Question about Cartier Santos 100 Chronograph Black Dial Silver Bezel Black Leather Band Watch
Take of bezal steel
Can I take out the screws and remove bezel to polish
Bulova stailess steel 16 Diamond Bezel Chronograph Watch discolored on raised part of bezel like the metal is turning brown?
You can try a polishing cloth to see if this removes the discoloration, or very gently brush it with a toothbrush and mild soap ( very little water) if this does not help you will need to send the watch back to Bulova to their service center. 1-800-228-5682 is the Bulova service center phone number, call them for further instructions. Sometimes the discoloration is caused by certain chemicals found in lotions, soaps and cleaners. Hope this helps! thank you!
Sep 21, 2011 | Bulova 98R107 Diamond Collection...
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
Hi, I have a swiss legend Commander watch with a rubber band. It is white and really needs cleaning. Also, it is coated with a rose-gold plated material on the bezel. Any ideas on how I can clean...
mcdevito75 here, For the Bezel (top part of the watch) the best bet is to use a jewelers polishing cloth available at any jewelery shop. For the white rubber strap, a few drops of water with a light hand, or dish washing soap on a wet paper towel or cloth should do very well.
Sep 20, 2010 | Watches
The crystal is scratched, can I fix that myself?
Thanks for contacting FIxYa.
  • Use a jeweler's loupe to identify all scratches on the watch crystal. You do not have to remove the watch crystal from the watch.
  • Use a polishing cloth to remove dirt, grit, lint or any debris on the watch crystal. Squeeze a small amount of standard toothpaste with abrasive properties onto the watch crystal. Gently brush the toothpaste into the crystal for five minutes. Wipe clean the watch crystal. and repeat another five minutes.
  • Use the jeweler's loupe to inspect your progress. Repeat application if necessary. Apply Brasso polish once the watch crystal is wiped clean. This will polish the crystal to a clear, bright shine.
  • Apply Autosol or Polywatch to the watch crystal in the same manner as toothpaste if you prefer to use a product specifically designed for watch crystals. These products will provide the same results as toothpaste. You may also apply Cerium Oxide, a glass scratch remover used specifically in the window manufacturing industry.
  • Apply a small amount of 3-micron diamond paste using your finger or a Kleenex if removing scratches from a sapphire crystal. Rub the paste in for about five minutes. Remove paste with cloth. Buff the sapphire crystal with one-quarter micron buffing diamond paste for finishing.
  • Use a toothpick to remove excess polish and gunk that may accumulate between the crystal and the bezel that secures the crystal in place. Gently work the toothpick around the diameter of the bezel. Wipe the bezel clean with a cloth.
  • Buff the watch crystal with a polishing cloth.
  • OR..take to a local jeweler/watchmaker.
    Best regards. Jewel
    Sep 10, 2010 | Relic Watches
    TTI DIVER BEZAL
    GOTO
    http://www.watch-clock-makers.org/
    Hope this tip helps.
    r/ David
    http://antiqueclock.clockstop.com/
    Mar 09, 2010 | ORIS TT1 Divers Der Meistertaucher...
    Can I remove the back of my bertolucci watch myself and replace the battery?
    The method of removing the back of a watch varies from make to make. Often the question is how can I get it back on!
    Unless the watch has an obvious battery cover (a small round cap which can be screwed off), it is much safer to take it to a watch shop to replace it for you.
    They have all the tools, a stock of batteries and will will do the job a few minutes.
    Jan 24, 2010 | Bertolucci Vir Mini Steel and 18k Gold...
    Navitimer 2 rotating bezel has gone very stiff to turn how can i free it up?
    This depends on what exactly is causing the problem. If the bezel is bent from a sharp blow it would have to be replaced. It could be there is dirt under the bezel. To clean this there are two possibilities. If your bezel has screws around the outer edge they will need to be loosened or unscrewed to remove the bezel. These are small screws so be careful you don't loose them. The bezel should then lift off. Clean it with mild soap and water and dry it well. Be careful of the bezel spring. it is easy to break the little fingers. Wipe off any dirt on the case and set the bezel spring and bezel back on the case. Use Red locktite on the screws and reinstall them. If you have markers on the bezel that come off when you remove the screws be sure you keep track of them and the screws that went with them.
    If your bezel does not have screws but fake ones then the bezel should be removed by a qualified watchmaker because the bezel could be bent or damaged when removed.
    Hope this helps.
    Ken
    Yellowstone Watch Inc.
    Oct 01, 2009 | Watches
    Appraise Bulova N2 10K R.G.P. Bezel Stainless steel back
    I have seen this watch sale in mint condition for as much as $40 but this is an inexpensive piece.
    Sep 14, 2009 | Watches
    Need new bezel
    Try parsecent.com, you can get a replacement bezel there...
    and you are right, you are basically buying a new watch as this model is made of plastic and cannot be 'polished'. Refurbishing it means that it will look new and everything on the outside would have to be replaced...good luck :)
    Aug 07, 2009 | Luminox Navy SEAL Dive 3901 Wrist Watch
    Ebel Classic Wave fitting a new crown
    i have changed the battery on my and my wifes ebel classic wave watch,,
    step 1 ...remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
    step 2 ...remove all 5 gold bezel screws
    step 3... be careful,, the bezel/crystal will pry off easy
    step 4... be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
    step 5.. small screwdriver and remove/replace battery
    step 6... reinstall watch guts/bezel and gold screws
    step 7... push crown back into watch
    step 8... take wife and kids to dinner ,,you just saved three hunderd bucks
    if have done it many times ,, you can do it !!!!
    Dec 10, 2006 | Ebel Classic Wave 9090F249725 Wrist Watch
    Cartier Santos 100 Chronograph Black Dial Silver Bezel Black Leather Band Watch Logo
    11 people viewed this question
    Top Cartier Watches Experts
    k24674
    john h
    Are you a Cartier Watch Expert? Answer questions, earn points and help others
