Question about Tag Heuer 2000 Exclusive Qtz Chrono CN1112.BA0337 Wrist Watch
Timer not reseting to zero - Tag Heuer 2000 Exclusive Qtz Chrono CN1112.BA0337 Wrist Watch
How do i change the time on the three small dials
Hello Garrett,
"Three small dials"... My guess is that we are talking
a chronometer... (stopwatch)... "ZERO Process".
Not only are the three sub-dials usually settable... but also the sweep second hand.
Trouble: After resetting the watch... the hands go back to the same position...
Solution: You want to "ZERO" your dials... one by one.
These watches typically need to have the stem out to the third position... then press the top "start" timer button... observe ONE of your dials is moving. As it approaches the desired number release the button and step it into position with single button pushes.
Go to the bottom "stop" button... Repeat the process!
Push the stem in to the middle "set" position...
Repeat the process!
Again... press the top "start" timer button... zero
and finally press the top "stop" timer button... and zero.
Set the time and date... push that stem back into the home position... and record 35 seconds on your watch... stop and reset...
If everything does not come back exactly to ZERO...
Then that is called an iterative process (do it again).
Fine tune it!
Good Job.
(comment me back if I didn't hit the spot)
Horology Wikipedia the free encyclopedia
Feb 10, 2016 | Watches
How to reset Festina back to zero
Pull out the crown, push the chronograph start button. You will see that the hand moves one second. once it is back to zero push back the crown. Depending on your model you might need to pull out the crown with one click for the chronograph timers and another click for the second hand.
Jul 01, 2014 | Festina Watches
Reset fossil mens es3380
Google (fossil)(ES3380)(manual) without parens for instructions.
Feb 16, 2014 | Fossil ES Watches
I just recieved my Movado 800 series watch today and the large chronograph timer hand won't reset to zero (top of dial @ 12 o'clock) when I press the zero button. It resets to 56 minute position....
you do not need to return, as this is re-settable. Pull out crown to the first position (date setting) and then toggle with upper push button. If upper button do not do the job, try the bottom one. When you reach 12, then push the crown back in. Start the chrono, stop it and check if it returns to 12.
May 18, 2011 | Movado® Series 800 Blue Chronograph Watch...
Stop watch will not reset to zero
pull the crown full out reset all hands set time set alarm or second time if you wish and press the crown back.
Dec 01, 2009 | Seiko Coutura Chronograph Watch
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Resetting stopwatch dials - Armani AR5331
Pull the crown to first position (where you set the date) then adjust the dials with buttons.
uhrmacher
Jan 10, 2008 | Giorgio Armani Classic AR5326 Wrist Watch
Tag Timer Resets to Wrong Time
Unscrew the crown and press the lower button, this should advance the minute counting hand one press ata time. Pull ot the crown a further stop to advance the seconds hand and again to advance the tenths counter.
Nov 04, 2007 | Tag Heuer Watches
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
Open Questions:
Tag Heuer 2000 Exclusive Qtz Chrono CN1112.BA0337 Wrist Watch Logo
13 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
