Question about LG 37LH3000 37" HDTV LCD TV
Colour has gone weird - LG 37LH3000 37" HDTV LCD TV
My Compaq Presario fall down and its screen gone colourless its not show anything normal when boot windows 7 it's colour goes red colour after booting showing very low quality colour....what I
Check the GPU and motherboard are OK by plugging an external monitor into the VGA socket and then booting. If the external screen is OK, replace the LCD screen.
Oct 09, 2014 | Computers & Internet
The colour of my tv just goes heywire randomly but the settings are unchanged. what can i do about it?
With Sony a problem that can arise is the Y board goes faulty and will change saturation of colour etc, It may intime go blank in one area or display other weird problems, It is an internal issue and you will have to get it professionally repaired.
Mar 29, 2011 | Sony KLV32V400 32 in. TV
I have an Acer AL1916 monitor and I turned it on like normal yesterday and it has now got a weird green tint all over.. I've gone into the settings of the monitor and played with the red, blue and green...
sounds like a cable problem, can you find another VGA cable to try, look at the cable ends carefully for bent pins.(they are easy to bend by accident) wiggle the blue VGA connector while its on, try both ends, I think when you push the button your pushing on the cable momentarily which causes the monitor to function properly, likely the connector on the back of the monitor. if this helps, please use the thumbs up for feedback. cheers
Aug 26, 2010 | Acer AL1916B 19" LCD Monitor
Panasonic tx-32lx60a colour gone all red/dark
Ur Main Tuner signal board is dead.Replaced this board will fix this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Mar 13, 2010 | Sony KLV-S32A10 32 in. HD-Ready LCD...
My hdtv turns green when i try to play my xbox 360 why?
Are you using component video?
If the Green (Y) provides Luminance, Red (Pr) and Blue (Pb) are the colour bands. If only the Blus is pluged in then you will have a blue-green screen. If you have the Blue and Red switched then you will have weird colour aswell.
If you are using HDMI then unplug and re-plug the connectors.
Jan 02, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
My Colour There A Second Gone The Next
The color cartridges are defective as refilling sometimes damage the cartridges and refilling can be may 3 or 4 times, try using lexmark cartridge, it should fix the issue
Mar 21, 2008 | Lexmark X6170 All-In-One InkJet Printer
Bright screen with very low contrast
I fixed it myself, it seems that the monitor have some problems remembering it's settings and sometimes it automatically set its settings to crazy values that are out of the range that we are allowed to input. For my case, the setting that was crazy was the gamma setting since it was set so high. I wasn't able to bring it back to a normal setting so I found a way to do it by resetting the monitor. So to reset these display settings such as colour, contrast, brightness and gama, you need to turn on the monitor and unplug the monitor without turning it off and plug it back in again. It will automatically power on and the correct default settings will be present.
This forum isn't very helpful is it?
Dec 09, 2007 | LG Flatron L1811S 18.1" LCD Monitor
Colour gone wrong on sony lcd tv
Please post this under the appropriate model under Sony TVs. It got posted under microwave ovens. Good luck!
Dec 04, 2007 | Microwave Ovens
LG 37LH3000 37" HDTV LCD TV Logo
177 people viewed this question
