Question about MSI H55MP31 LGA 1156 Intel H55 Micro ATX Intel Motherboard
How to conect motherboard wires - MSI H55MP31 LGA 1156 Intel H55 Micro ATX Intel Motherboard
Problem with lan in dell ispiron 6400. When I put in lan wire it shows that cable is not conected. Cable is ok, I tried few. When I look on the conection window sometimes it flashes for less than one...
Inspect the pins inside the network connector. They have to be even and stright. Sometimes people put there a phone cord connector and it bends pins 1, 2, 7 and 8. To recover use a needle with slightly bended tip. Hook the pin with the bended tip and pul until strightened.
Apr 08, 2012 | Dell Inspiron 6400 Notebook
Remote control will not turn on fan
Do you have the correct type of fan connected to the motherboard ?
For fan control to work you must be using the type of fan that has at least three wires in the connector plug (if it has four wires that is ok too) but if it only has two wires then it will not works since the third wire is the control wire that the motherboard uses to detect fan speed and so on...
Fans that connect through a connector on the power supply will not work either must be conected to motherboard plug on the motherboard itself with at least three wires
hope this info helps
NOTE: if you are sure you are using the correct type of fan then check BIOS power/hardware monitor settings to see if the fan is connected to the correct plug on the motherboard and to verify it is being detected properly and fan speed setting is correct.
May 15, 2011 | Computers & Internet
Conecting front panel wiring to INTEL 845GRG MOTHERBOARD.
Normally a small area of 10 pins or 9 one is not used,you nedd the book or go to manufactuers website and download user manual,connect your wire to the board with out a diagram and you could damage the board
Jan 15, 2009 | Intel D845GRG Motherboard
Intel D845GRG Motherboard Problem:usb wiring conection to board
Hi mrm291048,
The Intel D845GRG MB supports USB 2.0 & is backwards compatible to USB 1.0
For in-depth description of motherboard wire color & location click on this link & scroll down till you see, "Standard USB Cable Wiring Color Code". http://www.usbman.com/Guides/BelkinMotherboard_cable_assembly.htm
You'll also need to open your manual to page 68 If you need the manual for the D845GRG MB click on this link; ftp://download.intel.com/support/motherboards/desktop/D845GRG/BVRG_English.pdf
Between the two you should be able to set the correct colored wire up to its matching pin on the MB.
If this is not answering your question, please set me strait & rephrase the question.
Mike
Sep 30, 2008 | Intel D845GRG Motherboard
Need to know how to wire it.
Here is a link to where you can download the manual for this motherboard: http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=193&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
Mar 04, 2007 | EliteGroup K7SEM Motherboard
MSI H55MP31 LGA 1156 Intel H55 Micro ATX Intel Motherboard Logo
14 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
