Question about Brother Office Equipment & Supplies
Unable to int.73 in dcp-j125c? - Brother Office Equipment & Supplies
2 Suggested Answers
  • 526 Answers
SOURCE: unable to int.AF by brother 330c
most likely you will need to take it in for service.
the problem with the AF error indicates a bad scanner assembly or possibly a cable that needs to be reconnected.
Before replacing the flatbed unit, disconnect and reseat the CIS flat cable at the Main
PCB. This will ensure that the issue is not being caused by debris in the connector.
open up the plastic cover that goes from the back to the middle of the unit. it looks like the cover goes from top to bottom, in the middles it turns to the left. take that out with a small flat blade screwdriver, pull the cable out and put it back in.
make sure you do this when the unit is not plugged in.
thanks
Posted on Aug 19, 2009
BROTHER DCP J140 W UNABLE TO PRINT ERROR 73
Hello!
Please find attached a manual to this printer.
Hope the "Troubleshooting" part will help you.
https://manualsbrain.com/en/manuals/1228133/?page=42
Nov 04, 2017 | Brother Office Equipment & Supplies
Paper jam unable to print print 73 error how to solve it
I have same problem, the message make me wonder. I am very sure there is no paper tears in the printer. But then i have the answer from internet. I hope this answer can solve your problem too.
First shutdown your printer and open printer cover and find something like ribbon plastic transparant. becareful,clean that gently use wipe tissue or alcohol tissue. dont touch with your finger. hopefully it can solve your problem.
Oct 03, 2016 | Brother DCP-J315W Inkjet Multifunction...
WHERE IS THE PURGE UNIT IN BROTHER DCP-J125 PRINTER?
Description Fails to switch the cap lift cam positions. Causes Cap lift cam switch defective ASF encoder sensor defective ASF motor defective Main PCB defective
Dec 29, 2014 | Brother Dcp-J125 Compact A4 Colour Inkjet...
How to clear "unable to init.73" in brother dcp-j125 printer?
Hi
This is a mechanical problem of some description. Open the scanner cover and remove any foreign objects and paper scraps from inside the machine. Then, disconnect the machine from the power for several minutes and reconnect it. This should clear the error, but if it does not repeat the procedure making absolutely certain there is nothing in the printer obstructing the paper path.
You can get a manual for this machine here:
http://data.manualslib.com/pdf2/36/3557/355673-brother/dcpj125.pdf?5f68814c3d046699f5763ce9725a25e1
and there is a manual resetting procedure that you might try here:
Reset Methods for All Brother Printer Models
Hope this is helpful, if so would you please register that with Fixya
Cheers
Brother dcp-j125 shows unable to print 73
'unable to print 73' is a Printhead error..
Usually the printhead is an expensive part around $80 to $110, and you will need a full set of cartridges to prime the new printhead..
Sorry to say that this repair is not normally economical to go ahead with.
Oct 15, 2014 | Brother DCP Office Equipment & Supplies
Brother DCP-9010cn is showing Unable to print code 73
The error code 73 means that you have a paper jam or a paper sensor problem.
here are a list of all the codes for brother printers:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000068/faq000168_005.html?reg=us&c=us&lang=en&prod=mfc5490cn_all
To troubleshoot paper jams go here:
http://www.manualslib.com/manual/355700/Brother-Mfc-9010cn.html?page=78#manual
If its not a paper jam you will need to call brother customer service as it may need a sensor part.
1-877-BROTHER (877-276-8437)
Mar 14, 2014 | Office Equipment & Supplies
Brother DCP-J125 unable print 73
unable to print 73 brother printer dcp-j125
Mar 29, 2013 | Brother DCP-J125
Unable to int.AF by brother 330c
thanks
Aug 19, 2009 | Brother Office Equipment & Supplies
Brother DCP 330C
This COULD BE that there is some paper stuck in the dcp. Open cover and try to see if there is some paper left in the machine. I ve noticed, that -seeing from behind!- on the right side paperpieces are stuck and disturb the disk (foil) which give the printer info what to do. Open cover and try to look into the edges (seeing from the front: its the left side -where the modell name is printed) In some cases this means that the purgecamshaft is defective.
Aug 17, 2007 | Brother DCP-330C All-In-One InkJet Printer
18 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
