Question about Samsung Heating & Cooling
Can't get A/C to turn on
Turned on A/C today for the first time this season, and it started running, but when I hit the cool button, it stopped running and I have not been able to get it to turn on since. How do I reset or re- program the start cycle?
    Problem Solver:
  • 10 Answers
Check the fuse located in the disconnect box located on or near the unit. Make sure you trip the circuit breaker before you open the disconnect. The fuses are in the disconnect box and usually situated in a pull out block. The fuses should read zero ohms resistance on meter. If you don't have a meter take it to hardware store. If the fuses are bad, verify that the max fuse size rating on the nameplate of unit and the fuse rating are the same. If the fuses blow again then you have a problem with the condensor unit. If the fuses are not blown then the problem lies within the unit. Depending on how old it is, you may or may not have trouble codes blinking an LED in the control panel. Either way you will need to call a technician.
Posted on Jun 18, 2009
I have an07 street glide I need the wiring diagram for the starting switch system
Is the bike in gear with the jiffy stand down? Safety circuit will stop bike from starting. Also, is the run switch turned on (the one on the right hand handlebar switch)? Have you any error codes in the speedometer diagnostics? The start switch on the bars do fail so could be that. Listen for a click from the start relay under the side cover while pressing the start switch. No click could mean faulty start switch. If you here a click, then check for 12 volts at the small terminal on the starter solinoid. If missing, starter relay may be at fault. If present, the starter solinoid is faulty. Listen for the fuel pump running after turning on run switch. Pump should run for a few seconds and then stop. If pump not running, then run switch may be at fault.
May 22, 2014 | 2008 Harley Davidson FLHX Street Glide
Unit makes a loud rattling noise when operating
Hello, most likely the fan blade is either loose or cracked at the hub causing the blade to hit the fan shroud. You will either have tighten the fan blade or have to get a replacement.
Jun 20, 2012 | Kenmore 71121 Air Conditioner
Door won't open after self cleaning and cool down has stopped.
if you are sure it has cooled down cycle it again to clean hitting the cancel button shorty after it starts
Dec 09, 2011 | Maytag CWE5800A Electric Double Oven
We have a Jensen marine system that came installed in our Tahoe boat. Shortly after we got the boat, the left speaker stopped working. A few months later, the speaker came back. Then just before the end of...
This really sounds like a wiring problem. I would start from scratch, seeing as how it will be difficult to find the issue you describe. Also, if you can, solder your connections to the radio. If you used crimp butts they may not have been tight enough and vibrated loose with use of the boat. Hope this helps
Sep 04, 2011 | Jensen Car Audio & Video
I installed an RTH2300 this winter to replace an old mercury thermostat. It worked fine for the heating season. I turned it to Cool for the first time today and my AC and furnace blower will not turn...
Maybe turn selector switch to off.see if every thing shuts off.if yes. turn FAN selector switch from (auto) to (on) mode.does the outside unit come on or does just the furnace blower only run ? the inside fan should be the ONLY thing on.if not, reverse the (G) & (Y) wires inside the new thermo.
Jun 07, 2011 | Heating & Cooling
Help!! my dell 6000 laptop has been running without a battery installed, only been using the power cord. The first time I turned it on today, the company freezed after all the desktop icon and start up...
No running the laptop without a battery will not hurt it in any way. I would suggest like you thought that it's a cooling problem. It may need the cooling fins cleaned out and silicone grease reapply'd to the processor and heatsinks.
May 07, 2009 | Dell Inspiron 6400 Notebook
Bought a boxed set of Star Trek Next Generation.In the first two seasons 3 episodes stalled to the extent that they jumped back to the menu.3 episodes were in German.Seasons 3456 were OK.Season 7,of the 25...
One of my grandsons fixed it.He turned up today out of the blue and noticed that I had been hitting the up button at the same time as the play button.Thats what happens when you are clumsy.This caused the choice to change to German.Thanks for the enquiry. Donca
Jul 05, 2008 | Televison & Video
Air-O-Swiss 7133
Okay, I just started getting this same deal with my 7133 on it's third season. I found in a blog that if you hold down the button that controls the heat while turning the mist knob on, it resets the machine. It worked. The red light went green and I turned off the heat button for cool air and the upper light still stayed green. Fingers crossed this continues to work. good luck!
Nov 27, 2007 | Air-O-Swiss 7133 Humidifier
Heating & Cooling Logo
148 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
