Canon ir1605 it gives open front cover rec.paper jam
SOURCE: canon mf5650
Check the paper setting in your software. Paper size should be A4 in all instances. Hope it helps
Posted on Oct 05, 2007
  • 537 Answers
SOURCE: Cannot find paper jam ...
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
Posted on Oct 21, 2008
MXM450
  • 62 Answers
SOURCE: PAPER JAM
laser printers dont use ink.
you will have to check the sensors. first the one where you put the media (paper) then check the registry one (remove the cartridge and you should see it) then the fixing on, from the back it has a small cover you can open an dthen a pair of green coloured levers to remove any jammed paper in fixing (the hot ***'y) then check the delivery sensor right where normally you see the page printed out and coming your way. there should not be any media remains anywhere. also if you copier is dirty it may also be causing this. try to clean it with compressed air.
Posted on Jan 22, 2009
canontech
  • 1219 Answers
SOURCE: REC. Paper Jam, Open front door
1) check left door of cass pick up section, if they are closed properly, special the sensor flap- when you opens the lower left door of cass section,you have another "door" which pick up the flap into some middle position in nick in the "door". For test try with finger yust to see the diference in positions.
2- check all sensor flappers
Posted on Jan 13, 2010
canontech
  • 1219 Answers
SOURCE: Paper jam /Message says Rec. Paper jam Open right cover
From right side of fax, open the toner door, remove the crg.unit, and look for paper, if not also from left side open the door and check for paper or broken parts in fixing unit.
Posted on Apr 30, 2010
Rec. paper jam open right cover
Obviously you have a paper jam somewhere. Probably one the right side, open all the covers and pull the paper out.
Oct 20, 2013 | Canon FAX-L400 All-In-One Laser Printer
I am getting rec.paper jam no paper jammed though
Open back door, clean feed roller very well, and open and close upper cover.
May 28, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Paper jam will not clear
you have a stuck or broken sensor
Jul 02, 2009 | Canon Office Equipment & Supplies
May 21, 2009 | Canon FAX-L400 All-In-One Laser Printer
L-50 machine gets Rec.paper jam slide platen left
Slide the uper unit to the left by pulling handle on the left,open cover on the right,remove drum unit by pulling on the handle,remove paperjam.
Oct 31, 2008 | Canon PC-1060 Black and White Copier
PAPER JAM
Oct 29, 2008 | Canon imageCLASS D320 Digital Copier
Oct 21, 2008 | Canon ImageClass D880 Copier
Jarry cannon
open printer cover, pull out toner cartridge, re-install cartridge, close door, it should re-boot the machine.
Mar 14, 2008 | Canon LaserBase MF5750 All-In-One Printer
Ir 1600
That code indicates a laser problem. You can check the door switches on the front of the machines as well as the left lower door.
Jan 25, 2008 | Canon imageRUNNER C3200 Copier
Canon mf5650
Oct 04, 2007 | Canon LaserBase MF5650 All-In-One Printer
18 people viewed this question
k24674
jasbo
jasbo
