Question about Hobart D300 Stand Mixer
Hobart mixer making a clicking noise
Clicking noise
  • 68 Answers
SOURCE: Noisy Hobart N50 Mixer
First, there is a double set screw (one on top of the other - if they are both there) towards the back of the planetary.
Remove the first screw, it should have a normal tip, not pointy. Run the mixer in 1st and adjust the screw, first out then in. Then repeat in 3rd. You should clearly hear a difference.
If not, you probably need to repack the grease in the transmission. The proper grease is called "Darina II". It's expensive ~ $35 per mixer.
Posted on Apr 25, 2008
bigg t
  • 640 Answers
SOURCE: hobart 20 quart mixer
Hi im a service tech for hobart.I cant give service manuals out because i could lose my job but i can step you thru your problem with the mixer,let me know.
Posted on Aug 24, 2008
  • 20 Answers
SOURCE: Hobart L800 making noise
If you can send me your email address i can send you a parts catalog for your L800 They have no way to send a link here is my email address
onesharpstore@comcast.net
Posted on Jul 07, 2009
  • 81 Answers
SOURCE: Hobart D300 Mixer, Will not shift from 2nd to 1st
Hobart mixers are NOT designed to change gears while operating. The Hobart planetary gears are like the transmission in your car but, without the clutch. Everytime you change gears while unit is running you are tearing up the brass spacers, gears & seals. Time to call a QUALIFIED service tech to come out & sell you another planetary or rebuild your old one, about $2K, Buy a Varimixer if you want to change gears while unit is running, they use belts. Another planetary premature failur cause, over loading the bowl. Batters & icings- 75% bowl capacity, Dough 65% bowl capacity.
Posted on Jul 25, 2009
Cuisinexpert
  • 61 Answers
SOURCE: oil leaking from hobart d300 mixer
DEFINITELY contact the manufacturer (Hobart) on that one. Sounds like you're having some sort of an internal problem with it (something might be cracked), and in this situation, the best way to go is to contact the manufacturer rather than try to repair it yourself. If you're still under warranty, and you try to open the machine up to fix it yourself, you could wind up VOIDING the warranty, and if you're out of warranty, most repair places won't touch a machine that you've messed with already--too much of a liability.
Just give Hobart a call, and they should be able to help you (if you're in warranty, sometimes even for free!). Their phone number (according to their website, www.hobartcorp.com ) is 1-888-4HOBART (1-888-446-2278)
Good luck! :)
Posted on Aug 27, 2009
When I turn the machine on it makes a buzzing noise, (not loud but it might be like an alarm).
If the mixer is still running and making the buzzing noise one of the electrical contactors is making the noise and should be replaced.
If the mixer is not running and just making a buzzing noise it can be because off single phasing, check the incoming supply to the mixer and make shore you get the right voltage to the motor (test on motor connection terminals)if the voltage to the motor is right the motor might be faulty
Jul 29, 2015 | Hobart 60 Qt. Mixer
Hobart h600t . Makes noise on speed 3 and trips on overload. I checked start cap all electrical components all look normal.
I'm having the same problem cap and all look good but still the motor won't run and the the overload trips the breaker
Jan 13, 2014 | Hobart H600 Stand Mixer
How do i put back togeather Hobart 300-d mixer
http://www.hobartservice.com/Parts/
Go to this page and click on Hobart Smartparts System. Select Food Machines, Floor Mixers, D300 and you will eventually find parts breakdowns.
Feb 25, 2010 | Hobart D300 Stand Mixer
Hobart mixer making grinding noise
the noise is not a good sign. would rec. taking apart trans. and investigate gears,shafts, before futher damage takes place
Nov 30, 2009 | Hobart D340-6009 Mixer
Hi i have hobart mixer 220v and it start to make loud noise when the dough get harder .thank you
What is the model and ml # on the data plate?I'm a hobart tech and repair these mixers often,let me know.
Nov 20, 2009 | Hobart A200 Stand Mixer
THE MOTOR MAKES LOTS OF KLUK/KLUK NOISE.
It sounds like your motor is okay if it is trying to drive the unit, it may be that one of the gears inside the unit have broken or chipped. this can cause a lot of damage quickly and should be disassembled right away and cleaned. another source of this noise could be that your motor fan blade which is attached to the motor is hitting the armature field winding. you could easily detect this if you have the back panel off and turn your mixer on This motor is not a Hobart motor simply because its made by Whirlpool and Hobarts motors for smaller mixers are mostly no longer available as where the whirlpool motor is still available.hope this helps
Thanks
Sep 10, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Feb 20, 2009 | Hobart N50 Stand Mixer
Requesting instruction and operation manual for hobart Mixer
Nelson. Go to www,hobartservice.com and register. Once you are authorised to log on find the Product Group choices, select Food Machines and then select Mixers. On the left side of the page click on discontinued products and then look for your mixer. Make sure that the file you choose matches your ML# on your mixer's info plate. You'll find everything that you need there, including parts lists and use directions.
If you find this solution helpful please rate it. Good luck. ricardok45
Jan 05, 2009 | Hobart A200 Stand Mixer
Clicking noises. Mixer doesn't have enough power to mix.
You have a drive gear that runs off the motor gear. That gear has a problem. It has either broke away from the weld or you have a pin or key sheared.
Oct 28, 2008 | Hobart N50 Stand Mixer
Hobart D300 Stand Mixer Logo
64 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
