Question about Compaq NVIDIA TNT2 M64 (32 MB) AGP Graphic Card
Loud noises my graphic card makes weired noises when the computer starts and the fan spins slow
  • 50 Answers
It is very possible that that fan is mulfunctionning overheating the videocard. replace the fan. (you can by the fan seperate from radioshack or some local computer store. (sometimes it is cheaper to replace the video card since it comes with it's own fan.) but of course it depends on what card you have.
Posted on Jun 18, 2009
Whining fan dell E520 computer
Replace the fan as soon as possible. If the noise suddenly stops, DON'T assume the problem corrected itself. More likely, the fan completely froze and stopped spinning entirely and you're at risk of overheating something inside. Generally, there are usually 3 fans in a desktop computer (cpu/heatsink, case, and power supply) and sometimes a 4th fan if the computer has a separate graphics card. Laptops usually only have one fan.
Apr 27, 2014 | Dell Dimension E520 PC Desktop
My HD 4850 fan is not spinning correctly. It will spin normally for a few moments, then make a cranking noise, then start moving extremely slowly, and sometimes it even stops. Now it is not even spinning,...
Your heatsink fan on the graphic card is failing and the motor is going down hill, now saying it has completly stopped..,.. that means the fan motor is done for and need to be replaced to avoid further damage to your graphic card. Would reccommend you not using your graphic card until a new heatsink fan is replaced otherwise you can fry your GPU and suffer a complete loss.
Jan 15, 2011 | HIS H485QT512P RADEON HD 4850 GDDR3 PCI...
Loud Whining Noise from Motherboard on Startup
Whining noise is something in motion or moving.Does the graphics card have a onboard fan?Is it clean and free moving.
How about the processor fan? clean,free from wires or anything hitting it.?
Disconnect hard drive and see if you get the sound.
Jan 18, 2010 | Abit IP35P Motherboard
Making loud noise
What you need to do..is open you comuter and have a look if the fan is spining in you card..if not you need to take it back to your supplier you baught it from....but if the fan is spinning just to check the temps get evga precision program.It runs with all nvidia cards...with the program you can put fanspeed up or down ect...here is the link for it...just install and proceed..http://downloads.guru3d.com/EVGA-Precision-1.7.1-download-2251.html the noise should not be a prob but to make sure check your temps with program anywhere between 53-60 Is still safe...Please let me know how it goes and if this has assisted you :-)
Dec 23, 2009 | ASUS NVIDIA GeForce 260 GTX,, PCI Express...
Card started making loud clicking noise i have tried blowing dust out of it when i start my computer within a few minutes clicking starts again
Hi, couple main reasons to get loud clicking in a computer. First is the hard drive, so if you can turn the system off and disconnect the power and the information cable from the hard drive, yes your computer will not boot all the way back into windows but that is ok since you just want it running for awhile to see if the clicking stops. Next thing would definitely be the fans, any fan in the system, the blade part of the fans can get loose sometimes and start to hit the sides as it spins around, you need to be sure about which part it is that is causing it, it can come from the power supply fan, the case fan, the video card fan, the cpu fan, and you might have more than one case fan, test by disconnecting one at a time just make sure to disconnect the device too so you do not over heat anything. Once you identify which fan just replace it, if its something like power supply or video card, unfortunately you might want to look into either warrantying the part or buying a new one.
Nov 01, 2009 | PNY GeForce 9800 GT, PCI Express Video...
ASUS Lap top computer, 2 months old' makes loud fan type noises at each start up.
Hi
Its normal for a laptop computer or a desktop computer to spin its fans at maximum speed during start up - its part of the power on self test.
If the fan is very loud like on this video the sound is very bad -
that would be a bad fan, constant bad noise. but if your fan only makes noise in start up, its normal.
your warranty should cover the replacement of the fan if its bad.
Oct 02, 2009 | ASUS Z71V Notebook Computer - 15.4"...
CPU fan problem
The stock fans that comes with systems are usually fairly poor in construction and tend to fail. I would have a look at the fans and heat sinks on this website for a replacement.
I hope this helps,
Thanks for using FixYa,
Eric
Jan 20, 2009 | PNY VERTO GEFORCE 6600GT 128MB DDR3 PCIE...
Fan Noise
No it's not normal. Send it back to where you bought it.
Jun 29, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
Loud Fan Noise
Usually the fan on graphic card dies first. It can be replaced with another one but I'd suggest you to build in 80 or 100 mm fan to blow directly on your graphic card cooler. Remove the lid and check if perhaps some cable has fallen close/into fan blade. It must be one of those two. I'm 90% certain.
Apr 23, 2008 | E-Machines eMachines Desktop PC
Compaq NVIDIA TNT2 M64 (32 MB) AGP Graphic Card Logo
123 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
