Question about Whale Universal Electric Pressure Pumps UF1215 3 GPM
Low pressure Loss of pressure
What causes low blood pressure?
Some of the causes of low blood pressure are:
1. Genes- Low blood pressure can be genetic.
2. Aging- Aging can also cause low blood pressure, as the age increases blood pressure can either increase or decrease.
3. Medication- Some types of medication is also responsible for low blood pressure.
4. Dehydration- Low blood pressure can also occur due to fluid loss in our body.
Oct 19, 2016 | Health & Beauty
Loss of pressure
You will probably find the loss of pressure is bad pump seals maybe even worn pump pistons. The problem is that it cost as much to repair these pump as it does to replace them with a new warrantied unit most times. Larger commerical pumps are still fairly reasonable to repair but the replacement costs are coming down too.
Jan 15, 2015 | Garden
Peugeot 308 low oil pressure and loss some power
Low oil pressure starts from oil pump sounds like its blocked either in the pump filter or galleries in the enging. I would first call the dealer and check what filter system is on the pump which may require removal of the sump to replace or clean.
I would certainly not use a car with this problem as it could well cause engine failure. Try a good quality flush first and run the car for 20 minutes minimum on tick over. Remove and put a good quality oil in and do another oil change again if required a month later with a flush to make sure the gunge is out.
If this does not help do an oil pressure test and see what it comes out at checking the manufacturers recommended pressures. If you have changed the oil, pump filters and done a second oil change and still get low pressure then you may well have a faulty pump.
I would also check the oil pressure switch to make sure it s not giving a false reading. The loss of power sounds like Turbo failure and again dirty oil to the Turbo oil feed pipes could be restricitng flow, hence why regular flushing oil and filter change is important.
I would get the Turbo checked out same time as on this model it could well be a Turbo and engine change if its gone that far due to the metal particles contaminating the engine.
Jul 11, 2014 | 2010 Peugeot 308 HDi
Loss of front brake pressure well moving
Some how your reinterducing air into the system but not sure where.
Oct 22, 2012 | 2001 Harley Davidson FXDL Dyna Low Rider
I am on a well system (submersible pump) and low pressure issues happened this week. Checked the pressure on Smart Water system and it was 45psi. I replaced the paper filter with a carbon filter cleaned...
This could be caused by several different issues. A faulty switch on the well, bad well tank, bad check valve. If you have a water softener, bypass it to see if pressure loss is through it. That carbon filter will cause even more pressure loss. Turn a cold water faucet on, let the well cycle several times and observe the cut-in and cut-out pressure. Typical well pressure pressure will be 40-60psi.
RJ
Jun 26, 2010 | General Electric GE SmartWater Household...
WARNING MESSAGE sTOP: OIL PRESSURE ...wHAT IS
Check your oil, it may be low if not the oil pressure needs checked. The sending switch could be bad or you have low oil pressure. If you have low oil pressure have it fixed ASAP. The loss of oil pressure can cause severe engine damage.
Sep 26, 2009 | 2007 Volkswagen Passat Sedan
Loss of oil pressure
Loss of oil pressure can be any of the following: defective oil gauge, defective oil gauge sending unit, defective oil pump, worn rod and main bearings, plugged oil pickup screen, insufficient oil in engine hole in oil pickup tube, etc. Many issues can cause low oil pressure. Take it to a mechanic for proper diagnosis.
Sep 24, 2009 | 2005 Dodge Ram 1500
Loud ticking noise
Ticking is generally associated with a valvetrain problem but may be caused by low oil level or pressure. Noise is in the upper half of the engine. Knocking is from low oil pressure and is caused by worn bearings causing pressure loss. Knocking is the worse of both conditions (means overhaul or engine replacement.) Ticking needs to be checked for it's cause...if cause is low oil pressure, remember...oil pumps don't cause low oil pressure, pressure will lost if bearings are worn or pump inlet screen is plugged with carbon.
Jul 18, 2009 | 1999 Jeep Cherokee
Ac not blowing cold
Check for a loss of freon, if it is low, check for leaks. If the system is not pressureized (ie: low on freon) the computer will not let the compressor or cooling fan activate. If it is not low on pressure, then systematically check each part of the system for operation.
Jul 13, 2009 | 2005 Dodge Grand Caravan
Low oil pressure light keeps coming on
check if there is too much oil. over filling the engine with oil causes the oil to foam which leads to loss of oil pressure. it could also be the oil pressure sensor
Jan 09, 2009 | 2005 Buick Terraza
Whale Universal Electric Pressure Pumps UF1215 3 GPM Logo
21 people viewed this question
Top Whale Plumbing Experts
Donni Steen
Tom Chichester
Are you a Whale Plumbing Expert? Answer questions, earn points and help others
