turned player off. It will immediately show you aconnect screen on the mp3 player.
2. pressed the left side middle button twice - this will turn it on and go into music like you're playing a song.
3.Now turn the mp3 player on by switching the button on the right side ofthe device to the on position. It will suddenly show you it's charging- the battery on the front of the mp3 player will have a signal pulsingthrough it.
4. It will turn off after one minute. It's literallyhalf charged now. Strange I know. Repeat from step 1 and it will fullycharged.
If it doesn't fully charge after it turns itself offafter 1 minute the 2nd time, then repeat steps from 1, one more time,but this time when it turns itself off after a minute, still leave itconnected to the computer for 10 mins even though it looks like it'soff. Then disconnect it physically from computer, turn it on with theon button on the right side, press the left side middle button twiceand look at the battery on the screen - it should be fully charged now.
Jan 30, 2010 | Jensen MP3 & Digital Media Players
It wont turn the **** on
There are some reasons why it's not turning on. Here are the things:
1. Battery - make sure that the battery is fully charged.
2. Software - for some reason, MP3 players' software sometimes got corrupted. You need to try connecting it to the computer even if it's turned OFF and see if the computer will still detect it.
3. Electrical Wiring - in most cases, the wire that's connected to the battery or to the board looses connection. You may need to open up your MP3 player to check it. Or it would be best to refer to the manufacturer or to the reseller for repair.
Jun 04, 2009 | MP3 & Digital Media Players
I have a 8gb GoGear it turns off immediatly when i turn it on
Make sure the lock switch was not accidentally engaged, and try powering on one more time. If that fails, plug the mp3 player into the computer, open the Philips Device Manager and run a Repair - it will give on-screen directions once you have clicked the Repair button. Warning: Running the Repair will result in all of your songs being erased from the mp3 player.
-Tha Mp3 Doctor
Feb 14, 2009 | Philips GOGEAR SA6045 MP3 Player
My mp3 is just straight up broken
Out dated anyway...replace; cost between $9.99 to $14.99 (512) or $14.99 to $24.99 (1gig) or higher. Walmart or other dept stores..even walgreen have them on sale. Most cheap units cannot be repaired or cost to much to do so. Please forgive me if you don't agree. This is not a reflection on your ability to purchase a higher cost MP3..just a cost saving solution.
Sep 10, 2008 | RCA M2000 MP3 Player
Apple Ipod Classic
Your logic board has probably went out. This is the board that controls all of the things the ipod does like the back light and volume and stuff like that. The logic board is around $50 and should be replaced by a professional.
Jun 02, 2008 | Apple iPod MA446LL/A MP3 Player
Shaker wont turn on
you have to hold the play pause button until you hear a noise and music starts playing
Mar 04, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Mp3 wont load fully
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Oct 06, 2006 | Philips GoGear HDD1850 MP3 Player
Battery doesn't hold charge
It is just like that because it isn't done recharging. After a while it will turn back to what it's real power level is. You should let your MP3 player recharge for over an hour at least to have it fully recharged.
Sep 25, 2006 | RCA M100512 512 MB MP3 Player
Mach Speed Trio DA-8033A (512MB) MP3 Player Logo
22 people viewed this question
Top Mach Speed MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Mach Speed MP3 and Digital Media Player Expert? Answer questions, earn points and help others
