Question about Snapper Garden
Gas is dripping from line past carb while sitting
  • 2,005 Answers
Check the line and see if it is leaking from the line itself. If so you need to replace it. If its leaking from the ends that goes into the carb take a wrench and take it off and clean and reinstall. You may have to put goop on the threads to stop leak. Be careful as the threads can cross thread as well and ruin the threads in the carb.
Posted on Jan 20, 2016
Why is gas dripping/runnng out bottom overflow line of carb?
Could be one of the carb floats is stuck or the rollover caused it to come off its mounting position. As fuel enters the carb, the float rises with the fuel level until it reaches a position that shuts off any more fuel entering the float chamber and prevents an overflow. Fuel level drops, float drops and fuel flows again. Basically like the cistern in a toilet.
Feb 11, 2016 | ATVs
Appears engine cyl is filling up with fluid and hydrolocking-bike has been sitting for 4 years without running
Hi. Vern the float needles in the carbs need to be cleaned. Also take the plugs out and turn motor to drive out all the fluid. It will also need an oil change because the fuel will get past the rings and fill the sump. Good Luck.
Apr 30, 2015 | GAS Motorcycles
Fuel filled up air intank, lawnmower been sitting for 2 year.2003 troy-bilt riding mower
Ethanol gas ruins the Needle Valve tips and Valve Seats. This allows gas to get past them even when the Float is up causing the Needle valve to close. I bet your Oil is full of Gas as well.
Change oil, Add a Gas shutoff in the gas line and from now on shut the new Shutoff OFF a few seconds before turning off the Mower. OR by a new seat and needle valve for the Carb.
Jul 30, 2014 | Garden
My jag smells like as if it was flooding when i try to start it, when it does start it idles fine but as soon as I rev it up it bogs out, please help me as i really can`t afford to take it to a mechanic,...
Well first off what year and kind of Jag is it?That will make a difference on what might be the problem.If it is a carbureted model, it sounds like you either have a simple fuel line leak going to the carb so when your car sits fuel drips out and gives you the gas smell and then sucks air when you rev it up.If there is no line leak,sounds like your float in the carb is sticking open and simply flooding the carbs with gas,hence the smell and the bogging out at rpm.You would need a carb rebuild kit with float to fix that problem.That way you have gaskets and floats to fix your carb.
Aug 17, 2011 | Jaguar XJ6 Cars & Trucks
Need gas line sketch for craftsman brush wacker 32.cc
Most 2 cycle engines are basically the same. The primer button has two lines coming from it. Gas is actually s.ucked thru the carb and not pushed thru when you prime it. Take a look at the sketch I provided and hopefully you will get yours running again.58fe8f0.jpg
Apr 26, 2010 | Craftsman 25cc Gas Line Trimmer
I have gas dripping from my air cleaner. 2002 883R has been sitting for 1.5 years.
If your bike has been sitting for that long with gasoline in the fuel tank and carb, you can be sure that you need to have the carb disassembled, cleaned, and put back together. Pay particular attention to the accelerator pump diaghragm.
I'd also take the tank off and empty any old gas that was left in there as well. Inspect it for rust on the inside. If everything looks pretty decent, reinstall the tank and fill with fuel. Remove the petcock and clean the strainer on the inside of the tank.
Feb 22, 2010 | 2002 Harley Davidson XL Sportster 883
85 yamaha xt 600 drips gas after it has ran and
Unfortunately, there is no easy fix for this issue. You are right, you do have a float sticking. If you know what one, sometimes you can remove the bowl off the bottom of the carb without pulling the carbs all out. Not many tricks for this, just tear the bottom end of the carbs down and clean them up. Good luck
Sep 17, 2009 | 1985 Yamaha XJ 600
I need the schematics for stihl gas blower [bg85] gas leaking from carb have to overhaul
I had the same problem with mine. And when I wasn't using it, gas would drip out of the tank until almost empty. When I took it to the Stihl dealer, it was actually just the gas lines leaking. They changed the lines and tuned it for $75. It looked to me like the carb also but it was not, just the gas lines.
Sep 15, 2009 | Garden
Gas overflow line coming from carb is pouring out on a 2001 kaw
The float is stuck in the bottom of the carb. Remove the bowl, pull out the float and needle valve, and clean the valve and the hole it sits in.
Jul 08, 2009 | 2001 kawasaki KLX 300
Garden Logo
69 people viewed this question
Top Snapper Garden Experts
ray gallant
solver2010
Thomas Perkins
Thomas Perkins
Are you a Snapper Garden Expert? Answer questions, earn points and help others
