Question about Hobart AM15VL-2 Ventless door type dishwasher
Code HL on readout
The start up readout shows the normal numeric 22-33-44 etc but then a HL will flash and the whole display board lights up with no action happening
Code in digital display does not have a E in front of it
Please let me know if you can get a number after this - if so what number shows up?
Model differences:
• Better models have a digital readout display
• Good models do not have a digital readout display
In the Better Models line, the failure codes will appear in the display as an E followed by two numbers, a number and a letter
or two letters. The control will beep and the Door Lock, Wash, Rinse, Final Spin and Control indicator lights will flash.
Example: E14. To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains
stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something
that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is
started.
In the Good Models line, the control signals the failure code by flashing the five indicator lights of Door Lock, Wash, Rinse,
Final Spin and Control for the first number or letter after the E and the Start indicator light for the second number or letter
after the E. When a failure occurs, the washer stops or pauses and the control beeps and flashes the five indicator lights to tell
the customer that a failure has occurred. To stop the flashing and beeping, the customer may touch the Pause Cancel button.
The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer.
If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate
normally the next time it is started.
To recall an error code,
• Wake the machine by pressing any button
• Wait 5 seconds
• Press and hold the Start and Pause Cancel buttons simultaneously
• All LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking
LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Please Note the following...... on a small number of washers with serial number prefix XC4,
if the previous procedure does not perform as specified, follow the option below:
• Follow all previous steps but instead of pressing Start and Pause Cancel buttons,
press and hold Options and Pause Cancel buttons.
If the washer is a Better Model, the error code will appear in the display. Troubleshoot problem by using charts on the
following pages.
If the washer is a Good Model, the five indicator lights of Door Lock, Wash, Rinse, Final Spin and Control will flash the
number of times for the first digit of the code and the Start indicator light will flash the number of times for the second digit.
Take
separate counts of each indicator light, then repeat to confirm in order to be accurate in identifying the proper error code.
The code is obtained by counting the number of times the lights flash. Example E24: The five indicator lights would flash twice
indicating the 2 and the START indicator light will flash four times indicating the 4. The five indicator lights and the START
indicator light start flashing at the same time.
The control will pause for 2 seconds, then repeat the code as long as the two buttons are pressed and held.
Note: A letter appearing in the code stands for a number higher than nine:
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code F1: the first digit would be 15 and the second digit would be 1. If this code would appear on a washer in the
Good model line, the five indicator lights would blink fifteen times and the START indicator light would blink once.
May 13, 2014 | Frigidaire ATF6000ES Front Load Washer
Readout all of a sudden says E6 and F2 where we usually see the clock/timer/etc. What the heck is going on and how do I clear this so we can see the time display again?
Yup Yup, been there. We had to replace the control board on ours. We are lucky enough to have a repair service tech in town that came by and diagnosed this (cheaply since he didn't really do anything), gave us the part number and where locally to order the new control board. Easiest way is to contact the manufacturer to order a new one. If its the exact same problem, the oven wont hold temperature, will start to heat up then gives the code. The board is very easy to replace, takes less than 30 minutes.
Jan 10, 2013 | Ovens
I have a whirlpool dishwsr. model GU2400XTPB7 that has been flashing the normal light and I cant use it for over a week. I turned off the breaker to the house for 30 min. & that did not work. I tried...
Hi Melinda,
Thanks in advance for using Fixya.com. Now then firstly by pushing the heated dry and normal buttons then repeating is the proper procedure to reset the control board,below is a the exact buttons to push to reset the control. Also please take a count of the number of times the light flashes befroe going off breifly then repeats the same number of flashes; the number of flashes indicates a error code...if if flashes 5 times that error code 5 and if it flashes 7 times its error code 7 etc,etc.. please get back to me with the number of times it flashes.
Here is what i copied and pasted from my online service manual for Whirlpool dishwashers that shows which buttons must be pushed to reset the board,after pushing the buttons shown push the cancel/off button and the board should be reset so the machine will start at least one time where ya can take note of the number of times the nirmal light flashes,
GENE
Mar 01, 2012 | Whirlpool Dishwashers
Refrigerator Crash
Rod; when a run is melted off the board, it is always a result of one or more components on that board shorting out and drawing maximum current that generates enough heat to first lift up the run and then to melt it in two. So if you only repaired the run you still have a problem on that board.
Jan 13, 2012 | Whirlpool Refrigerators
Kfwe50a1 will not start, green light comes on and then flashes red 6 times
Hi Keith,
6 flashes of the led light is an error code and the unit will not fire-up unless isolated the faulty parts.
To confirm if it is the real fault, unplug the unit from the outlet for 15 minutes and then plug it back in and check if the symptoms still persist.
Your unit has a self diagnostic screen that can be access by pressing in rapid sequence "Display", "Channel 5", "Volume (-)", "Power" on the remote control while the unit is in standby mode or the led light stops from blinking.
Self diagnostic screen will be display. Error code will be display together with numerical "0" means no fault detected and "1" means fault detected.
You will see "6 : LOWB with a numerical "1" on the screen, this is an error code for 6 flashes of the led light.
