Question about Pool & Spa
Water does not ciculate thru skimmer - Pool & Spa
  • 1,631 Answers
Can you provide additional information, use comment section ?
What kind of pool, inground, Steel wall above ground?
Toy pool from Wal-mart, kmart, target etc.?
these are important bits of information to know.
is there separate equipment or combo... pool pump and filter separate units or are they combined?
Posted on Apr 06, 2015
    Problem Solver:
  • 11 Answers
Check the valves that control the water in the pool equipment area. There are usually valves to divert water between the skimmer, service port and outlet jets. Also, the multi-port valve on the filter has several settings on it to control normal filtering, backwash, bypass, winterize etc. If all the valves are correctly set, you should look in the skimmer and pull the strainer basket out. Clean it if necessary and look at the bottom of the skimmer bucket to ensure that the drain cover is open.
Posted on Jun 23, 2014
How to vacum my spa with pool maintenance kit
if you have the intex kit , it comes with instuctions but hers it ina nut shell , find adaptor plate that fits inside skimmer (flat thing with hose port in middle) assemble sustion head and handle with hose attached and drop into pool (keep handle out) fill hose full so it sort of sinks (no air gaps) snake carefully end of hose over to skimmer (pump running normal) fit plate into skimmer quickly snake hose thru skimmer hole and fit to plate adaptor on hose port , wait a few minutes if flow continues out pump dishcharge then your good to go if not dissasemble and start over , but let filter pick up prime again 1st , do not lift head out of water even to get big stuff off pickup do it in the pool under water
Jul 23, 2014 | Intex Above Ground Swimming Pool Skimmer...
What are the dimensions for cutout and hole pattern
you dont cut it out until all bolts are tight fill the pool just about to skimmer only poke holes through as you put skimmer together with gasket on both sides after all tight and full cut the inside of the skimmer out
Apr 26, 2014 | Sun N Fun Deluxe Thru-The-Wall Skimmer
Pool pump wont prime
if this is a inground try only the main drain if it works something is in the skimmer line
Jun 01, 2013 | Pentair Pinnacle High Performance 1 HP...
What is a Co-Current protein skimmer?
Co-current protein skimmer is one of the methods used in aquarium water skimmers. The air source is on the bottom of the reaction tube. Water is drawn up into the chamber with minimum dwell time. This skimmer is the least efficient of all skimmer designs.
Aug 30, 2012 | A H Fabrications Fish
What is counter current protein skimmer?
A counter current is one of the methods used in aquarium water skimmers. The water to be processed enters the skimmer reaction chamber, then the air administered through a diffuser. The water flowing downward meets the bubble column flowing upward, this increases dwell time making the skimmer much more efficient.
I can't get surface skimmer to work
im not sure what or even how you mean "swims away" as properly intalled it has a bracket that holds to pool wall , no the most problem ive seen with these is they sink !! pulling it and bracket right to bottom , this is just an adjustment of water flow thru float skimmer vs side skimmer (normal)
Jun 22, 2012 | Intex Swimming Pool Leaf Catcher Skimmer
My pressures low
Low water volume will cause low pressure. Check for any obstructions in the suction libe and/or minor leaks that will cause the pump to **** air. If everything checks out, make sure the water is actually flowing thru the sand. If you suspect the water is bypassing thru the multi-port valve or a tunnel in the sand: pour a cup of flour in the skimmer, if you see it return thru the returns, you have your verification.
Jun 17, 2011 | Hayward SAND FILTER, PRO SERIES
When vaccuming pool,after attaching hose to skimmer water pressure resort to priming stage.wyh?
Thank you for posting your question here on Fixya.com.
It happens because you are introducing a lot of air into the suction line when you attach the vacuum hose. Once the pump draws that air thru and expels it you should go back to normal pump flow in order to vacuum. To help eliminate this problem, place the vacuum under the water and take the end of the hose you will attach to the skimmer and place it over a return outlet. This will fill the hose with water and force most if not all the air out. Attach the hose to the vacuum plate and vacuum away.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Sep 07, 2010 | Emerson Pool & Spa
Pool & Spa Logo
693 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
