Question about Avanti EC15W-2 Compact Refrigerator
Coling very slowly
It cools but it takes a long time
How do I take the back off of a Kenneth Cole watch kc1346
Could use butter knife or similar something to pry up case back , there is back of watch 12 O'clock side between case and case back put butter knife in and pry up . Be careful make sure not hurting yourself and same time be gentle make sure not damaging something
Jan 25, 2016 | Kenneth Cole Watches
How do i set time for Kenneth Cole Reaction New York Digital Chronograph Men's Watch # KC1494
How do i set time for Kenneth Cole Reaction New York Digital Chronograph Men's Watch # KC1170
Jan 09, 2015 | Kenneth Cole Watches
Cooling fan relay
If the fan runs all the time, even when the engine is first started up and cold, then you probably have a bad temperature sensor switch. When that sensor fails, it keeps the fan on all the time so the car will never overheat...Chris
Dec 01, 2013 | 1991 Mercury Capri
How do o set the time on a Kenneth Cole watch kc1687?
Hi! Welcome to FixYa!
I was able to find a link that details on how to set time on a Kenneth Cole watch. Please on the link: http://www.ehow.com/how_5930839_set-time-kenneth-cole-watch.html
Hope this helps.
Jun 21, 2011 | Kenneth Cole - Ladies Watches - RK4087
My ford F-250 got stuck in the snow, tried to back out. truck was in 4 low now it is struck in 4low and will not com out.truck has manual locking hubs was auto
Hi Cole,
I suggest you carry out the following exercise....
Start the vehicle and, move it slowly under its own power backwards and forward several times....slowly applying and releasing pressure to the transfer lever....until the 'wind up' releases and the low range becomes disengaged....The 4X4 range and more often the low range of off road vehicles often becomes 'wound up' locking it....just as you're experiencing'....We have plenty of experience with 4X4's here in Africa....It may take several tries but it should release....
Regards Johngee10
Feb 07, 2011 | 2001 Ford F250 Super Duty Super Cab
Kennet Cole Mens Watch Model A126-08 KC1494 How to adjust time
I have a Kennet Cole Mens Watch Model A126-05 KC1296 and I'd liked to know
How to adjust time
Jan 16, 2010 | Kenneth Cole Watches
Makes ice very slowly to none...
You need to turn the freezer side to a cole=der setting to allow ice to freeze faster.
Mar 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Taking the battery out
some watches have a special way to open..nut by push/pull out the back but by rotating it .in this case it hase some small cuts in the back cover .if this so,it just might need to rotate.
Feb 02, 2008 | Kenneth Cole KC3289 Wrist Watch
Avanti EC15W-2 Compact Refrigerator Logo
24 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
