Question about Exercise & Fitness
I would like to find an operation manual for a WESLO FLEX TABLE
I would like to find an operation manual for a WESLO inversion flex table. This exercise machine is similar to a Teeter inversion table.
  • 101 Answers
SOURCE: Repeated Broken Flex Plate in Transmission
1997 Honda Passport 4wd
Make sure you have the correct factory Honda starter in your car , if its an aftermarket starter they may have replaced with cheapo starter,sometime the teeth that engauge starter to your flexplate will not mesh properly,because there different,causing the flex plate to fail. I had the same problem. I went thru 2 before I found this out..Hope this helps.
Please rember to rate me on my help. Thankyou!
Posted on Dec 16, 2008
  • 4 Answers
SOURCE: 2009 ford flex - in for slipping transmission 2x,
i work at a ford dealership and its very rare to actully have a flex come in for somthing wrong... im sorry to hear about your missfortion
Posted on Jul 13, 2009
SOURCE: Manual Craftman professional router table model
I had the same problem as far as the manual is concerned. I emailed Bosch. They responded and told me this is actually a Vermont American router table, and said they would put a copy of the manual in the mail to me. I haven't received it yet.
Posted on Feb 03, 2010
maxtreadmill
  • 832 Answers
SOURCE: how do i get the ankle holder in a nordictrack
Go to iconservice.com go to replacement parts input NORDICTRACK 30792
Posted on Jul 19, 2010
maxtreadmill
  • 832 Answers
SOURCE: looking for a manual for an old lifestyler (weslo)
You may have to call iconfitness.con since this is their product, they may have the manual in their Dungeon call them @ 1800-999-3756 GOOD LUCK!!!
Tip
Table Saws not Powering Up
When a table saw won't power up there are various causes of failure, but troubleshooting should be done in a methodical order, the main thing though is to check the obvious first!
Equipment Needed:
  1. Continuity meter or multimeter to trace continuity from the plug to the motor
  2. A non-contact voltage detector (optional). These devices glow when the tip is held close to a live cable
Troubleshooting:
Remember to avoid shock, disconnect the tool from the mains supply before troubleshooting!
  • It may be obvious but ensure the socket outlet isn't faulty, try the tool in another outlet to see if it works.
  • Check whether the overload circuit breaker if fitted on the tool has activated. This happens e.g. on a table saw when the motor is stalled. To reset you need to press a button. The breaker may need a couple of minutes to cool down before resetting
  • If plug is rewireable check for loose screws at plug pin terminals, loose or blown fuses etc.
  • A common cause of failure especially with drills and other hand held tools is one or more broken wires in the power flex caused by metal fatigue in the cable (like when you break a paper clip by bending it backwards and forwards) , this usually happens where the cord leaves the plug or where the cord enters the tool. If you have a non-contact voltage detector, you can use it to trace the break from the plug to the tool. Plug in the tool and hold the tip of the detector at the plug, it will glow here but as it is moved down along the flex it will stop glowing after the break (If the break is in the live core of the cable)
  • Sometimes it is possible to detect where a break is in a flex by stretching it, the flex will narrow in the region of the break
  • If you still can't trace the fault, unplug the tool. Open it. Check the continuity from each pin of the plug to the switch in the tool.
  • A faulty on / off switch can prevent the tool from working. Use the continuity tester to check this
  • Loose spade terminals on switches may cause intermittent operation
  • Tools with green and red start and stop buttons may have a faulty relay
  • The brushes in the motor may have worn down
  • The armature or field coils of motor may have gone open circuit. The field coils can be checked with the continuity meter
on May 12, 2011 | Saws
Not working
There are various causes of failure but the checks should be carried out in this order, you will probably need a continuity meter or multimeter to trace continuity from the plug to the motor:
Check overload circuit breaker on saw hasn't tripped. This may need a couple of minutes to cool down.
If plug is rewireable check for loose screws at plug pin terminals, loose fuses etc.
Wires in power flex breaking, usually at plug or where flex enters machine.
Faulty on / off switch or loose spade terminals on switches or faulty relay on switch.
Worn out brushes.
Armature or field coils of motor going open circuit.
Mar 05, 2011 | Bosch 4000 - 07 Electric Table Saws
Table saw model 36-650 suddenly stopped while in use. Checked the power cords, pressed the reset switch on the motor. What are the likely causes of failure?
Worn out brushes.
Feb 27, 2011 | Delta Saws
Yeah, I sure could use some help. I have an older craftsman table saw. It is a Flex-Drive. Model # 113.241691. I acquired it from someone that didn't have the manual. Needless to say, that leaves me with...
Don, go to "managemyhome.com and type in your model number under the manual section. Have plenty of paper ready it is 52 pages long and will instruct you how to align the saw along with other solutions to your many problems. Let me know if you need more assistance
Sep 10, 2010 | Craftsman Saws
My screen on my VE20 stopped working.
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Jul 23, 2010 | Motorola Mobility MOTORAZR VE20 Cell Phone
I bought a weslo inversion table at a fle market but it didnt have a mannual with it. is there any place to download one?
