Question about Garden
Huskee supreme 5400
It won't start
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: have Huskee Supreme snow thrower
The starter solenoid is not thrusting the armature into the flywheel. I am not familiar with your particualr engine and starter without some serious book research but..... You problem is on the started itself.
1. A wire may have come off of the solenoid coil
2. The solenoid coil is bad
3. You have a mechanical thrusted starter and the Starter Bendix has failed.
No doubt about it your going to have to troubleshoot just the starter.
Posted on Feb 10, 2010
Huskee supreme LT
model/serial number or the answer is no
Aug 29, 2014 | Garden
2006 huskee supreme slt 4600 keeps blowing fuse
Make sure the battery is not shorting out against anything.
Jun 17, 2013 | Cars & Trucks
2006 huskee supreme slt 4600 fuse keeps blowing, any ideas, it's the one by the gas tank
you have a wire grounding causing the fuse to blow you will have to trace wires to see if one is pinched or rubbed raw
Jun 17, 2013 | Garden
Huskee LT 4200 Won't Turn Over
Remove spark plug. Then try it. Sometimes filled with gas.
May 28, 2013 | Garden
Huskee Supreme (MTD body) loose steering, looks like some spacer or grommet is missing, but can't find in parts diagram
?l=mtd&p=76902073%5c0001&nd=0&z=30
OK THE PART YOU NEED IS PART # 37 PART # 941-0656A ITS CALLED A HEX FLANGE BEARING
Nov 03, 2012 | Mtd Garden
Oil capacity for huskee supreme tiller
approx 1/2 to 3/4 of a quart be careful not to over fill check level as you add an overfilled engine is worse than a low oil situation
Oct 13, 2012 | Garden
The drck wont raise up on my huskee supreme slt 4600
look to see if the lift cable broke or clips fell off
Apr 26, 2012 | Garden
I have a Huskee Supreme Model # 13AX605H730. I have
According to MTD Parts Lookup:
The correct UPPER belt (referred to as the PTO belt and runs from engine to deck) is part # 754-04122 (Also available as 954-04122...in which only the packaging of the part makes the first digit of the part number change. The two belts are identical.)
The correct Description is:
[ Belt, V-Type, A x 90.24 ]
What that means in plain English is that this is a 1/2 inch wide V-Belt with an Industry Standard "A" cross sectional profile. The more important info would be that it's 90.24 inches long.
As for the "Deck Belt" (the lower belt that runs only from blade to blade to blade) it is listed as part #754-0349 or #954-0349 (again, identical belts, different packaging).
A very common problem we see in my shop is that the front pulley (the one directly attached to the engine) shows signs of separation at the weld and the grovve of the pulley becomes wider, therefore making the belt "act" like it's longer because it runs deeper in that groove.
Reply by using the "Add Comments" section if you need any futher info. I'd be glad to offer other possibilities for these symptoms you've described.
Hope this helps,
Dolf-
Oct 17, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Huskee jerks while going forward
Go to... http://mtdparts.arinet.com/scripts/EmpartISAPI.dll?MF&App=MTD&TF=Empartweb&Lang=EN&searchDB=MTD&loginID=MTDCon&LoginPWD=&xmlPostDest=http://www.buymtdonline.com/webapp/wcs/stores/servlet/processShoppingCart_10101_19502_-1_19502 Enter the brand (Huskee) and model number, not the one you listed, but the one under the seat... hit search and click on illustrated parts, then click on Mower Deck. That will show you the routing and belt number.
Jul 06, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
