Question about Maytag MMV4203WS Microwave Oven
Maytag microwave not getting power
Microwave is not getting power. Reset circuit breaker and confirmed outlet it working with another device. Panel has no display and will not respond to buttons.
jsrock516
  • 5911 Answers
SOURCE: MAYTAG mmv4205aab OVER THE RANGE MICROWAVE
It could easily be a bad line fuse and/or line filter. To access you will need to unplug the unit and remove the outside case. Inside the unit, where the A/C power cord comes in, there should be a small circuit card (part #237068) located somewhere with a fuse mounted on it. This is your input line filter board with line fuse. Replace the fuse, first and see if this fixes your problem. This is a 20amp appliance fuse that you can purchase at any hardware store. Make sure you place the cover back on the unit BEFORE you plug it in. It is not safe to have this area of the microwave exposed with power applied. High potentials in the 4,000 volt range are present! If the fuse does not correct your problem, the circuit card runs about $26.00. Good luck and hope this fixes your problem.
Posted on Aug 04, 2007
tomsat69
  • 214 Answers
SOURCE: Maytag MMV4205BA microwave buzz/grind when operating then no power
you may have some arching inside where your magnatron is located.If you open the door on the right middle part there is a silverplate on the wall .If it is burned you may need to replace magnatron.if you do not seee burn marks it may still be the magnatron hope.that would be the only possible thing that would make the noise other then the mtor plate out of place.
Posted on May 15, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Maytag microwave just died.
Take it back to the store and make them do something about them. If they dont then file a complaint with the BBB no reason for you to have to deal with this when it is there problem. It sounds like there is a venting issue and more going on
Posted on May 19, 2009
atomicflash
  • 17 Answers
SOURCE: my maytag microwave lost power
There is always a fuse inside a microwave.Sometime this has only blown due to a surge,and upon replacing, the microwave will continue working.If it is something worse the fuse will continue to blow.In this case it could very well be the transformer,but there are other possible causes as well.(for example the control board or a short.)
Posted on Jun 24, 2009
  • 45 Answers
SOURCE: No power to microwave?
The cord may be defective either 1) at the plug end, 2) internally inside your microwave, or 3) inside the cord itself.
Otherwise there may be an internal fuse that has blown due to a surge, etc.
It is not so difficult to check. Open the rear cover of the unit, and check for an in-line fuse. If there isn't one, or if it's okay, then use a tester to confirm if power is getting to the unit by placing the probes on on both positive and negative contacts. If you don't have a tester, you can use a basic unit (a light with 2 wires/probes) that Home Depot has in the electrical department for a couple of bucks.
Posted on Sep 07, 2009
Everything went out
you blew a circuit breaker...find fuse panel and reset breaker. It will be the one that is tripped
Apr 05, 2014 | Maytag MMV5207BAW Microwave Oven
My maytag microwave blew the ciruit breaker a several times last night. I reset the circuit breaker each time. Then the last time, I reset the circuit breaker and the microwave did not get power back....
If there's no other appliance on that circuit, then please stop trying to use the microwave. You could be dealing with a dead short, and those sometimes leave people,,,DEAD!
I would be really cautious about trying to use it anymore without checking it first for a direct short.
You need to allow the circuit breaker more time to reset, flip to off and give it 2 minutes, then turn it back on. You should feel the distinctive click, as well as hear it if it's working properly.
Circuit breakers can go bad after repeated failures within a circuit.
The outlet could also be damaged now, but normally it's the circuit breaker getting too hot with repeated failures.
If there are a number of other items on the same circuit, then try the microwave in a plug that you know has no other items being used at the same time, preferably while wearing heavy duty leather insulating gloves to protect yourself from any possible shock. If the circuit breaker blows, you've got a possible electrical short within the microwave.
Mar 27, 2012 | Microwave Ovens
Microwave does not work nothing on the control pad work the pad just says se
Hello
Check the power supply. Make sure the microwave is firmly plugged into a working electrical outlet and that your wall outlet is active if your home uses outlets controlled by a wall switch. Check your home's fuses or circuit breakers to ensure they have not been tripped. Without power the microwave will not respond to any input.
