Question about John Deere Garden
Ltr166 alarm sounds and won't start, why?
I have the grass box on, which has now stuck and I'm unable to release it. The engine cut out and an alarm sounded mid cut. The box is only about a third full.
SOURCE: Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Posted on Mar 24, 2009
youcandoit2
  • 11 Answers
SOURCE: ride on lawnmower isnt starting.
You may have a bad starter - the solinoid is "clicking" but not engaging. Remove the starter and clean it up and connect it to 12 volts to check if can turn. If not then buy a new starter and replace it out.
Posted on Aug 03, 2009
  • 382 Answers
SOURCE: Black&D'er CMM1200 24V is running very slow unable to chew grass
Sounds like a battery problem, you could have a defective cell which is causing a very low voltage to be sent to the motor which = slow spin.
Yes the charge indicator could be related.
You can take the battery apart and find out what type of cell it is and have it replaced...but personally I hate cordless lawn mowers for this exact reason so I would go but a manual push or a gas model.
Posted on May 05, 2010
SOURCE: Was cutting grass: mower chucked down and now
I had that problem, Then I realized the cutting blades were still engaged. Did you make sure the blades were disengaged, The mower was in neutral and the Brake was fully engaged? It won't start without the blades diengaged and the brake on. You must be sitting on the seat to activate the pressure switch also. I recommend cleaning the debris out from under the deck before you start although this will not stop the engine from running if the other interlock switches are all set right. Also recommend raising the deck to the highest position before you start. Please do not activate the ignition switch with hands under the deck. The blades may turn. Not to insult your intelligence but safety is always first. I have a freind who is a lawn care expert with many mowers and years of experience, missing parts of fingers.
Posted on Jul 12, 2011
  • 66 Answers
SOURCE: DROVE MOWER, PARKED IT, AND
Check your drive belt. If you removed the rear wheels, make sure you reinstalled the drive keys.
Posted on Jul 13, 2011
John deere d110 not cutting grass
check belt and pulleys --if belt to loose wont turn blades to cut the grass
Aug 31, 2016 | John Deere D110 42 in. 19.5 HP...
Hayter jubilee 43
Sounds like the fuel system need to be cleaned out. I woudkl also check for grass clogs and a sharp blade.
Sep 07, 2014 | Garden
I own a Toro model 20070 mower with a Tecumseh engine. It's 8 yrs old. I have regular maintenance conducted. The mower starts and runs well but about 20 minutes into mowing, when I shut it down to empty...
Are you sure there is oil in the machine?
Are the Fins on the engine clean and not loaded up with sand and mud?
Sounds like it is running so hot that it is seizing.
Aug 06, 2014 | Toro Garden
2001 BMW 330i wont start. Immobolizer?
Sounds like a dead battery or a dead starter. Try using a jump box or jump start first.
Feb 27, 2010 | Anti-theft Alarm System 3 Series E90 E92...
I have a John Deere lawn tractor Model # LTR166 that won't start and won't even turn over. I found a wrapped wire harness with a female plug - it has 2 purple and 2 white wires that is just dangling and I...
JD lx277 tractor problem would not start ...had starter checked it was ok ,,unplugged seat saftey still no start .ordered ignition module ...put on had to jump battery it Started ...ran couple minutes then proceeded to cut grass ran good for 10 min. then pto kept shutting off pulled up to garage and smelled something ..burning on new module ...could it have been bad or do i have another problem ....help
Sep 23, 2009 | Garden
Husqvarna ct 135 mower,when attempting to engage cutters with lever beside steering wheel the alarm sounds and then the engine cuts out
Hi Janet,
its the warning button on the grass collector. If the button is not pressed in fully, the machine thinks that the grass collector is off, and therefore stops the engine. I had the same problem. If you take the grass collector off, you will see the button on the top left side of the back of the mower. It is covered by a strip of black plastic that slots over it.
To fix the problem my first solution was to tape a washer onto the plastic strip, thereby ensuring that the button is pressed fully in when the grass collector is on. When I got tired of the washer continually falling out, I used a screw to jam the button in. You should be aware though, that with the second method you will be able to engage the cutters with the grass box removed. Potentially a small child (with long arms) could put his/her arm down the shute and chop fingers off etc. I have no kids, and thereby feel safe.
Jul 16, 2009 | Husqvarna Garden
Mar 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
