Question about Bosch Hammering
Solid red light
Have changed brushes and put new speed control in aswell
  • Bosch Master
  • 1,815 Answers
1 sliding contact of the 4 pieces thats on the electricfield (stator) of the motor is broken.
Posted on Feb 26, 2016
How to trouble shoot a brush warning light
What color light are you referring to? If it is one of the green lights that is normal for the up and down adjustments. If it is the red one that is another issue. If it is the red one, what does it do while it is on? Does it flash or is it on solid?
Jun 17, 2014 | Windsor SR12 Sensor Bagged Upright Vacuum
11316 evs solid red light
Could be it is drawing too much amperage - that is what this control detects.
How long has it been since it was torn down & serviced - that is a possibility.
The other is more costly, it is possible you have a bad armature causing this as well. Remove the bottom cover where you replaced the brushes and examine the armature - look for burnt / raised segments or burnt windings.
Let me know what you find.
Apr 13, 2014 | Bosch Hammering
Reset pcb bosch classixx 1200 express
There is no reset as such, if the motor shorted when the motor brushes went there is a good chance that it blew the motor tracking or relay on the board. Sometime this is indicated by F20 or F21. Unfortunately this will be a new board. You could try to run a motor test as follows:
Hold in the start button while turning the dial one click to the left (30 easycare) wait until the display shows 888 or two indicators light up next to dial.
Release start and turn dial to 60 cotton (WITHOUT GOING THRO THE OFF).
Press start
This should start a motor test
slow turn one way, slow turn the other, pump on then up to full spin.
(some machines will show the rpm on the display).
If this does not work, you probably need to change the module aswell.
Best of luck
Mar 20, 2013 | Bosch Classixx WFO 2866 Front Load Washer
Fan will not turn under it's own power, but turns freely by hand. Light bulbs light up very dimly. Light sockets show 120volts when the switch is turned on if all light bulbs are removed, but if a...
You probably have a wire nut connection that is just barely connected. Perhaps it's a connection between stranded wire and solid wire where only one of the strands is making contact with the solid wire.
Jan 09, 2011 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Solid red light
Have about a 30 second window to replace batteries before all codes are lost and when you put in the new batteries it goes into programing mode. Re-enter codes and try it again. Have the same remote and it has happened to me before.
Mar 12, 2010 | DISH Network IR Remote Control
I have a BOSCH 4000 table saw which spins very slow. I opened the motor took out the field to examine. When I tried to reassemble it, I faced some problem. There are two wires from field, one connects to...
There is 4 wires from the field, 2 reds a white and a black. the reds have spade connectors on them, they go to the brush holders. The white goes to the white on the speed controler and the black goes to the black on the speed controller. There is one wire from the speed control that goes on to one of the brush leads, there is a small adapter that allows both wires to be connected. If the motor spins very slow then the field is faulty and needs replaced.
Hope this helps
Feb 11, 2010 | Bosch 4000 - 07 Electric Table Saws
2wire modem power light red
Its Due to AC adapter capacitors. Capators dry out after certain usage that cause unfiltered output of DC. Add about 2 or 3 pieces of 1000uF capacitor on DC way issue will be resolved. Or simple change the capacitors in AC adapter or change the AC adapter to new one.
Jun 10, 2009 | 2wire 2700HG-B Router (2700HGB)
Remote Control
Change the remote control batteries. Because of the motor construction, it needs to turn on in the highest speed setting. This is why it defaults to the high speed mode. Put new batteries in the remote and that ought to fix it.
Mar 04, 2008 | Hampton Bay 48670 Flemish Pewter Finish...
Hammering Logo
98 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
