Question about Intel Core 2 Duo E7500 Processor 293 GHz
Pci simple communications driver - Intel Core 2 Duo E7500 Processor 293 GHz
map9966
  • 2351 Answers
SOURCE: pci simple communications controller
It's there but you did not vote.........
Thank You
Posted on Apr 08, 2008
adnanbhatti
  • 1188 Answers
SOURCE: I need drivers for PCI Simple Communications
These driver are installed with the chipset's driver.
Click here to visit the page where you can download the chipset driver (for XP).
Select your OS and select Chipset: ATI Radeon Xpress 200 from the list.
Other drivers are also available.
Hopefully this will solve your problem.
Thank you.
Posted on Nov 05, 2009
  • 235 Answers
SOURCE: PCI Simple communication controller driver is not
then windows 7 has no driver for the device download the latest device driver that support win 7 operating system, if there is no device driver for win 7 then you should have to wait until the manufacturer releases a driver for win 7
Posted on Nov 20, 2009
Testimonial: "Thank you"
cspatiala
  • 54 Answers
SOURCE: PCI simple communication controller not installed.
First u have to install Microsoft Universal Audio Architecture .... that is UAA. then check in the device manager that is under system devices "pci bus" has excl. sign (i.e. ! ). Delete the pci bus device with exlc. sign. and press the button in the upper side of this window "scan for new hardware" it will automatically install the pci bus device and ur sound comes...
Posted on Jun 29, 2010
computus
  • 487 Answers
SOURCE: PCI Simple Communications controller
Hi, yes you need the right driver, do a google search for the driver, there are many sights where it will be free.
Posted on Jul 05, 2010
Pci simple communication controller
PCI Simple Communication Controller is a 56k PCI Modem, to know which exactly you have, use Unknown Device Identifier ( Download Here for free ), that will tell your the Model and Manufacturer, then Google for the drivers.
Sep 27, 2013 | Western Digital Computers & Internet
Hp nc6400 PCI Simple communication controller required please.....also unknown device driver???
The PCI simple communication controller is probably bluetooth or modem. Also install the Texas Instruments Media Card Reader driver. All the drivers for this model are (CLICK HERE)
Apr 18, 2011 | Computers & Internet
Drivers for pci simple communication controller for toshiba
Check out the Toshiba Support Site.
Select your Toshiba model to download the require drivers.
PCI simple communication controller - ie the 56K internal modem drivers.
Hope it helps.
Mar 23, 2011 | Computers & Internet
Description: PCI Simple Communications
Hello sainz_pm,
This Driver Detective site might be able to help:
http://www.driver-fix.com/updatedrivers.php?t=Pci%20Communication%20Controller%20Download
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jan 28, 2010 | Gateway BCM94306MP Network Adapter
Motherboard Simple PCI Communications Driver Code 28 for modem
Hello, Mike.
In case you still need this:
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware.
Hope this helps.
Mar 29, 2009 | Gigabyte GA-7VA Motherboard
Need a ethernet controller & pci simple communications controller
Try this link: http://partner.atheros.com/Drivers.aspx
You might be able to find something here.
Mar 14, 2009 | Biostar 945GC-M7 TE Motherboard - v6.0,...
PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Dec 07, 2007 | Gigabyte GA-7VT600 1394 Motherboard
Intel Core 2 Duo E7500 Processor 293 GHz Logo
62 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
