Question about iRiver Story
Screen display not clear - iRiver Story
My pioneer 2700 BS has too many devices on it and the memory is full I've been told I have to shorted out reset somehow from the back how do I do that
Displaying the “Bluetooth”
screen
1 Press option key.
2 Touch , and then . The “Bluetooth” screen appears.
Clearing the Bluetooth memory
This setting is available only when you stop your vehicle in a
safe place and apply the parking brake.
CAUTION
Never turn this product off while the Bluetooth memory is
being cleared.
1 Display the “Bluetooth” screen. ? Displaying the “Bluetooth” screen on page 12
2 Touch [Bluetooth Memory Clear].
3 Touch [Clear].
The confirmation screen appears.
Sep 09, 2015 | Cell Phones
Mem cleared Changed out the batteries and received a messege mem cleared and nothing will work.
Follow this steps to resolve this problem:
1. Press ON to turn calcilator on
2. Press 2nd and then press + key button. TI- 81 displays RESET menu
3. Press 2 to select the RESET, the second item in the RESET menu. The display shows the message Mem cleared. Press CLEAR to clear the screen
If you cannot see anything on the screen, you may need to adjust the graphing TI- 81 calculator contrast:
-To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark
- To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light
Aug 22, 2012 | Texas Instruments TI-81 Calculator
Erore code
You can try to clear it with " press the yellow clear botton, then the numbers 1 - 0 -7 , then press and hold the red clear stop botton, till the screen changes... Then turn the MAIN POWER switch OFF & then back ON. If that will not clear the code, then let us know what the error code is , that is displayed on the display screen.... Good Luck
May 24, 2012 | Ricoh Aficio 450 Copier
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
The Screen displays random lines and numbers.
Clear the screen. Reset RAM :[2nd][MEM][7:Reset][All ram] [2:Yes] Ram cleared is displayed. [Clear] the screen.
Hope it helps.
Sep 19, 2009 | Texas Instruments Office Equipment &...
How do i clear the code on the display screen?
The only way to clear it is to replace the fuser rollers or the thermistor.  Clear code isn't available for override.
Sep 10, 2008 | Office Equipment & Supplies
How to clear all information from screen
screen has (m3)and (m1) in upper left corner, have not been able to totally clear screen.
Apr 10, 2007 | Texas Instruments TI-30XA Calculator
iRiver Story Logo
Top iRiver Computers & Internet Experts
David Payne
David Payne
Are you an iRiver Computer and Internet Expert? Answer questions, earn points and help others