Make sure the parental lock is inactive. Some ovens, like the one shown in the image above, feature a keypad lock to prevent children playing with the controls. Most keypad locks can be cancelled by holding down a button or combination of buttons for a few seconds.
Make sure the door is firmly closed. Some microwave ovens will not allow any control panel input if the door is open.
Remove the microwave from the power, wait 10 seconds, then plug it back in. This will reset the microwave oven if there is a temporary problem with the software.
Press the "Stop/Cancel" button several times to cancel the current operation and return the microwave to standby mode. Re-enter your cooking instructions using the keypad as usual.
Oct 04, 2011 | Maytag Microwave Ovens
Microwave, kenmore 721.89822, will run when powered, but will not cook, no microwaves
HELLO.
Follow some straightforward troubleshooting steps to make your microwave work like new again.
1 Make sure the door is closed. If the door is not closed tight, the microwave will not function.Sometimes food will get stuck in the door and prevent the latch from working. Use the paper towel to get the food out, then close the door carefully and listen for the latch to click.
2 Check the power sources. First, make sure the microwave is plugged in; the plug may have shifted or slipped partway out of the socket. If it is plugged in and still does not work, voltage test the outlet the microwave is plugged into. If you are not getting a reading, the breaker is probably blown. Reset the breaker for that outlet in your home's circuit breaker box.
3 Reset the microwave breaker. Take the back cover of the microwave off with a screwdriver. Inside you will find a motor. Most microwave motors have a small red reset button on them. Hit that button. Your microwave should work again if the breaker was the issue.
Thanks.
Sep 18, 2011 | Kenmore 80822 80823 80824 80829 1500...
Microwave has no power when plunged in
1) Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2) Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3) Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4) Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Apr 04, 2011 | Maytag Microwave Ovens
Blowing main breaker
I have a hard time believing that the home's main breaker is tripping instead of the branch circuit breaker that feeds the microwave. I suspect it is really just a difference in terms. You should disconnect it and try using in another outlet - preferably one on a different circuit if possible. If the breaker continues to trip; this appliance should be disconnected and either be discarded, repaired or replaced before using again.
If the microwave works as expected (on a different circuit), it may indicate the original circuit is overloaded. Microwave overs are supposed to be installed on a dedicated circuit. This means only one outlet is on the circuit - no other loads (lights, appliances, etc.) are permitted on this circuit. A microwave typically requires 10 Amps or more when on "high" and will require a significant portion of the power supplied by a 15 or 20 amp circuit breaker. There is little unused to power much of anything else. If other appliances go out when the microwave trips the circuit breaker, you should contact an electrician to have a dedicated outlet installed for the microwave.
I hope this helps!
Sep 23, 2010 | Maytag Microwave Ovens
Lg micorwave, lam1180st refridgerator and microwave were plugged into the same outlet. i heard a loud pop. circuit breaker popped. i reset and the frige works fine. Microwave does not have power. the...
It is possible that the interconnection link(s) between the two sockets in the duplex outlet have blown apart. Turn off power at the electrical panel for this circuit, remove the outlet from it's box, and check the interlink on both sides. If obviously burned, replace the socket. A better option is to run another duplex cable from the breaker box to the outlet from a new breaker, cut the interconnections on the new socket, and wire the new cable to the isolated part of the socket. This supplies full power to each half and allows both units to run at the same time.
Oct 19, 2009 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Has no power
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
thanks
Mar 18, 2009 | Panasonic NN-SN657SMicrowave Oven
Need help
1. Have you tested the outlet by plugging in something else and confirming that the outlet is good? If another device doesn't work in the outlet, then you have a bad fuse or breaker that powers that circuit in the house.
2. If power is OK, you probably have a bad fuse in the oven. You'll need to unplug the oven and remove the outside cover. Replace the fuse with the EXACT same rating of fuse of the original.
Please get back to me and let me know what you find.
- Jim
Feb 12, 2008 | Westinghouse WST3504 Microwave Oven
Maytag MMV4203WS Microwave Oven Logo
23 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