Hello there. Yes there is a site to download it for free. Go to
http://www.iconservice.com , then go to the manuals section,
In the model number section you should enter wlbe13320 . this will pull up a pdf file that is free to download and print.
Good Luck! Tim
Jan 27, 2010 | Peavey Fitness Pro Inversion Table
Air flow hockey table
We made a fixture that allows us to clean the table top. We took a piece of wood larger than the fan opening, drilled a hole in it, and installed an air fitting for use with our home air compressor. WIth the fans removed, we run the compressor and hold the fixture against the bottom of the table. That forces all that air to exit out the table surface. To concentrate the flow over problem areas we cover sections of the table during the process. Also, you may need new pucks too if they are old and worn.
Dec 09, 2008 | Dmi Sports Air Hockey Table Dmi Goal Flex...
Flex Grid
The most common multidimensional array, the two dimensional array table, is best presented to your users in row and column format. The grid control offers a convenient way for you to display table data to your users. The users can navigate the table's values using scrollbars. Therefore, the grid control does not have to be as large as the table, because the grid control automatically displays scrollbars.
To add the flex grid control to your toolbox, select project and components. Add the flex grid control:
lesson97-1.jpg Once it is added, you will see the yellow flex grid control in your toolbox:
lesson97-2.jpg When you place the grid control on your form, you will have to resize it before the control takes on a tabular appearance. As you expand the size of the control, it does not look to much like a table. The problem is that the table's default number of rows and columns are two. To fix this problem, you must configure the rows and columns in the properties window:
lesson97-3.jpg lesson97-4.jpg lesson97-5.jpg The grid control supports fixed rows and columns. These refer to rows and columns in a grid control that do not scroll when the user clicks the scrollbars. The fixed rows and columns provides labels that describe the data. The fixed rows and columns are often called row and column headers.
lesson97-6.jpg When working with the grid control, much code is needed to provide the grid with functionality. Call statements are used to break the code required by the grid control into smaller, more manageable procedures. This is referred to as modular programming (which refers to the practice of placing code with a single purpose in a general subroutine procedure and then calling the code from a second procedure.)
Here is the code for the form load procedure (this example is based on the computer disk example used in the last lesson)
Private Sub Form_Load()
Call SizeCells
Call CenterCells
grdGrid.Row = 0
grdGrid.Col = 1
grdGrid.Text = "Single Sided; Low Density "
grdGrid.Col = 2
grdGrid.Text = "Double Sided; Low Density"
grdGrid.Col = 3
grdGrid.Text = "Singled Sided; High Density"
grdGrid.Col = 4
grdGrid.Text = "Double Sided; High Density"
grdGrid.Row = 1
grdGrid.Col = 0
grdGrid.Text = "3 1/2 inch"
grdGrid.Col = 1
grdGrid.Text = "$2.30"
grdGrid.Col = 2
grdGrid.Text = "$2.75"
grdGrid.Col = 3
grdGrid.Text = "$3.20"
grdGrid.Col = 4
grdGrid.Text = "$3.50"
grdGrid.Row = 2
grdGrid.Col = 0
grdGrid.Text = "5 1/4 inch"
grdGrid.Col = 1
grdGrid.Text = "$1.75"
grdGrid.Col = 2
grdGrid.Text = "$2.10"
grdGrid.Col = 3
grdGrid.Text = "$2.60"
grdGrid.Col = 4
grdGrid.Text = "$2.95"
End Sub
Notice how the form load procedure is used to populate the cells in the grid control. To control cell size and cell alignment, two smaller procedures are created and each procedure is called by the form load procedure.
Private Sub SizeCells()
Dim intColumn As Integer
grdGrid.ColWidth(0) = 1100
For intColumn = 1 To 4
grdGrid.ColWidth(intColumn) = 2200
Next intColumn
End Sub
Private Sub CenterCells()
grdGrid.ColAlignment(intColumn) = flexAlignCenterCenter
Next intColumn
End Sub
Notice that the size and alignment procedures are only applied to columns 1 through 4. Column 0, which is a fixed column reserved for labels, is not formatted using either of the above two procedures.
Here is the final result:
Mar 26, 2008 | Computers & Internet
HOW TO INSTALL THE OEM Motorola RAZR V3 Keypad LCD Flex Cable
1), remove the bottom part (completelly)
a) do you know how to open the bottom part?
2) remove the cover on the top part
a) disconnect the keypad LCD Flex Cable
3) remove the two chrome "big screws" that allows it to open and close
4) CAREFULL!!!! WHEN YOU READY TO SEPARATE THE TOP PART FORM THE BOTTOM!!
a) make sure the Flex cable is loose, and take a screw driver, push the ping on the other side (try to do this at the edge of a desk or table) keep pressure until this side pops out. KEEP IN EYE ON THE OTHER SIDE!! that the Flex cable does not get cut out by separating the two sides.
5) Replace and pop the two sides together.
6) Put everything back together.
let me know if I need to be more specific
Dec 07, 2007 | Motorola Mobility RAZR V3
Exercise & Fitness Logo
61 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
