Question about Cuisinart DCC-1200 Coffee Maker
Can't change the time
The hr and min buttons don't seem to work when the dial is set to clock
Have you tried turning the left dial to "PROG" instead of "CLOCK"? This is the only way I can change the clock time on mine...Seems like some kind of a design error...Now I'm not sure what the "CLOCK" function does! Very odd...
Posted on Oct 27, 2010
I need the manual on how to set the radio stations
thttp://www.retrevo.com/support/Blaupunkt-MP3000-Car-Receivers-manual/id/550ci556/t/2/
here is your manual....just click the red download button the fill in your email addy and the code and it will download for you. It is a pdf file so if it wont open you need adobe acrobat reader...d/l that and try again...
for the clock keep pressing disp till you see clock 12----then rotate the dial to select 12 or 24 hr format----then press disp to display clock adjust-------then press muts/sens to flash the hour-----rotate dial to desired hour-----press mute/sens to flash min-----rotate dial for correct min----press disp to complete the time set.
don't forget to give testimonial and the votes 4 thumbs up if I helped.
May 29, 2011 | Blaupunkt MP3000 CD Player
How can I adjust the clock on a K7 GSXR-600
Sorry to say, but this problem is easy. Just turn the key to the on position. U don't have to start it at all. Now there are two buttons on the left side of the rpm gauge. One is at top above the N light. This button changes the time (hr & min). The second button is below the N light. It shifts u from hr to min to done. Now, hold down the bottom button for 5 sec, or until u see the number flash on and off. Then u adjust with the top button by pushing it til the correct hr. Tap the bottom button to move to the min side. U do the same as u did for the hr setting. Now, press the bottom button again and ur time is set. These two buttons also allows u to reset ur trip. Also, if u mess up. U have to click the bottom button again, until u get back to the time. Sorry, but it want let u go backwards. This is how to set or adjust the clock on ur K7 GSXR-600. Take care and may God bless u and ur family/friends. L8r.
May 12, 2011 | 2007 Suzuki GSX-R 600
How do i turn off demo mode? And set the clock?
  • Press and hold (SEL) button
  • Then turn the control dial to set "Demo/Link" to off
  • Setting the clock
  • Press number button 4 (Clock). "Clock Hr" (hour) appears. Then, turn the control dial to adjust the hour.
  • Press the >>' /\ (fast forward button) to select "Clock Min" (minute). Then, turn the control dial to adjust the minute.
  • Press the >>' /\ (fast forward button) to select "24H/12H". Then, turn the control dial to select "12Hours" or "24 Hours" time display mode.
  • Exit from setting by pressing the (SEL) Button
Hope that helps, don't forget to vote.
Nov 16, 2010 | JVC KD-G820 CD Player
How do i change the time?
Hello, here is the instructions for setting the clock
RDS Clock Time Broadcasters can choose to send clock time information in the RDS data. This information can be used to update the clock time on the radio. RDS clock time is broadcasted once a minute. To set the clock using RDS clock data perform the following:
• Press and hold the HR and MIN buttons together for two or more seconds to update the time.
• The display will show "UPDATED" after receiving the broadcasted time data. • If the broadcaster is not broadcasting the time data, the radio will display "NO UPDATE" and the time remains unchanged.
if this doesnt work, just simply push and hold the hr and minute buttons to set the time
• Press and hold the HR and MIN buttons together for two or more seconds to update the time. • The display will show "UPDATED" after receiving the broadcasted time data. • If the broadcaster is not broadcasting the time data, the radio will display "NO UPDATE" and the time remains unchanged.
Oct 23, 2010 | 2002 Chevrolet Impala
How to set the clock for a Hyundai Getz?
hi from uk ! to set clock/time on getz look t the speedometer ? you will see two buttons on the bottom of dial ? the left button is to cancel the trip meter by pressing button in for trip A and again for B trips the right hand button marked hr + min ? to set hour time turn to left untill hr time is shown then release now turn button to right to set the minutes then releas when time/minutes ar correct that is it! ps you cannot cancel the odometer/milage clock only trip meter hope this helps best wishes from n/west uk
Oct 16, 2009 | 2001 Hyundai Sonata
Set clock
Turn dial to "Clock"
Press HR button and MIN buttons to change time
Here is a link to the full user's manual - surprisingly, the directions are not in it:
http://www.cuisinart.com/share/man/25_man.pdf
-Tha Mp3 doctor
Mar 08, 2009 | Cuisinart DCC-1200 Coffee Maker
Changing the time pioneer DEN2000MP
The solution that worked for me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
Nov 11, 2008 | Pioneer DEH-2000 CD Changer
Setting the time on car stereo/cd player
Changing the general settings
(PSM)
You can change the items listed on the next page
by using the PSM (Preferred Setting Mode) control.
• The PSM items are grouped into five
categories—“Disp (display),” “Clock,” “Tuner,”
“Color,” and “Audio.”
Basic Procedure
1 Press and hold SEL (select) for more
than 2 seconds so that one of the PSM
items appears on the display.
(See page 23.)
The currently selected
category is shown on the
left side of the display.
2 Press 5 (up) or ∞ (down) repeatedly
until your desired PSM category
appears on the left side of the
display.
3 Select the PSM item you want to
adjust.
4 Adjust the PSM item selected.
5 Repeat steps 2 to 4 to adjust the other
PSM items if necessary.
6 Finish the setting.
To set clock—Clock Hr, Clock Min
You can set the clock using the PSM control.
1 Press and hold SEL (select) for more than 2
seconds so that one of the PSM items appears
on the display.
2 Press 5 or ∞ repeatedly until “Clock” is selected
as the PSM category (it is shown on the left side
of the display).
3 Press ¢ or 4 to select “Clock Hr
(hour).”
4 Turn the control dial to adjust the hour.
5 Press ¢ or 4 to select “Clock Min
(minute).”
6 Turn the control dial to adjust the minute.
Nov 04, 2008 | JVC KD-G720 CD Player
Toshiba DKT2010-SD Phone
OK, model on bottom of phone is DKT2010-SD, but I found a little cheat card in a file for a STRATA DK8 & DK16 so I used a combination of things. First pick up handset and then hit intercom button, # 652 (for time or #651 for date) and enter time in HHMMSS (hour, minute, second) format, once complete hit the redial button.
Nov 03, 2008 | Toshiba DKT-2010 Corded Phone
Changing the clock
Wow I know its been a while but I can tell you how to change the clock on your radio. It can be done while the radio in on or off. To simplify this please turn radio off. The incorrect time should be displayed. There is a button that is the display (disp) located in the middle right of the face.( If for some reason the time is not displayed, press the disp button once or as many times needed until the time is displayed. Now let it go and continue from there.) Press and Hold this button down until the time begins to blink. Once it begins to blink let go of the disp button. Now the next button you are going to use is the 'skip' button (>>I) for the hr only and the (I<<) button for the min. You cannot go backwards only forward. You must observe the correct time of day or am/pm. The >>I and the I<< are far right and vertical to each other. Because one is for hr and the other is for min you can not go backwards only forwards. So hold down the hr button until it is the right am or pm and the right hr. The min is simpler since you don't have to worry about am or pm, just depress the button once it reaches the right mins in the hr. Hope this helps
Jul 16, 2007 | Verge VMP508 CD Player
Cuisinart DCC-1200 Coffee Maker Logo
634 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
