Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I JUST GOT A D52W20 HD TV.I SCREWED THE CABLE CONNECTION TO THE ANTENA INPUT. THE ONLY STATIONS I GET ARE LOCAL CHANNELS BUT NO CABLE CHANNELS. WHAT DO I HAVE TO SET ON THE TV OR WHAT DO I HAVE TO PRESS ON THE REMOTE TO DO THIS CORRECTLY ?
    Scholar:
  • 59 Answers
Before you bought your new TV, was the cable connected to an older TV, and was it working?
When you say you screwed the cable connection to the antenna input, did the cable come directly from the wall, or did it go through a cable box first. If it came through the wall without a cable box, it's possible it's not an active cable account, and you're only getting over the air signals for your local channels (and nothing through the cable). Or, your cable signal might have been analog only, and with the transition this week to digital TV, maybe you're no longer getting the channels broadcast properly.
If you are a cable subscriber, then this problem should be reported to the cable company, and they can do further testing to see what's wrong with your signal.
Posted on Jun 18, 2009
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Good Afternoon, I have no cable where i live now, but i have a analog converter box, how do i install it to my tv to get local channels?
you install the cable wire into the box or antena into the box then the cable or rca cables into the tv. set the tv input to the right input (usually channel 2 or 3 for a cable) or input one for the rca cables then you need to hit the scan option on your converter box to scan for the channels and the tv to scan for the channels. please let me know if this works
Mar 14, 2011 | Televison & Video
No getting digital reception
With this model tv, if you are using the coaxial connection on the tv to receive local stations you will not get any. The tv is digital, but not the tv tuner. As of June or July 2009 that tv will no longer receive analog channels from local stations as they are now all digital. You need a digital cable converter box to convert the signals to analog. *** This is if only if you are using the coaxial input.***
Mar 08, 2010 | Protron PLTV-32 Television
Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause...
U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
Jan 10, 2010 | RCA HD52W58 52" TV
Im trying to comnect this tv so i can get the local channels only- no cable. the tv comes on but the connection is not there. thank you
Go to the menu pick air,don't pick cable u get free air channels,just use a regular roof antena or a digital antena.
Dec 10, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Dont know how to get cable channels , i just get local channels.
Hello.
It sounds like you need to change a setting before running the auto or channel scan. On the same menu screen that has the option for running the channel scan, you should see a setting that has next to it the word "AIR" or "ANTENNA". If this isn't changed to "CABLE" or "CATV" then the TV will only scan for a limited number of channels because it assumes you have an antenna hooked up to it instead of a cable line. This is the same for all TVs. Anytime someone runs a channel scan on ANY TV and they only pick up a limited number of channels, they need to change the setting I've described. And remember, it will be on the same menu screen that you go to in order to run the channel scan.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
P.S. On some TVs, autoscan is called autoprogram.
Jun 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
NO HDTV
There are many variables here that could cause the problem. I can receive a few local HD channels ( within about 60 miles ) on my 57H94. I am not aware of any "HD specific" settings- it's all part of the receiving circuits in the TV. The first thing I would look at is to be sure you have a secure antenna connection. Then be sure you have selected the correct antenna input on the TV (there are two). HD channels, as an example will show up as 10-1, 10-2, etc. Most TVs have different sensitivity thresholds, regardless of size. Usually digital signals, including HD, are either there or not. In most cases if a TV picks up a decent analogue signal, a digital set should receive the digital signal, including available HD channels, as well. If you are going to use an antenna, rather than cable or satellite, try to get the best antenna you can afford, that will meet your physical requirements ( indoor / outdoor,etc.). Keep in mind that not all digital TV signal are HD. All of our local stations in this area transmit a digital signal, but true HD broadcasts remain variable. I hope this has helped in some way-Good Luck!
Nov 15, 2008 | Toshiba 57H94 57" Rear Projection HDTV
I purchased a SANYO-DP46848 42"HDTV. I have a Cable box and my cable provider (Time Warner Cable) provides free HD Channels. However.... I CANNOT PICKUP ANY HD CHANNELS ON THE NEW TV. WHY???...
I just got the same exact one, when it searches automatically the first time it doesn't look for digital channels. go to Menu>manual channel search>cable. it will look for all possible signals and will take forever probably. the free digital channels will take several seconds to switch channel to channel, but they're there! They will show up on your screen as "DC 91-2" or similar. you can switch back to regular cable channels with the input button, you just cycle through all the inputs. hope that helps.
May 18, 2008 | Televison & Video
Get HD Signals but it Says Channels not available
you might have to look for "hidden" hd channels.
most cable companies are broadcasting the local stations unencrypted, so you should be able to receive them and sometimes a few other "basic" hd channels like discovery or tnt.
try googling your cable system, city and hd channels to see if someone has posted a list of channels (eg, 88-1 or 102-1)
Jan 12, 2008 | Panasonic TH-50PX75U Plasma HDTV
HD cable question
i have the same LCD and my problem was the same as you, you need a powerful antena like a out dor antena or indor antena whit buster
Dec 03, 2007 | Polaroid FLM-3232 Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
