Question about Grilling
Need instruction manual to assemble members mark hybrid grillinstruction manual for hybrid grill
SOURCE: Need instructions for assembly of char-broil gas grill
mine wont line up i need help
Posted on Oct 10, 2008
SOURCE: I need the assembly instructions for a Four Seasons Gas Grill
I purchased this grill and assembled it yesterday. I noted the area that is providing confusion as it is wrong. Please follow the following instructions. It is quite simple when you have a background in electrical and electronics engineering. These directions should translate my knowledge into step by step instructions for all.
1. Attach the two thinner wires with two terminals on each wire, from the front of the grill head to the larger (Input or Control) terminals on the igniter assembly. These two wires are from the push to turn micro switches on each of the burner control knobs on the grill head. Attach the two smaller terminals on these thinner wires to the micro switch on the side burner control connected as part of the regulator and hose assembly.
2. Attach the three thicker wires from the front of the grill head to three of the six smaller (output) terminals on the igniter assembly. These wires go to the igniters themselves.
3. Connect the two thicker wires from the rear of the grill head to two of the six output terminals on the igniter assembly. The small wire is for the igniter on the bottom infrared burner and the larger, thermally insulated wire, connects to the igniter on the rear infrared burner.
4. Connect the lead from the side burner to the remaining small output terminal on the igniter assembly.
5. Mount the igniter to the front of the right side shelf by removing the battery cover and hexagonal nut. Insert the shaft through the hole in the front of the right side shelf and secure with the hexagonal nut. Replace the battery cap. Do not install the battery at this time.
6. Mount the side burner control by inserting the long end of the control into the side burner assembly. Attach the control to the front of the right side shelf with the two screws held in the front of the control assembly. NOTE: You must remove the screws from the control assembly and insert them through the Off/On bezel and front panel of the right side shelf before screwing them back into the control assembly. Install the control knob for the right side shelf. Verify that the connections to the side burner control micro switch made in step 1 are still intact.
7. Insert the battery into the igniter assembly by removing the batter cap and inserting the AA size battery with the positive (pointed) end out. Replace the battery cap.
8. Test the igniter assembly prior to installing the gas tank and installing the “Flame Tamers” and grates by pushing in on each burner control knob in turn. Listen for a popping sound and look for sparks at each burner.
I hope this helps.
Ed Roberts
President
E. F. Roberts & Associates
www.efrobertsassoc.com
Posted on Apr 09, 2009
  • 26 Answers
SOURCE: Instruction Manual for Thane Q-grill.
go to this site http://www.thane.com/manuals/manuals.php then scroll down to the Thane Q-BBQ Grill manual, select it and it will open in PDF formate so you will have a free instant manual.. if this helps please rate me and let me know..thanks and good luck!
Posted on Jul 21, 2009
  • 51 Answers
SOURCE: i don't mave instructions on how to assemble my grill
use your brain
Posted on Sep 04, 2009
  • 153 Answers
SOURCE: I need a manual for
http://www.appliancefactoryparts.com/content/pdfs/8746-1.pdf
try this link
Posted on May 05, 2011
Testimonial: "Excellent and promptresponse. Thanks"
Need to order parts for Members Mark Gas Fired Ignition Charcoal Grill Model:CG2001201-MM-00
Just Google it and you'll find a number of places, such as:
https://www.appliancefactoryparts.com/gasgrillparts/brands/members-mark/
Jul 04, 2017 | Grilling
Bought a members mark hybrid grill model number gr2071001-mm. Attempted to put it together but when I opened the box I discovered that it did not come with an instruction manual. Where can I find one at...
check with the store where you got it, if they dont have it go to the manufacturer of the grill. they will need the information from it and should be able to give you one.
Dec 24, 2014 | Grilling
Members Mark Hybrid question
Did you try switching out the tank? Turn off the tank and disconnect it ... check the connections to be sure there is nothing blocking the flow. Carefully open the valve on the tank to be sure it is letting gas out. You should hear as well as smell it ... be very careful that it is not near an open flame or heat when doing this. Also be sure you are outside in an open well ventilated area. Only open it for a second or two then shut it off.
Dec 01, 2013 | Grilling
We recvd a "backyard classic
This imported (China) hybrid grill is an exclusive of Sam's Club. You can ether contact them (you aren't the first one to complain of this) or the manufacturer's Customer Support Dept. 1-888-837-1380. Even with the Owners/Assembly Manual they are are not easy to assemble, according to other customers.
Hope this helps you.
Jul 04, 2011 | Grilling
I have an Model: GR3055-014684 Grill from sams club and their was no assembaly instuctions or manual. Can i down load them and where do i go to get them.
Apparently, you're not the only customer who purchase this Hybrid Grill, got home, only to discover the Owner's / Assembly Manual was missing. On the Sam's Club website they list a number 888-837-1380 to call if you have any questions, parts missing, etc. I could not find any on-line manuals for this imported grill. Sadly, you may have to wait until later this week, to assemble the grill. Or go back to Sam's Club and ask them to copy a manual from the display model grill.
Hope this helped you.
Jun 19, 2011 | Grilling
I have a hybrid grill model number: GR3055-014684 and I would like a grill cover to fil it.
i need the instructions to put mine together as it did not come with any. But Lowes sells a cover to fit this grill. if you know where i can get the instructions that would be awesome!
Jun 13, 2011 | Grilling
I purchased a Hybrid grill @ Sam's Club and the
John, the best place to start is the manufacturer:
Rankam's BBQ Grills & Accessories
1322 Rankin Drive
Troy, MI 48083
888 837 1380
But, don't waist any time, as your grill only has a 90 day warranty.
May 16, 2011 | Grilling
Grilling Logo
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
