Question about Baumatic B187 Stainless Steel Electric Single Oven
HOW DO I REPLACE THERMOSTAT
Can you tell me the location and how to replace the thermostat on b151ssb Baumatic oven
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Beaumatic B151SS Single Oven Problem
Disconnect the element, and run the oven for at least 30 mins,,if it does not blow fuse, then more than likely it is a faulty element.
What I cannot understand is that you say the thermostat light is on after the fues has blown? I would have thought that the light would be not be on, if the fuse has blown.
If after replacing fuse and the stat is in the off position, and the indicator light is on then indeed the stat is faulty.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
barkencoa
  • 3463 Answers
SOURCE: Baumatic 720 Double Oven - Door has come off hinge.
If you got to:
www.youtube.com
Then click on youtube videos, and in the search box type in: fitting oven door hinge, you should be able to get all the info you need to help solve your problem.
Please leave a fixya rating for my suggested solution.
Thanks.
Posted on Feb 08, 2009
ginko
  • 19396 Answers
SOURCE: Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Posted on Mar 03, 2010
Testimonial: "Thankyou very much for your help.Im off to buy an element first thing in the morning. Thanks again"
HansPP
  • 2510 Answers
SOURCE: Hi I have just replaced the
Try removing the thermostat bulb from the oven and then turning it on. (Observe the elements carefully because they could over heat very quickly). If they do get hot under this condition, the thermostat is faulty and needs to be replaced. This is not a difficult task, just make a note of how the old one came out and replace the new one the same way. Make special note of the wire terminal positions.
Posted on Apr 04, 2011
My Baumatic BS65MS oven is cooking too hot, it burns everything. I have turned down the temperature, this doesn't help. What would be the problem?
You may have a stuck thermostat and that should be replaced because he's probably telling the other keep eating even though the temperature the temperature would be correct
think your new oven is too hot or too hot or too cold, you can adjust the temperature yourself to meet your specific cooking preference. You can also adjust your thermostat if your oven is not new, since thermostats may "drift" from the factory setting over time. See the "Adjust the Oven Thermostat"
Mar 18, 2018 | Baumatic Ovens
Hi I have just replaced the oven element for my baumatic thinking this was the cause of the oven not heating up, but it still does not heat up although the element gets slightly warm. The thermostat...
Apr 04, 2011 | Baumatic Ovens
Temperature lights stays on an oven is overheating
From the symptons described, I would say that the thermostat is faulty that controls the oven temperature, normal procedure is replace the faulty thermostat.
Nov 30, 2010 | Baumatic B904SS Stainless Steel Electric...
Electric oven dont work
sounds like the heating element, also check the thermostat
Apr 06, 2010 | Baumatic B180 Electric Single Oven
I have replaced my oven element on my Baumatic B180ss-B, but now everything burns. How can I find and replace the thermostat on this oven
The thermostat is the control that has the temperature marked on it, it has a sensor inside the oven compartment, make sure that it is not broken or become detached from it's fixing bracket before you replace the thermostat., you could save yourself quite a bit of money, as it may not in fact be faulty.
Please rate my solution.
Thanks.
Nov 08, 2009 | Ovens
I have a baumatic bc3510ss double oven. everything works fine except the large oven. you can turn on the grill or oven but when you turn on the temperature the rcb blows on the fuse box.
Tthere are a couple of possibilities for your prob, the thermostat, or the oven element is faulty.
Disconnect the oven element, and try it again, if it does not trip, replace the element, if it still trips, replace the stat.
Thanks.
Nov 01, 2009 | Baumatic Ovens
Electric fan oven overheating
It sounds like the thermostat is faulty, make sure the sensor is not detached inside the oven compartment, as this will affect the thermostatI if it is. If o/k, then the only option is to replace the thermostat. If it is fan assisted, then make sure the fan is working o/k as well.
Please leave a rating for my comments.
Thganks.
Mar 01, 2009 | Equipex PZ-330 Electric Single Oven
Thanks.
Jan 12, 2009 | Baumatic B151 Electric Single Oven
Baumatic B187 Stainless Steel Electric Single Oven Logo
14 people viewed this question
Top Baumatic Ovens Experts
Starnley Johnwells
Starnley Johnwells
Craig Butler
Craig Butler
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
