Question about Jetway V266B Motherboard
I want to change boot order in my jetway boot from cd
How to change setting in bios to boot from cd drive"?"
you usually dont have to change the boot order to boot from a cd. the bios should check the cd rom before booting from the hdd. However, if that isnt the case, you can always change the boot order.
go to the bios settings while u turn your laptop on. (It should be "esc" for HP. a message will be displayed at the bottom of the screen indicating the key. if not, try esc, f10, f11, f12. either one of them should work).
go to the boot order settings (May have a different name- boot settings/ boot priority settings/ advance boot options etc.).
Jul 13, 2014 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
I want to change the boot order in my jetway motherboard from cd
re start your pc then while the pc is boot press control alt delete . then it will go to bios set up . then select first boot set up to cd .
Apr 13, 2014 | Jetway 939GT4-SLI-G Motherboard
How to change boot up menu to cd rom
when your laptop sets up press F10 that will take you to your BIOS ...next go to "ADVANCED" Next go to BOOT OPTIONS...NEXT go to BOOT ORDER.... To change the order of your boot, use the + and - keys, after you get the cd-rom first in order, hit F10....go over to the "FILE" and save changes and exit. Your laptop will restart on its own ! to change the setting back just reverse the boot order ! :)
Jan 26, 2013 | HP Compaq Presario 2100 Laptop
Reboot with cd
Put the cd in the drive and the system might be set to boot from it automatically.
If not, Put the cd in the drive and watch your screen for which key it says to hit to change the Boot Order or Boot Sequence, when you see the message, hit that key. This is a temporary change only good for the current boot cycle.
If you want to make a permanent change to the boot order or boot sequence, reboot your system and watch the screen for which key it says to hit to enter the Bios or System Setup. When you see the message, hit the key. Tab over to change the boot order or boot sequence. Normally you would make the CD/DvD drive 1st and the Hard Drive 2nd, because if the hard drive fails or has a problem you can always insert the cd and it will boot from it first. Just make sure when you boot that there is no music cd or movie dvd in the drive or you will get a message saying something to the effect of Unbootable device.
May 14, 2012 | Computers & Internet
Jetway 740dmp Failure to boot
Replace the memory chip or try it in a different memory slot. Sounds like it has some issues.
May 12, 2012 | Jetway 1GB 740DMP/DMU/DMZ 333MHz UDIMM
Phoenix bios D686 (1999)
Go to the BIOS setup and find the Boot Seuence. Select Hard Disk first and if Hard Disk in blank, Boot from CD and install Operating System. This error usually comes when BIOS do not find the Boot Record on Hard Disk. (ehteshamhusain@gmail.com)
Jul 18, 2009 | Jetway V266B Motherboard
I purchased a new motherboard Jetway LGA775.... keyboard and mouse do not work. How do I make them work?
The motherboard does not have the drivers installed and that is why they are not working. If you have the cd's for them, try booting pc with the cd's already installed. They should have auto-detected them. If you have a schematic of the motherboard, check all jumpers to make sure they are set correctly.
Jul 11, 2009 | Jetway MiniQ-450 P4/ 533FSB W/ Remote,...
Boot cd problems
You can't just put the windows cd in your cd rom drive. If your going to change your boot order (to cd), then you HAVE TO use a BOOTABLE cd. That means a bootup disk with all the correct bootable files for WINXP. Same with a floppy. Change your boot order to a floppy....and in order to bootup windows, you MUST HAVE the bootable files ON THE floppy. In your case...the cd. The windows xp does not have the bootable files since it is only used for install and reinstall.
Create a bootable CD or floppy (((from someone elses WINXP pc or laptop))). There is a feature that allows you to do that. Then when you boot to cd it will start windows and give you options.
Mar 31, 2009 | Panasonic Toughbook CF-27 Notebook
Jetway 939 gt motherboard install
What install disk are you talking about, and sorry ,need to know the error too.
Nov 18, 2007 | Jetway 939GT4-SLI-G Motherboard
Jetway 867AS motherboard problem
Hi, the problem not your video. It is your memory module, it is faulty. Try another one that is surely working and it should boot right up. Good Luck!
Jun 02, 2007 | Jetway V266B Motherboard
Jetway V266B Motherboard Logo
53 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
