Question about PaceMaster Exercise & Fitness
Treadmill suddenly stops during run cause fix
Treadmill runs but suddenly stops after 10 minutes
You should lubricate walking belt , check the deck for wear , too much friction between walking belt and the deck may cause the motor to shut down
jbassembly
Dec 29, 2014 | Exercise & Fitness
Treadmill keeps stoping
Precor Error 27, Too Much Drive Motor Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 27
Jan 27, 2014 | Life Fitness Treadmill Precor C954 (Used)
Stops while running
i had this problem before , there is something down in the circuit board , its shorting as the reason it suddenly stops , get an electrician to fix the problem , if the board is to critical to be fixed then you need to get a replacement , call up the manufacturer or any store room close by , they ll replace the circuit board for you
hope this helps :)
Jan 25, 2013 | Exercise & Fitness
No power from power pack to switch display , need wiring diagram as tried with meters and no success
see the diagram attached and troubleshooting and fix it.
God bless you
However this Sympton is because you do not LUBE the deck belt do it and rollers bearings too, this will fix it.1_14_2013_9_11_01_pm.gif1_14_2013_9_11_33_pm.jpg1_14_2013_9_12_03_pm.png
Jan 14, 2013 | Hammer Walkrunner Rpe Treadmill
Treadmill stops dead during workout
Dear Sir:
The most likely cause of the problem is a worn treadmill belt and deck.
Most of the time its caused from not lubricating between the treadmill belt and deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics.
Feb 14, 2012 | Exercise & Fitness
Client run on treadmill then suddenly its stop and display an error speed, then 5 seconds treadmill belt moves again and moves faster whats the problem of that?
hi,
There are two possibilities for this problem
1. Check the speed sensor on near the motor pulley. Remove the sensor and clean it and re-fix it. then make a try. if problem remains then
2. The motor speed controller is faulty. There is an IGBT for controlling the motor speed. If it get shorted the motor will run it its high speed.
Be sure before opening the treadmill remove the power.
ok
Feb 25, 2011 | Life Fitness 9100 Next Generation...
I have a 6 year old Reebok RX5000. At speeds
They walkbelt is most likely worn out causing too much friction overheating the motor.
Jan 15, 2010 | Exercise & Fitness
The belt stopped suddenly and now won't work anymore
I would check your speed sensor. I've never seen one of these just stop suddenly. But running for a min or so is one of the signs a speed sensor gives you.( especially if the treadmill want speed up while it running) Check this out and if it"s not the problem get as much info as poss to help diag.
Nov 16, 2009 | NRS Golds Gym Preview 1000 Treadmill
Sudden Variable Speed on ProForm 615 XP
Dear mam,
Please check the speed sensor and Belt Tension also.
sada
Sep 27, 2009 | Exercise & Fitness
Exercise & Fitness Logo
107 people viewed this question
Top PaceMaster Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a PaceMaster Exercise and Fitnes Expert? Answer questions, earn points and help others
