Question about Sewing Machines
Forward reverse switch not working - Sewing Machines
Just bought this used machine, it worked fine in tryouts but after transit the stitch width switch is not working. It automatically goes to the reverse position and will not dial down to any widths.
the forward /reverse control sets the stitch length(width) the closer to neutral the smaller the stitch
full forward or full reverse is max stitch length
Jan 31, 2016 | Sewing Machines
Haven't used machine for a few years. Reverse won't work, what should I be looking for?
check the forward reverse lever is in the forward position
have a service done on ti as the oil will be like gum on certain parts.
May 21, 2015 | Sewing Machines
How do I correct singer 1507 which suddenly started sewing continuously in reverse and not forward
It could be a thread got caught on the reverse switch and pulled it into reverse while sewing.
Mar 29, 2015 | Singer Sewing Machines
Singer 9015
check feed dogs are clean with no build up of lint and have sharp points on teeth
Feb 19, 2014 | Singer Sewing Machines
My sewing machine now only sews in reverse
Maybe there's a problem with the reverse and forward button.
For sewing machine reviews
Sep 26, 2012 | Sewing Machines
Sews backwards..when I press the reverse button it sews forwards
Sounds like you have the timing precisely reversed. Time to try again.
Sep 10, 2012 | Singer CE-100 Futura Computerized Sewing...
I can't find reverse on my necchi 536fb. I inhereted the machine it's pretty old but works great. Sewing would be much easier if i had a forward/reverse button. Thx
Hi! Sewing is so much easier with a forward/reverse button! :-) I have a Necchi 536 fb also. Here's a picture of mine: efebd8b.jpg
The knob on the lower right controls the stitch length and forward/reverse. Push the center part in to get reverse and release it to go forward again.
You really need a manual for your machine--my Miss Sophia came from a pawn shop so I ordered one from relics.com (http://pages.sewing-machine-manuals.com/173/PictPage/1923115740.html) for $17.00.
I love my Necchi--you can read about her at www.robbiesews.blogspot.com if you like.
Happy Sewing!
Robbie
Apr 22, 2010 | Necchi 3101 Mechanical Sewing Machine
Janome New Home mx3123 reverse button not working
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work!
Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
Apr 05, 2010 | New Home MX-3123 Computerized Sewing...
Sewing Machines Logo
13 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
