Question about Compaq (242697-001) 8-port KVM Switch
Out of frequency
When i start my computer,I get an out of frequency message at boot time.
plz tell me how to remove it.
can u send the solution on my e-mail add:
    Brigadier General:
  • 6,966 Answers
Re: out of frequency
Are you referring to a problem with a Compaq (242697-001) 8-port KVM Switch or on your display (projector?)?
If it is a display problem, start your PC in Safe Mode and go to your Display Properties. In the Settings tab, lower down your screen resolution and color quality. In the Advanced button, Monitor tab, lower down your Screen refresh rates.
Reboot. Do the same and increase settings slowly (by increments) till you get the "out of frequency" message again. Pressing escape would revert you back to the last setting that worked fine.
Hope this be of some help to you, otherwise pls post back with a more detailed description.
Good luck and kind regards.
Posted on Nov 02, 2007
0 characters
3 Points
Eurovox max v code needs updating
VM are currently switching frequencies both to be a pain and preparing for the analogue switch off. All you need to do is factory reset and rescan. Don't forget to turn EMU back on.
Oct 05, 2009 | StarView SV211K 2-port KVM...
Telewest codes for southlanarkshire plzzzz
JUst got further info some frequencies have changed. Factory reset and rescan.
Jul 17, 2009 | StarView SV211K 2-port KVM...
When 2 pcs boot at the same time on my GSC1464 switch, the one which the swtich's tune too work the video display like it should but the second limit the second computer (the one who wasn't selected) limit...
When a computer first boots up the video card send a request to the monitor to find on what resolutions the monitor supports. If the video does not get a response the card will default to very low resolutions. The only way to avoid this problem is to boot your computers one at time and keep the KVM on the computer until it fully boots to a desktop. This will allow the KVM to pass the monitor information to the computer.
Jun 29, 2009 | IOGear MiniView DVI KVMP Switch GCS1764...
New codes for may
Try re-scanning some frequencies have changed
May 31, 2009 | StarView SV431USB 4-port KVM...
Computer problems after installing automatic switch
It really upsets me that a product I bought from you messed up my computer and now you want me to spend more money to tell me how to fix it. The instructions that came with the switch states "free technical support" Please follow this claim and tell me how to fix my computer.
Dr. George Saiter
Oct 07, 2008 | Cables Unlimited KVM Switches
KVM Monitor resolution out of frequency and will not display
Restart your system in a VGA mode (you will find this below Safe Mode, by pressing F8 before windows is loading) This way yours screen resolution will be at the very low frequency then you can change it back to the resolution you like. Eg. 800x600 or 1024x768. Remember to keep your Screen refresh rate lower like 75Mhz
Oct 30, 2007 | Compaq (242697-001) 8-port KVM Switch
PC start up problem
dont forget to tell me u r problem solved or not
best regards & best of luck..
even u can mail me at my mailing add-
Oct 12, 2007 | Trendware TK-207K 2-port USB KVM Switch
My Keyboard only works on one PC but the monitor and mouse works on both?
Plug the key board and mouse directly into the computer that doesn't work, let it recognize the hardware and then reboot. After reboot, plug the keyboard and mouse back into the KVM and reboot again. That solved the problem for me. Most likely, the computer that doesn't work has never loaded the driver for that key board and does not recognize the input sent from the KVM.
Oct 09, 2007 | Belkin F1DK102U 2-port KVM Switch
KVM Switches Logo
146 people viewed this question
Top Compaq KVM Switches Experts
Peter Parker
Peter Parker
Are you a Compaq KVM Switch Expert? Answer questions, earn points and help others
