Question about Dishwashers
Miele open stopcock error message - Dishwashers
Why is my Miele dishwasher displaying "Open stopcock", even though water is flowing and I've cleaned the inlet filter?
There are 2 possible main causes for lack of water, given that you have checked water availability at the dishwasher.
1. The water solenoid valve in the machine is faulty or failed.
2. The motherboard in the control panel has a fault and needs replacing.
Unless you are a DIY'er I suggest you call a serviceman
Apr 06, 2017 | Miele Dishwashers
My miele front loader beeping and display saying activated close stopcock.
Defective door lock switch Manual release in side back of door lock
may have pull wire near drain clean out.
Jul 05, 2016 | Miele Washing Machines
What is a stopcock
A stopcock is a handle used to slow or restrict the amount of liquid or gas through a pipe. The most common is what you turn to allow water through your garden hose.
Jan 10, 2012 | Miele Dishwashers
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
The intake/drain lite is lit on my Miele g892sc dishwasher. the unit will not operate in this mode.
Hi
Thanks for using FixYa. The first thing that should be checked is if its draining properly as it could be that the drain hose is clogged and needs to be cleaned. The drain pump also should not be clogged. Also the stopcock should be opened fully and the water inlet valve should be checked for any clogs. Also the metal filter, impeller cover and the air gap unit should be checked. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 11, 2010 | Miele G892SC SS Dishwasher
Reset delay program
Well first of all you can check that the stopcock is opened fully or whether the water inlet hose is kinked. Check that the water inlet filter is not clogged and clean it, if necessary, as described in the operating instructions. Check that the drain pump is not clogged.
Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Post comments if you need furtehr help or information........
Good Luck!!
Mar 27, 2010 | Miele Optima G2420SCi Stainless Steel...
All cycle lights flash and then the machine stops. I tried turning of and unplugging, tried the switch on/off circuit. Pretty much tried everything. How do I reset my Miele G2140 dishwasher?
Good Luck!!
Thanks
Mar 04, 2010 | Dishwashers
How do I reset miele dishwasher - drain pipe now unblocked but will not commence cycle
Good Luck!!
Thanks for using FixYa!!
Nov 29, 2009 | Miele Dishwashers
Miele Dishwasher G 2630 SCi fails to fill.
Debris is jammed in the valve for water ejection. It's jammed slightly open. This happened to me and it was a very small piece of plastic from the lip of a tupperware bowl.
Oct 04, 2017 | Miele 24 in. Incognito G843SCVi Built-In...
Dishwasher stuck´s in program
Well to Reset the error message as follows: To cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again.
If resetting not work then you can check that the stopcock is opened fully or whether the water inlet hose is kinked. Check that the water inlet filter is not clogged and clean it, if necessary, as described in the operating instructions. Check that the drain pump is not clogged.
Good Luck!!
Jun 21, 2009 | Dishwashers
Dishwashers Logo
386 people viewed this question
Top Dishwashers Experts
