Question about HP LaserJet 2840 All-In-One Printer
How to remove drum - HP LaserJet 2840 All-In-One Printer
  • 240 Answers
H20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00364328
pls go the above site and u ll surely get the procedure with pictures explaining them pls rate my solution
Posted on Jun 18, 2009
  • 483 Answers
Hey,
follow instructions with pics, good luck !
http://www.rechargermag.com/articles/31259/
Thanks
Fame !
Remove rear brake drums
Light Duty Models
  1. Raise the vehicle so that the wheel to be worked on is clear of the floor and install jackstands under the vehicle.
  2. Remove the wheel. Remove the three retaining nuts and remove the brake drum. It may be necessary to back off the brake shoe adjustment in order to remove the brake drum. This is because the drum might be grooved or worn from being in service for an extended period of time.
  3. Before installing a new brake drum, be sure to remove any protective coating with brake cleaner or a suitable fast-drying degreaser.
  4. Install the brake drum in the reverse order of removal and adjust the brakes.
Heavy Duty
  1. Raise the vehicle and install jackstands.
  2. Remove the wheel. Loosen the rear brake shoe adjustment.
  3. Remove the rear axle retaining bolts and lockwashers, axle shaft, and gasket.
  4. Remove the wheel bearing locknut, lockwasher, and adjusting nut.
  5. Remove the hub and drum assembly from the axle.
  6. Remove the brake drum-to-hub retaining screws, bolts or bolts and nut. Remove the brake drum from the hub.
To install:
  1. Place the drum on the hub and attach it to the hub with the attaching nuts and bolts.
  2. Place the hub and drum assembly on the axle and start the adjusting nut.
  3. Adjust the wheel bearing nut and install the wheel bearing lockwasher and locknut.
  4. Install the axle shaft with a new gasket and install the axle retaining bolts and lockwashers.
  5. Install the wheel and adjust the brake shoes. Remove the jackstands and lower the vehicle.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]>
May 08, 2011 | 1991 Ford F250
How do you rmove rear brake drum 2004 frontier 4x4
Hope this helps.
Good luck,
Removal & Installation
  1. Remove the hub cap and loosen the lug nuts.
  2. Raise the rear of the vehicle and support it on jackstands.
  3. Remove the lug nuts, tire and wheel.
  4. Release the parking brake.
  5. Pull the brake drum from the hub. If difficult to remove try the following:
    1. Strike the face of the drum with a plastic or rubber mallet. This will break free any rust that may develop between the drum and the hub.
    2. Install 2, M8x1.25mm bolts into the holes in the drum and gradually tighten them to pull the drum off the hub.
  6. 0900c152801a5f72.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Install and tighten 2 bolts to remove a stubborn brake drum
To install:
  1. Install the brake drum to the hub.
  2. Install the wheel.
  3. Remove the jackstands and lower the vehicle.
  4. Road-test the vehicle to ensure that the brakes are working properly.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the brake fluid, as necessary.
  3. Release the parking brake.
  4. Raise the vehicle and support safely.
  5. Remove the tire and wheel assembly.
  6. Pull the brake drum from the hub. If difficult to remove try the following:
Oct 23, 2009 | 2004 Nissan Frontier
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Removal of Rear Brake Drum on 2004 Chevy Aveo
1.Release parking brake.
2. Apply the brake pedal at least 10 times.
3. Raise and support vehicle with jack stands, etc.
4. Remove the tire and wheel assembly.
5. Remove the lock ring and the caulking nut from the spindle.
6. Remove the drum from the spindle.
Note: Pull the drum straight off the spindle.
There is an opening on the inside for adjusting the tension,It's under a rubber cap.You can use a screw driver to make the adjustment
May 13, 2009 | 2004 Chevrolet Aveo
Panasonic FP-7722 Drum Installation
disingage dv unit lower transport assembly remove blue screw from drum unit take drum unit out remove drum lock towards the front remove charge assemby remove drum reinstall drum remember to apply drum powder and replacement of drum blade is recommended reinstall
Apr 09, 2009 | Panasonic FP-7735 Black and White Copier
How to remove brake drum rear wheel 2004 Hyundai Elantra
Jack up rear of car till tire is off the ground.
Remove lug nuts & remove wheel.
Remove phillips screw(s) from drum.
Using a hammer, strike the drum to loosen it from the hub.
Remove drum by simutaneously turning it and pulling it outward away from the vehicle.
