Question about Samsung WF206ANS Front Load Washer
SAMSUNG WF203ANS DOOR IS LOCKED OPEN - Samsung WF206ANS Front Load Washer
I've got a samsung top loader washing machine, it's giving me a DE error code. The door is closed and the message only comes when it's about time to spin
DE = Door Error
• Check the Door-Lock SW terminal connections and contacts.
• Bring the probe of tester into contact with two terminals of Door-Lock SW.[dE Error]
What Samsung is attempting to say is: check the door lock assembly, your machine will not spin if it "thinks" the door is open...
May 02, 2016 | Samsung Washing Machines
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
How to open the door manually for samsung WF9904CWN
Hi David.
If the door is locked and won't open, it's probably because the 'Interlock' has failed.
The Interlock is the part of the door lock which prevents you opening the door while the machine is going. It's part of the electrical circuit and should only be replaced by a technician..
Good luck
Nomess
Feb 04, 2015 | Samsung Washing Machines
Samsung VRT with a DS or D5 code? Door closes but won't lock
bad door lock switch mechinism or the control board is bad at the emergency door lock circuit? where the wires from the door swtich attache, check ur schematic and will need a multimeter
Dec 18, 2014 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
DOOR IS NOT LOCKED
This video will show you how to open your samsung washing machine P1453 door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2013 | Washing Machines
Samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Jun 22, 2012 | Samsung 24"" Dishwasher
Service (repair) manual for Samsung WF203ANS/XAC
You have this listed in the Projection TV area--try posting a new question in the major appliance area---if you post the model number a expert in that area MAY help you or suggest how to get what you want.
Apr 06, 2012 | Televison & Video
What does dc mean for my samsuing model # WF203ANS/XAC?
dc--Unbalanced load preventing washer from spinning
Aug 24, 2011 | Samsung Washing Machines
Samsung Front Load washer has odour
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Sep 01, 2009 | Samsung WF203ANW Front Load Washer
Samsung WF206ANS Front Load Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
