How do I turn off lights service copy minolta ep 1054
  • 57 Answers
SOURCE: EP 1083 service /reset codes
Press on keyboard, stop o stop 1. Press 4 to enter counter mode., the first counter should be the pm, displaying a counter with a negative sign. Press cancel key to reset to 0. Exit service mode by pressing panel reset 2 or 3 times and you should be back in business.
Posted on Jul 14, 2008
SOURCE: meaning of code C04 ( EP 2030)
minolta cspro1054 turns off once you turn it on and code is c
Posted on Nov 03, 2008
Cogz
  • 1326 Answers
SOURCE: I want minolta ep 1054 simulation code,please help
I think you are looking to get to service mode. The switch is on the back of the copier > you will have to take the back pannel off. The dervice switch looks like a small Black botton > it is on the main control PCB.... press it once and make sure the doors are closed and then go to the reset mode and you are good to go.
Posted on Apr 25, 2010
  • 3 Answers
SOURCE: minolta EP 2050 copier
transfer crona is lekage change the tranasfer corona ano clear the code error ce200
Posted on Jul 19, 2010
ginko
  • 19396 Answers
SOURCE: Describe your how can I
Hi.
If you want to attempt resetting the counter enter in service mode and do a Timer Reset.
If you have replaced the drum (or if you need to replace it), then you have to perform the auto image density control procedure.
To reset the meter count:
enter service mode: stop, 0, 0, stop, 0,1, find meter count and reset. This should be done by pressing "1" to access meter count, then press"8" to display counter on the zoom display.
Stop key - 0 - 0 -Stop key - 0 - 1 and press 1.When you see E in the display, press 5 and the copy(start) button to perform the auto image density control procedure.
Posted on Sep 02, 2010
How do i solve my minolta copier cspro ep 1054 printing blank document
check the transfer wire assy. located under the drum. might not have a good connection or the High Voltage unit is bad. That is a very old machine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 03, 2017 | Minolta Office Equipment & Supplies
How can i put a passlock or a password on my ep 1054 minolta
You are talking about a real legacy Minolta Copier. I don't believe it can be done. Technology had not advance that far when she came out. Go to a service manual web site and see if some one might have a operation manual for that machine. Do you have yours?
Mar 04, 2015 | Konica Minolta Office Equipment & Supplies
How to Fix Error c 05 Minolta ep 1054
Open up the machine, near the heater section, there is a push button on the circuit board.Press it, machine will restart and code is removed.
Feb 07, 2015 | Konica Minolta Office Equipment & Supplies
Minolta EP 1054 - need to change the cleaning blade
Hi, I have all spare Minolta EP 1054 copie.But quistion Where you live? If you live in Bangladesh.I will give you.But if you live another country you send money I send it by DHL.Please contact us xptareq2000@yahoo.com or call 08801819879575.
Jul 26, 2011 | Minolta EP1030/1030F CS/PRO Copier
Ink fall in down inside minolta cs pro ep 1054
Get the developer replaced. and developer unit cleaned. Have a Konica Minolta tech come out and clean the entire machine replace the required parts such as Developer, clear the counters and run the required F8
Oct 31, 2010 | Minolta EP1083 CS/PRO Copier
I want minolta ep 1054 simulation code,please help me
Apr 24, 2010 | Minolta EP1083 CS/PRO Copier
Minolta ep 1054 copier paper jams and 3 appear on the panel
you mean a J3? check the fuser section the hot part. replace the parts as required
Jan 03, 2010 | Minolta EP1030/1030F CS/PRO Copier
What is the meaning og service code coo 70 for minolta ep 1054. thanks
Toner bottle rotation failure. This is usually caused by the toner bottle/cartridge not being installed correctly. Did you just recently install a new one?
Best solution is to try and remove the cartridge. Then leave it out, and close the machine back up and let it run. Only re-install the toner cartridge after the machine has completely stopped.
The machine rotates this cartridge when adding toner. So what happens is the add toner light comes on and if you open the machine to add toner while it is running the bottle stops turning and is thus out of it's home position.
Nov 25, 2009 | Office Equipment & Supplies
COde for ep1054
Service code: Press Stop keys - 0 - 1.
May 25, 2009 | Minolta EP1030/1030F CS/PRO Copier
18 people viewed this question
k24674
jasbo
jasbo