Mar 17, 2009 | 2004 Hyundai Elantra
Replacement drum for Q3964a
HP Color LaserJet 2820 and 2840 AiO Series Products - How to Replace the Imaging Drum Replace the imaging drum
  1. Push the scanner-release button to open the scanner assembly. Figure 1: Example of scanner release button location c00364331.gif
  2. Open the top cover. Figure 2: Example of top cover being opened c00364332.gif
  3. Grasp the imaging drum handle, and then rotate the drum until the handle is at the top.
    NOTE: The drum may be a snug fit. If needed, gently apply some force while rotating and removing the drum. Figure 3: Example of imaging drum rotation c00364333.gif
  4. Lift the imaging drum straight up to remove it from the device. Figure 4: Example of imaging drum removal c00364334.gif
  5. Remove the new imaging drum from its packaging.
  6. Place the imaging drum on a firm surface, and then pull the orange rings to remove the shipping pins. Figure 5: Example of shipping pin locations c00364335.gif
  7. Remove the orange shipping lock on each end of the imaging drum, and remove the two orange shipping spacers. Figure 6: Example of shipping lock and spacer locations c00364336.gif
  8. Remove the orange cover from the imaging drum. Figure 7: Example of orange cover location c00364337.gif CAUTION: Do not touch the surface of the roller or expose the roller to light for an extended period of time. Doing so could cause print-quality issues.
  9. Align the arrows on the side of the imaging drum with the arrows inside the printer. Figure 8: Example of arrow location c00364338.gif
  10. Lower the imaging drum into the printer, and then press it firmly into place. Figure 9: Example of imaging drum installation c00364339.gif
  11. Close the top cover and the scanner assembly.
Feb 27, 2009 | HP LaserJet 2840 All-In-One Printer
Imagerunner 1310 drum change
To change the drum you have to slide the plattened cover to the left,like you do when removing a paper jam,open the top cover,you will see a handle that you pull to remove the defeloping and drum unit,remove the drum and def unit.
The drum is attached by two clips on top of def unit,unlock the drum from the def by releasing that clips,slide te drum protecktion plate to the rear and remove the drum.insert the new drum by reversing this steps.
If your image of your copies is not bad you can remove the waste toner in the drum unit before replacing it.On top of the drum there are two plugs open them and remove the waste toner,make sure you remove all of the waste toner.Then that message will go away.
Jan 31, 2009 | Canon imageRUNNER C3200 Copier
Remove photoreceptor xerox 1505
1-6-4 Image formation section (1) Detaching and refitting the image formation unit Follow the procedure below to replace or check the image formation unit. Prucedure 1. Pull the drawer out and open the front cover, bypass tray and paper conveying unit. 2. Remove the waste toner tank and toner container. 3. Remove the two screws holding the waste toner tank cover and then the cover. 4. Remove the screw holding the developing retainer and then the retainer.
5. Remove the two screws and datach the connector and remove the image formation unit.
(3) Detaching and refitting the drum Follow the procedure below to replace the drum. Cautions: • Avoid direct sunlight or strong light when detaching and fitting the drum. • When removing the drum, spread paper underneath as there is a possibility of toner spill. Toner spill can be reduced by inserting an approximately 20-mm thick pad under the image formation unit toward the developing section and removing the drum with the unit slightly tilted. • Hold the drum at the ends and never touch the drum surface. • After removing the drum, keep it in the drum case or storage bag to protect the surface from light. Prucedure 1. Remove the image formation unit (see page 1-6-27). 2. Remove the main charger unit (see page 1-6- 28). 3. Remove the four screw and blade spring, and then open the cleaning unit. • Slide the cleaning blade back and forth and insert an approximately 4 to 4.5-mm thick spacer between the retainer at the rear of the cleaning unit and the housing.
4. Remove the screw holding the drum grounding plate and then the plate. 5. Remove the E ring from the drum shaft.
6. Remove the screw holding the upper developing seal and then the seal. Figure 7. Pull the drum shaft out and remove the drum. • Detach the drum horizontally. 8. Replace the drum and refit all the removed parts. • When replacing the drum, insert a sheet of paper between the drum and developing roller to prevent damage to the drum. • Check the letter indicating the drum type printed on the new drum flange. • Securely insert the drum shaft as far as it will go. When turning the drum shaft, turn it in the direction indicated by the arrow marked on the image formation unit frame. • Rotate the drum in its rotational direction and check that the cleaning blade does not flip up. 9. After replacing the drum, run maintenance items below. • U109 “Setting the drum type “ (set to the drum type printed on the new drum flange) • U110 “Checking/clearing the drum count”(clear the drum count) • U111 “Checking/clearing the drum drive time” (clear the value)
Oct 27, 2008 | Kyocera KM-1505 Copier
HP LaserJet 2840 All-In-One Printer Logo
56 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
