Question about Bose Wave Radio
First cd works fine but bose won't shift to the other 3 CD's...keeps saying "error" . I have tried unplugging the AC cord and then plugging it in again...worked for awhile but now doesn't work again.....help!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 71 Answers
Check the pins on the cable that's plugged into "BoseLink" on the Wave Music System. If even 1 pin is bent, this could happen. If that looks fine, try another reset, but keep the power unplugged for at least 30+ seconds. If this fails, call Bose tech support at 800-367-4008. If this is under warranty, they will fix this or replace it for free, otherwise it will be about $75 to fix.
Posted on Jun 18, 2009
No sound from CD player. The turntable, radio & cassette work fine.
Can't get video to work so bose works with tv sound
Can't get video to work so bose works with tv sound I needed to reset the power on my bose and instead of unplugging the power cord, I unplugged the audio/video jacks because I couldn't see behind the
Oct 03, 2015 | GPX S7694 CD Shelf System
My bose CD player is not working my cd are stuck I don,t why
Good luck this should do it.
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Feb 08, 2015 | Bose Wave Radio
Bose wave radio/CD three CD changer component is playing for about 4 minutes then saying "disc error" and stopping. My primary unit is working fine.
Obviously the laser reader in the unit is picking up interference from dirt or misalignment. You may have to open it up to get to the aser parts to clean them.
Jan 21, 2013 | Bose Wave music system Multi-CD Changer...
My 3 cd player will not play my cd's , it keeps saying disk error..light turns from green to yellow and starts blinkin....I have tried un-plugging the whole system and re-plugging it back in and the...
Sometimes home made CDs will not play. You might try to stick a good quality CD/DVD cleaner in there and run it two or three complete times. If it got real dirty sometimes one clean just does not do it. If you try both of these to no avail then your lens may have misaligned a bit. Just a mm can cause reading failure. If you have further questions on this issue please feel free to ask me.
Mar 23, 2011 | Bose Wave music system Multi-CD Changer...
Bose Wave System CD does not eject
Just unplug your power supply for 3 hours to reset the unit and to dissipetate power surges.
Hope it may helps;
Jun 12, 2009 | Bose Wave Music System CD Shelf System
Dvd keeps saying "format upsupported" for all movies
Get the free upgrade CD from BOSE and it will solve most of the problems when the program is loaded.
Jan 26, 2009 | Bose 3 2 1 GSX System
I gave the Bose Wave Radio and 3-cd player to a friend for
Unplug and plug back in. It should go through a automatic process, ejecting any discs that are inside. If all you hear is a mechanical noise, try this again only with the disc trays facing the ceiling.
Dec 29, 2008 | Bose Wave Radio
Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Dec 01, 2008 | Bose & Wave& Music System
CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Jun 06, 2008 | Bose Wave music system Multi-CD Changer...
    Bose CD for Surround Sound System
    First suggestion by Bose was to unplug the power cord for about 30 minutes and then plug it back and hit the Eject button...didn't work. Second suggestion was to unplug the power, tilt the unit up onto its left side and then "whack" the bottom of the left side a couple of good whacks. Worked fine and cassette would then eject.
    Apr 20, 2008 | Bose 683-0127FB CD Shelf System
    Bose Wave Radio Logo
    104 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Invebo
    Level 1 Expert
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
