Question about Dishwashers
Bosch she4ap cycle sounds like it is starting, but after a few minutes, the clean light comes on without the machine ever running the cycle
SOURCE: Dishwahser rinse cycle running for hours
I have a Bosch SHU5316 -- same symptoms -- turned out to be the control module (the thing with the lights & buttons on it). First replaced under parts warranty. The next time, I did it myself (you take part of the door apart). Not too bad to do, but the module cost about $100. Since this was the second time it happened, I bought a "lifetime" replacement warranty on the module ($10). Best ten bucks I ever spent. I am on my third module.
Posted on Jul 23, 2008
  • 7 Answers
SOURCE: Bosch SHU43
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door. Mine is a BOSCH 5316.
The draining problem may mean a clogged drain hose -- you have to check it all the way back to either the main drain or the garbage disposal (if you have one). This may be what forced off the impeller wheel.
  • 4 Answers
SOURCE: Dishwasher problem, Bosch
make sure u have jet dry in unit and put on higher number inside doors
Posted on Oct 03, 2008
whytfang
  • 170 Answers
SOURCE: Whirlpool Gold Dishwasher makes a very loud noise when running
Hi you probably have something in the sump drain assembly (this is a common problem with Nautilus DW's) there's a screen on the right side of the spray arm with 2 screws remove them and take screen off use your fingers to probe the cavity be careful it could be glass.
If it does not correct the problem
!.You may have an electric pump . and it could be pump without water . so i would say a bad pump....but since you say everything is draining well...then I doubt the later...HOWEVER...you did say it ran forever...which is absolutely typical of something in the sump...drain area...which will make the drain cycle run because it believes something to be in the drain.....there is also a check valve...that the drain hose attaches to...(it comes right off of the motor assembly) when you take the hose off there is a check valve that screws into the hose or the motor assembly...(it could have debris in the hose that is not being drained all the way out and it is finding it's way back to the check valve) ...shop-vac the drain line...or the valve is screwed into the motor assembly where the hose disconnects...and there may be something stuck in the valve...unscrew it and check that the valve is in good shape...and free of debris......reassemble...and run through cycle....if you need any of these parts...or any specific instructions on replacement of these parts...here is a great site...Quality for less and quick delivery.
http://www.appliancepartspros.com
I hope this helps...I believe it will....Good luck and good day....thank you for your rating my effort....The Fang.
Posted on Apr 07, 2009
SOURCE: ''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Posted on Jun 16, 2009
Bosch Dishwasher wont run full cycle. Stops/Beeps and says CLEAN.
Hello there,
Could you please supply the full model # off your appliance?
Mar 12, 2014 | Bosch SHX4AP05UC Dishwasher
Cycle stops after 2-3 minutes
Sounds like the fill solenoid. It is likely that the machine is stopping after a few minutes after not seeing the water level raise in the wash tank. When you say fiddle underside of the door, was this with any panels off? If so, maybe a loose wire on the pub that sends power to the solenoid.
Oct 30, 2017 | Bosch Dishwashers
Samsung b1113j washer
Kelly, try this. Let the machine auto clean. Then run a full cycle without a load at Normal setting. good luck
Dec 30, 2013 | Washing Machines
Bosch Exxcel 1200 (WF02464GB) not heating
The machine only heats when it takes the detergent, all three rinses are cold only and this time of year the load will be very cold when it comes out. If the machine is not taking extra time (like a hour or two) longer to run a cycle, then there is no problem.
If you want to check the heater is functioning, try this
1 Put the dial to off
2 press and hole the start button whilst turning the dial one click to left (easycare 30)
3 release start and either two of the progression lights are lit or if it has a diplay should show 8.88 or 0.00
4 turn dial to 90 cotton, take the the long way round ie not thro the off or you will have to start again
5 press start
6 drum will fill and the heater will come on, wait a few minutes and if the heater is working ok you will hear a noise like a kettle boiling.
The drum does not turn during the test to allow you to hear this without the movement of the drum obscuring the sound.
If it sounds ok, cool. put dial to off, wait a second then select drain to get rid of the water in the drum
All the best
Apr 08, 2013 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
Not washing
helen going by what you are saying i would say its the program cycle switch needs replacing,adrian
Jan 13, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Ran the dishwasher and the water didn't drain completely. Checked the drain line for clog - it was clear. Scooped out the remaining water (barely covered the flat wire mesh filter in bottonm of the...
Hello Ramona Doug,
Try disconnecting power from your dishwasher for a few minutes to clear the memory and then reapply power again. Start a wash cycle without dishes on the hottest water setting and after a few minutes.. pause the wash and add a few cups of white vinegar to the wash water.,. that will help break up deposits in the system.. See if that gets you going properly.
Regards
Oct 13, 2008 | Bosch Dishwashers
Bosch SHU43C installed in 2003
My Bosch SHU43C had the same exact problem. I found the below solution on this site. Perhaps you already seen it.
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Aug 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43C
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Sounds like water....dx doesnt work
2H means the machine is taking longer than 99 minutes to run a cycle. Start the cycle and wait 5 minutes, then open the door. If water doesn't look like it is spraying out the wash arms or slowly coming out the wash arms, then check to make sure the filter at the bottom is clean. If clean, then sounds like your circulation pump isn't running or impeller has came apart.
Dec 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
19 people viewed this question
Top Dishwashers Experts
