Question about Mister Twister Electric Fisherman Fillet Knife
Trigger broke - Mister Twister Electric Fisherman Fillet Knife
Throttle control trigger on Stihl 56c blower doesn't work..is this carburetor problem?
yes it is a trigger with a cable going to the carburetor. when you squeeze the trigger you should see the butterfly on the carb move. if not some thing has broke. or cable has come off the track. better get a second opinion on that. sounds like someone wants to sell you a carb.
Aug 08, 2016 | Stihl Garden
How do I repair a non-functioning solution trigger
The trigger has tabs on each side that snap into slots in the handle so that the trigger pivots in the slots. The slots where the trigger pivots may have broken, if so the trigger will not push the valve open and allow the water flow. If the tabs are broken you will need to replace the upper handle. If you supply me with your model number I will determine the proper part for your model.
Dec 14, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My NERF gun broke.
Take it back to where you bought it. It shouldnt do that, it sounds faulty to me. I am sure they will replace a faulty item.
Feb 26, 2014 | Hasbro Nerf N-strike Longstrike Cs-6 2010...
I have a fs 55 stihl weedeater I had it on my fourwheeler and hit a tree with the shaft it broke the trigger release button and caused the trigger to pop out i could still use it until I attempted to put...
in the trigger handle there is a cable that attaches to the throttle. This cable has a ball end (just like a bicycle brake cable). You have probably popped it out when you refitted the lever. split the handle and refit to trigger
Sep 12, 2013 | Garden
I was driving down the freeway and my 1998 Plymouth breeze just dies on me. Thought my timing belt broke but when I took off the cover the belt is not broke. It stills turns over and there is spark at...
need to check fuel injection trigger if no trigger check for voltage on injector connector if there is b+ on both wires need to pinout pcm if no voltage on one wire check efi fuse
Oct 28, 2010 | 1998 Plymouth Breeze
Trigger fell out
I would advise you to send the product back to the
manufacture, either for repair or refund.
Jul 19, 2010 | Toys
When i press the trigger for water to come out it doesn't?
there is a very weak plastic plunger under the trigger on the hose, if that is the one you are speaking of. mine broke shortly after i bought it. i just bought a replacement hose and used epoxy to build up the trigger for holding it's position better without snapping off.
Jun 05, 2010 | Bissell 9200 Upright Vacuum
Weedeater gas TE400. Trigger broke (perhaps
120' cord. I would go to a big-box store and investigate making your own cord so that you only have 2 ends. 12 guage at the very least. any thing smaller, and you will burn up the motor.
I believe that the trigger and throttle cable should solve your issue.
530071550 throttle kit $8.16 + 12.75 shipping
Nov 07, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
I think the trigger on my upholstery hose is broke how can i tell? trigger is loose- water just flows out and i have to shut the machine off. i have a hoover steam vac dual deep cleaner
The most common issue with this is the white nozzle tip broken. sometimes it comes out. it still could be the trigger. take it to a shop and they can tell right away. the trigger is spring loaded, you should feel tension.
Oct 09, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
L Trigger isn't working.
The l trigger got hit hard, and a wire broke, same thing happened 2 me,not the Gears of War part but the broke button. I just replaced my controller at SEARS.
Mar 22, 2009 | Microsoft Xbox 360 Controller
Mister Twister Electric Fisherman Fillet Knife Logo
20 people viewed this question
Top Mister Twister Sport & Outdoor - Others Experts
Are you a Mister Twister Sport and Outdoor - Other Expert? Answer questions, earn points and help others
