Question about Refrigerators
Frigidaire refrigerator with SY and EF codes displaying. Really loud noise coming from freezer section.
In the past, we had to clear chunks of ice from the motor in the freezer. But currently there is no ice accumilation.
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: My Frigidaire Gallery display says
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Aug 04, 2011
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Frigidaire fridge model FGUN2642LF6 fridge is not working. Code displays sy and ef, what is wrong
Your evaporator fan is not spinning.
Check to make sure there isn't any ice build up jamming up the fan. If there isn't then it's either the evaporator fan, or the main board.
Aug 14, 2015 | Frigidaire Refrigerators
My refrigerator is not keeping temp and there is a code on the water/ice machine reads S(or 5)y EF. What does this code indicate?
If I'm not mistaken EF error code stands for Evaporator Fan which is the fan motor in the back of the freezer section. That would explain the noise you heard. The fan could possibly be frozen or stuck or the motor actually went bad and needs replaced. Without that fan running you will get very little cooling.
Apr 15, 2015 | Refrigerators
What does the error code 5y EF mean on my Frigidaire refrigerator
Good Morning Friend,
I understand you are receiving an "SY EF" code on your Frigidaire refrigerator, model# FRS3R5EMB. The "SY EF" code stands for system error with the evaporator fan. This possibly means that there is something going on with your evaporator fan or it could possibly be a false error code. . I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FRS3R5EMB Side by Side...
What is code 5y and ef
Hi M - I am happy to assist you! Error codes SY/EF is commonly refer to a failure with the evaporator fan circuit. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power does not correct the issue, then more than likely there is a potential wiring failure between the main control board and evaporator fan. In this regard, I would personally suggest to reaching out to a repair tech to further evaluate and repair you appliance. If you have further questions, please do not hesitate to reconnect.
Jul 18, 2013 | Frigidaire FRS26H5AS Side by Side...
I have an old Frigidaire refrigeator/freezer, freezer on top. Model # FRT18TJHWO. It say manufactured 06-00. I presume that means June of 2000. I have had this for almost two years. A friend gave it...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 21, 2010 | Frigidaire Refrigerators
Loud noise coming from icemaker...noise decreases when i increase temp and goes away when icemaker shut off. I set the initial temp at 3 degrees, then let it make ice - after about 3 hours it sounded like...
The icemaker is pretty simple, there is a motor, a solenoid, and a couple of switches.
It sounds like the whole icemaker mechanism is jammed or has a broken gear, and the motor is trying it's darndest to turn the stuck mechanism (grinding it's gears in the process), or the gear has already gone, and what's left of the gear is dancing around in there.
http://www.repairclinic.com/Appliance-Parts?s=t-frs26r4a-%3d%3dc248
My guess is either the $7 icemaker drive gear or the $94 icemaker assembly.
Oct 23, 2009 | Frigidaire FRS26R4A Side by Side...
Open Questions:
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
