Question about Drills
Hilti tr5 drill
Do I need to oil unit in little lid on motor base?
  • 61 Answers
SOURCE: HAVING A PROBLEM WITH MY HILTI TE5 HAMMER
the bearing in the chuck is probly missing. replace the ball baering.
Posted on Oct 11, 2009
  • 123 Answers
SOURCE: will a Hilti TE 17 to drill 1" holes in sandstone?
The TE 17 is at least 29 years old. It will do up to an inch. However there are no parts available for this tool. Also be carefull if it has a black fill cap on top of the gear housing then it does not have a safety clutch. If it has a red one then it does have a clutch.
Posted on Mar 05, 2010
  • 123 Answers
SOURCE: what batteries i need for hilti TE5 cordless
Contact Hilti 800-879-8000
Posted on Apr 10, 2010
  • 61 Answers
SOURCE: Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
Posted on Jun 06, 2010
  • 123 Answers
SOURCE: te70 hilti hammer drill
The TE-70 is permantly lubricated. You would only add lubricant if you took the tool apart. You can add a small amount of grease to the end of your bit occasionally before putting in the chuck. This keeps the chuck parts lubed.
Posted on Jul 23, 2010
Need a cooling fan for hilti hammer drill te22
Claudette,
From my experience with Hilti tools, you have to send the tool back to them for repair. I have not had much luck in getting any parts from them. Sorry!
May 07, 2015 | Hilti Drills
The drill is leaking oil
As my knowledge drills not use oil just grease in the bearings.But if you need to service and the drill is not too old and the repair is not cost too much you can find parts at Hilti Online or by your self using the Hilti Manuals.
Nov 11, 2010 | Hilti 284228 UH 650 Universal 1/2" Hammer...
Te76 will run but will not hammer
THE TOOL IS LOW ON OIL. OR POSSILBE SEAL ISSUE, IT TAKES ITS OWN OIL, HAVE TO GET IT FROM HILTI!!! BE PREPARED YOU HAVE TO BUY A GALLON AT A TIME! IT HURTS!!! OR YOU CAN SEND IT TO HILTI AND YES THEY WILL BE MORE THAN HAPPY TO FIX IT FOR YOU OR GIVE YOU CREDIT TOWARD A NEW ONE, THATS HOW THEY WORK!
Aug 13, 2010 | Hilti Hammer Drill Bit, Te Yx 5/8 In. X 13...
Need brushes for an old style hilti te17
Hilti should be able to provide you with them. If not contact a local motor repair outlet and find brushes the same size, they are very easy to change on the TE series.
Failing that Hilti offers a trade-in program for their tools.
Dec 31, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
I have a hammer drill UH-240A and need motor brushes. Where can I find them?
ive checked the hilti website and theres no brushes avaiable
this is a link to the exploded diagram and parts listing
http://www.us.hilti.com/data/techlib/docs/tool_schematics/sfs/UH_240_A.pdf
it looks as though you would need to replace the motor
heres the link for it
http://www.us.hilti.com/holus/modules/prcat/prca_fuse.jsp?RANGE_OID=31634
hope this helps
if it does please vote
Nov 09, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
What type of oil is used in the Hilti hammer drill casing?
what oil do I use in a te80 hammer drill
Oct 26, 2009 | Hilti Drills
How to dis-assemble motor housing.
Not outside my category list. Its a Hilti, not Hitachi, right? They are a tad tricky. Best thing is to go to Hilti.com in the tech center. Click Tech Center and then Tool Schematic list rotary/combihammers. Get the breakdown. there should be four screws that detach it from base, hard to see. May need allen wrench, can't remember. The fan comes off the armature, may also need small bearing puller. hope this helps. Please rate me
May 23, 2009 | Hilti Drills
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