After you've confirmed that the the error code is "6 blinks/ LOWB error code", then the G1 board (Power supply board) is faulty. LOWB error code means that there's a malfunction on the 6Volts output of the G1 board.
To isolate the fault on the G1 board, you must have a skills on electronics troubleshooting, soldering and desoldering parts on the board, have necessary tools and test instrument. If you can't troubleshoot the unit yourself, don't worry, there's a DIY solution so that you can save money for the service fee of a TV technician. You may replaced the entire G1 board(part no. A-1087-323-A), this is more convenient if you are going to do-it-yourself because no troubleshooting and soldering required. I would advice you to obtain the board from your nearest Sony service center because this board is currently not available online.
Please let me know if you need further assistance.
Ratings and feedback is highly appreciated.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Nov 08, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 | Dishwashers
How do I set the digital time on a mossimo analog/digital watch. Where do I find instructions?
If you have the Mossimo that is an analog and gisital andhas the four (4) buttons around the side, here is what I have:
Legend:
Button near the number 10 = A
Button near the number 8 = B
Button near the number 2 = C
Button near the number 4 = D
Switch Control/Normal Readout:
Press:
A = E.L. Backlight
B = Mode
C = For Month Date and Day of Week
D = For Alram Time
Setting Sequence:
1. In normal time readout, press B three times to get normal setting mode.
2. Press D once; Minute flashing, Press C to advance.
3. Press D once: Hour flashing, Press C to Advance (A on display = AM, P = PM)
4. Press D once: Date flashing. press C to advance.
5. Press D once: Month flashing, press C to advance.
6. Press D once: Day of Week flashing, press C to advance.
7, Press B once: Setting completes - returns to normal time readout.
Alarm Setting Times:
1. In noraml time readout press B twice, Alarm Time hour flashing, Press C to advance.
2. Press D once: Alarm Time minute flashing, Press C to advance.
3. Press B once:Setting Completed, returns to normal time readout.
Alarm Function
1. In normal time readout, arm alarm by pressing C and D simultaneously. Alarm signal will appear.
2. In normal time readout disarm alram by pressing C and D simultaneously. Alarm signal will disappear.
The alarm will stop itself after 1 minute or can be silenced by pressing D or press C with snooze feature - will re-alarm in 5 minutes for the next hour.
Chime:
1. In normal time readout, chime activated by pressing D and B simultaneously. All day flag appears.
2. In normal time readout, inactivate chime by pressing D and B simultaneously. All day flags disappears.
Chronograph:
1. In normal time readout, press B once to get into 'Chrono" mode. Pressing C will start the counting.
Two Options for "Chrono" mose:
a. Durning coutning, pressing C will stop count and then press D to reset the mark.
-Or-
b. During counting, pressing D will enter teh watch into laptime mode, meaning 1 portion of the count is registered on the display while the counting contiues until completed by pressing C, then D twice.
Apr 08, 2009 | Watches
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Air Conditioner for Benz 1998 E320
Check system for codes;
Displaying & Reading Trouble Codes (DTC Memory)
Air Conditioning (A/C)
Models 208 as of MY 1998
Diagnostic trouble Code Memory [15]
Note:
  • The A/C pushbutton control module (N22) has DTC memory and data output. The diagnostic trouble codes and data are displayed via the temperature display window. The stored DTC's will remain in memory even with the vehicle battery disconnected.
  • The DTC memory differentiates between current and intermittent faults.
  • Numerous DTC's can also be read with the Hand-Held Tester (HHT).
Preparations for DTC Readout
  1. Review 11, 12, 13, 14, 15, 21, 22, 31, 31, 41
  2. Ignition: ON
  3. Temperature selector: left: "HI"; right: "LO"
  4. Ignition: OFF
  5. Ignition: ON
  6. Within 20 seconds press REST and EC simultaneously for more than 5 seconds.
  7. The LED in Recirculated Air flashes and the display shows "d1A".
  8. Press AUTO repeatedly until all DTC's are displayed. Record each DTC as it is displayed.
  9. Each fault (short circuit, open circuit) is assigned a DTC. Thus in the left display: "E1" appears, and the right display indicates the DTC. The current faults (refer to table) are displayed first, next, the intermittant failures (e.g. 45 °5) are displayed in the display window next to the FAN symbol. By pressing the right AUTO the next DTC is displayed.
  10. To erase: Can only be performed after all faults have been readout. Press left AUTO and right AUTO buttons simultaneously for more than 2 seconds and the display shows: left: "d" and right: "FF". To cancel erase: By pressing the left AUTO button, the current faults will appear again.
  11. Select a base temperature setting.
  12. Turn ignition OFF, to end test.
Note: Due to instrument cluster (IC) series interface, DTC's may be stored in IC memory, therefore readout and erase DTC's from IC memory.
133090425133090426
Aug 20, 2008 | 1998 Mercedes-Benz E-Class
Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Jan 10, 2008 | Frigidaire AEQ7000ES Dryer
Hobart AM15VL-2 Ventless door type dishwasher Logo
19 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
