Question about Watches
Setting time in sonata digital watch - Watches
I have a digital wrist watch and I can not set it up.
hi Claude.
Press and hold the "Adjust" button to until the "Time" digits begin to flash. Use the "Start/Stop" and "Split/Reset" buttons to set your digital watch to the correct hour and minute increments. Press "Mode" to display the "Date" setting screen.31 Mar 2015
Digital Watch Instructions ' Techwalla.com
https://www.techwalla.com/articles/digital-watch-instructions
How do u set a digital watch?In normal time mode, Hold L2 for 2 seconds to alarm time set mode, then L2 again to normal time set mode, the second digits begin flashing. Press R2 to reset the seconds to "00", press R1 to switch to the minute digits. Press R2 to advance the minutes. Press R1 to switch to the hour digits.4 Button Digital Watch - Dakota Watchhttps://www.dakotawatch.com/PDF_FILES/Digital.pdfSearch for: How do u set a digital watch?
how to set digital wrist watch Google Search
Nov 27, 2017 | Watches
How to set digital part of the watch
[PDF]4 Button Digital Watch - Dakota Watch
how to set time in digital watch - YouTube
? 1:13
https://www.youtube.com/watch?v=4FmHYMeXbDA
Oct 26, 2011 - Uploaded by Vedant Sen
https://www.youtube.com/watch?v=u_H5I3H15R8 ... how to setyour digital watch {UPDATED} - Duration: 1:20. by Vedant Sen 3,424 views ... The 10 Greatest Wrist Watches of all Time REVISED FOR 2014 - Part 1 - Duration: ...
How To Change The Time On Most Digital Watches - YouTube
? 8:40
https://www.youtube.com/watch?v=kBvaePDtEUU
Jun 27, 2012 - Uploaded by Pitskate
How To Change The Time On Most Digital Watches. Pitskate ...How to change / set time on Armitron watch, 45/7004. - Duration: 2:02. by ...
Jan 05, 2016 | Watches
I have 1 sonata super fibre watch analog+digital i dont know how to set time in it
If its a super fibre 3 series with 4 butons ( set, adj, mode, light)
Just keep the set button pressed for about 5 seconds, then use mode to select next( date, time, year etc) and adj to change the respective data. Then press Set once and its done.
Cheers
Nov 18, 2012 | Watches
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    How to set date in my sonata digital watch
    Just hold the reset button until the seconds start blinking!!!!!
    Then to change secon press sec/strt button or to changr hour,min or date just press mode !!!!!!!!!!!!!!!!!!!!!!
    Jul 13, 2012 | Watches
    User manual for sonata digital watch 7962pp03
    how to change the time of my digital watch
    Jun 16, 2012 | Watches
    My titan sonata watch problem is "date and days are changing at 12 noon" please help me
    it would appear that your home settings are not correct. Refer to 'casio G100H manual' to fix this. You can google it and follow the home setting instructions
    Sep 10, 2010 | Casio G1000H-1A G-Shock Analog Watch
    I accidentaly reset time & date on my square arnette watch and i need help to set it
    Thank you for contacting FixYa.
      Set Digital Watch
    1. Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
    2. Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
    3. Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
    4. Set Analog Watch
    5. Pull out the watch crown on the right side of your Arnette analog watch.
    6. Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
    7. Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
    Best regards. Jewel
    Sep 09, 2010 | Watches
    Tozai digital watch-setting correct time/date
    I need to correct the time/date setting on a tozai digital watch.
    Apr 05, 2009 | Watches
    I cannot set the digital time on diesel watch DZ7101
    First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
    Hope it may help you;
    Regards;
    VOTIT DON'T FORGET TO RATE
    Jan 11, 2009 | Diesel Watch DZ7071
    Watches Logo
    15 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
