Question about Haan SI-35 Slim & Light Steam Cleaner Floor Sanitizer
Haan floor sanitizer no steam
Fixable? - Cleanable? Replace water with ? to flush-out?
Haan steam mop
The heating element may have failed.
Jul 25, 2016 | Haan SI-70 Steam Mop With Detachable...
Can you buy a water canister replacement?
Perhaps you can , but not thru this website .
Sep 05, 2015 | Haan Si-35w Slim&light Floor Steamer
Haan sI70 unit gets hot but no steam is generated, so not hot enough. Anything I can do?
It sounds like the internal temp thermostat is detecting that its hot enough when its not, and cutting the power as its supposed to, but too early. It may not be worth time/effort/money changing this part, in case its a problem with another part. Its a bit desperate but you could turn it off and half fill it with cold water then shake it vigorously to see if washing the internal surfaces impoves things.
Dec 15, 2013 | Haan SI70 Multi Sanitizing Floor Steam Mop...
Shark Euro Pro Steamer
Hi, you could try the following steps, if you have not done so already. Some of these steps may seem like common sense, but it's for people to forget about checking the least expensive part to replace first, so if some of the steps are those that you have already tried, then feel free just to skip through to the ones you have not tried already.
  1. 1
    Make sure the power cord is plugged firmly into the outlet. The steam mop will not start if it the power cord is loose.
  2. 2
    Check the fuse box or circuit breaker connected to the outlet the steam mop is plugged in to. Replace any blown fuses. Reset any tripped breakers.
  3. 3
    Check the water tank if the Shark steam mop will not produce steam. Add water to the tank if it is empty. The mop will not make steam without water in the tank. To fill the tank, turn the tank cap counterclockwise and lift it up to remove it. Set the filling funnel into the tank opening. Pour water through the funnel into the tank until the water level reaches the "Max" fill line on the tank. Replace the cap.
  4. 4
    Inspect the microfiber cleaning pad if the steam mop is leaving water on the floor. If the microfiber pad is too wet, it will leave water on the floor. Unplug the mop from the wall outlet. Replace the microfiber cleaning pad. To replace the pad, move the latch strips out of the hooks on the mop head. Pull the pad off. Set the new cleaning pad on the mop head. Hook the latch strips onto the hooks on the mop head.
  5. 5
    Use distilled water if the steam mop is leaving white spots on the floor. Hard water may cause white spots to be left.
If none of the above work, then is it something that you purchased recently, and is new? If you did, then it could still be fixed under the manufacturer's warranty regardless of whether or not the original length of the warranty has expired. This could be due to the fact that you have received a product that has some sort of manufacturing fault, rather than it stop working through misuse by the user.
If it's a common problem, then you will more then likely be able to return it to the manufacturer and have it replaced for a new one, let alone repaired :-) - This only applies to whether or not the item is New though :-).
Hope this info helps
Apr 29, 2013 | Vacuums
How do i remove the hose from the haan gs 60
Look for a push-in button on the machine where the hose attaches to it. Also check that there may be a twist off connection with 2 pins on the machine that connect to the holes in the metal end of the hose...either is possible..Good luck!
Dec 28, 2012 | Haan GS-60 Steam Station Garment & Home...
My ez1 Monster Floor Steamer - green light goes off when I lower the handle and stops steaming
It could be calcium deposits in the tank. Clean it with white vinegar. Good luck!
Nov 10, 2012 | Euroflex Ez1 Monster Floor Steamer -...
Why are my wood floors not shining?
Well first off, I would not recommend using any time of steam mop on unsealed or natural wood floors. They will damage them because of the heat and moisture. If your wood is sealed then it would be okay for short amounts of time. meaning not keeping it in one position on a section of your floor for a long period of time.
Steam mops are not meant to Shine floors. They are meant to sanitize and disinfect. yes they do clean as well but if your floor is shiny after use then there is to much water coming out and not enough steam.
Sep 18, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Haan SI-35 Slim & Light Steam Cleaner Floor Sanitizer Logo
27 people viewed this question
Top Haan Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Haan Vacuum Expert? Answer questions, earn points and help others
