Question about Clarion MAX385VD Car DVD Player
I need a wiring diagram for Pyle view PLDNV78i
How can I get the install instructions for PYLE PL7300BT Rear View camera system?
Pyle PLCM7300BT Mobile Video Navigations Back up Camera Rear View...
Went to this site to find your particular product,it has a downloadable pdf manual whic will by default show you your setup.You may not have the green wire but if you read this manual you may be able to by process of elimination figure out your question.Pyle also has a very good technical support staff,been there done that ,they will also help you out.Good luck hope this helps you.
May 19, 2014 | Pyle PLCM7300BT 7"TFT Mirror Monitor W/...
Not able to active after reset pldnv78i
Not sure what connection method you have.. do you have USB driving the touch screen or all inclusive HDMI, or serial port... Anyhow, you need to check your drivers and remove and reinstall them. It is most likely a driver problem. Next check cabling if the touch screen is outside the video signal (non-HDMI modality).
Jan 29, 2014 | Pyle Pldnv78i 7-inch Double Din...
Installation instructions for pyle view plcm7200
Where do I hook up the green wire on Pyle 7200 rear view camera
Dec 27, 2012 | Pyle PLCM7200 7'' Tft Mirror Monitor W/...
I want the installation manual for this product
Manual for what? Plug in the power, plug in the display port and your done. What are you trying to do?
Nov 30, 2012 | Pyle Pldnv78i 7-inch Double Din...
I have a Pyle pldnv78i car stereo and the factory setting for the volume is set too high. How can I adjust it?
As of now, the only fix is to set the volume lower to what it should be (ex: level 2) and turn it off before turning off your vehicle. Start your vehicle and turn the radio back on, it will remember the last setting you had it on. You just have to remember to do this every time you use this unit.
Sep 22, 2012 | Car Audio & Video
I recently purchased the pldnv78i. Where do I hook the key 1
I know that these wires are for "Steering control" finction.
Feb 27, 2012 | Pyle Car Audio & Video
Can someone tell me what the Key 1, Key 2, and Key Ground wires on Pyle audio systems are?
They are for the steering wheel controls. If you don't have the steering wheel functions in your car, then I wouldn't worry about them. You may have a bad antenna for the gps.
Dec 03, 2011 | XO Vision Car Audio & Video
Clarion MAX385VD Car DVD Player Logo
48 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
