Question about Electrolux Refrigerators
My Edina cold soda vending machine which was made by Frigidare is not getting cold. The previous owner (my neighbor who I trust) said it had always worked fine. It had been in his garage, unplugged, for the last year. When I plug it in I can hear it quietly humming when I press my ear against the side of the machine. I looked in the back at the ''guts'' of the refrigerator and nothing looks bent or damaged or leaking. I found the black round thing that had brass tubes and wires coming out of it, (I'm guessing the compressor) it was hot. A label next to it said it had been charge with R134A refrigerant in January of '00. There were no repair/maintenance manuals with it. Is there an easy fix for this? Please help me...nobody wants to buy my warm soda!!! Thank you
  • pablo Jul 08, 2013
    I bought some of these machines from Antares.Now I have the same problem here in chicago..i bought the evaporator kit #AP 4036412. I cannot find a technican to do the job.They all state they do not work on those machines because the parts are hidden behind the machine and not exposed.They cannot be pulled out like other vending machines. If anyone knows of someone who work on this machine please share the info..
    I can be reached at 773-580-9898
  • 4 Answers
I have some of those machines. What happens to them is that the evaporators, which are made out of steel, rust out in approx. 7 years. This allows the R134A to leak out. If you can peek back through to the back wall, you will see where the rust has run down. The solution is to order a new evaporator from Frigidaire at around $100.00 and get someone to change this out and recharge the unit. Before turning it over to the mechanic, you may want to remove the vending module which includes the inner doors and plastic shelves. This can be done in 15 minutes and makes the job easier for the mechanic which can save you money. You should end up with less than $300.00 for the total cost of the repair, but since these machines are rather popular, they can be had on ebay fairly cheap. Sometimes you can pick up new machines for five or six hundred dollars. These are the same as the Antares machines which are made by Edina. I hope this helps.
Posted on Nov 04, 2009
  • Cecilia Guillot May 30, 2013
    I have the black Antares & can't see the evaporator coil when I removed the shelving???
You need a new evaporator in your machines. The part you need is Part #AP4036412. Just type this in your search box and it will pop up. They run like a $154.00 This is the excate same thing that is in the machine. It will last approx last 7 yrs. I would suggest what I did and get one made in copper. This way it doesnt rust b/c of all the condensation. Good Luck!!
Posted on Mar 27, 2013
  • 2 more comments
  • jasonneale00
    jasonneale00 Apr 08, 2013
  • fsp394 Jan 27, 2014
    jasonneale00
    Hi, is the part you listed the same one that is in my pic here?
  • Eric Picardi
    Eric Picardi Jul 11, 2014
    I have the same machine as the one in the picture. The sodas are not getting cold. There is a knob behind the machine at the bottom left side is the the tempriture knob? If not how do I adjust the temperature?
    Problem Solver:
I have the same problem with my Antares vending machine. Do you know what the model number is on that Frigidaire freezer? I want to buy a new evaporator but can't seem to find it.
Posted on Mar 08, 2010
The bill acc. blinks 3 times, bill & cion mechs have been changed, still blinks three times. won't take any money or vend.
Try it without the bill acceptor attached to get the machine working. You did not say what kind of acceptor but three flashes often mean a bad sensor in the unit. Another possibility is that it is disabled from the vendor. Check that all the columns have returned to home position if it is a bag vendor. If it is a pop machine then take off the metal cover over the vend motors and CAREFULLY push down on the microswitches to see if the motors run. Pop may fall out as you do this so watch for it. After running all the motors or homing out all the columns try you machine again. You will probably have to get the bill acceptor fixed though.
Dec 10, 2015 | vendors equipment Dixie 276/368/501 Can...
Genesis vending machine
Have you tried unplugging and reboot it?
Oct 27, 2013 | Retail Supplies
Drink-o-matic seems to run fine but doesn't get cold
Power supply is getting weak, and or the room is way too hot.
Nov 10, 2012 | Sharper Image Drink-O-Matic
I have an Antaris vending machine that has a frigidare cooling system. It was manufactured in 2006 and has been working fine. Recently the motor kicks on but the cooling system does not and it does not...
the antares is notorious for having evaporator problems. The evaporator is not galvanized and as such rusts after a period of time. Once rusted through the coolant is released. The machine will no longer get cold until the evaporator is replaced and the sytstem charged with coolant... gene
Aug 24, 2010 | Frigidaire Refrigerators
Pepsi soda machine
could be low on freon, drity coil, rear fan not turnig,
Apr 10, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my sky box works but when I push for a soda all
There is a little sensor board in the door where the flapper door is,you can access it when the door is open.That is what tells the main control that the can has fallen down through the door and the door has closed.
Aug 27, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
VENDO PEPSI 407 soda machine
selection number 7 reads sold out but its full i have a vendo drink machine that is electronic and i push the code button to test then select number 7 vend on first button then third button to test vend and it showed an error failed .what else could i try i need some sujestions. please.
Apr 23, 2009 | Refrigerators
Refrigerators Logo
3,091 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
